Old Jul 29, 2009, 04:37 AM
AD. is offline
AD.
Find More Posts by AD.
AD.
Team Better Than Yours
AD.'s Avatar
London, UK
Joined Jul 2009
I think the rc-model.cn isnt the manufacturer (AXN) but a distributor for AXN and a few other companies
AD. is offline Find More Posts by AD.
Old Jul 29, 2009, 10:20 AM
saucisse is offline
Find More Posts by saucisse
Don't disturb the pilot !!!
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Need some advise.... what's is the best way to repair the fuse ?
I always fly over tall grass fields so crashing has never been an issue but this morning I went to the local football field and I did crashed it pretty hard.
The nose is bent to the right and cracked on 3 places. I know I can use my foam safe CA glue for the cracks but as for putting the nose straight back what should I do?
saucisse is offline Find More Posts by saucisse
Old Jul 29, 2009, 11:24 PM
Warsaw is offline
Find More Posts by Warsaw
Warsaw's Avatar
Iowa
Joined Jan 2006
I wonder if heating it a little with a heat gun or hair dryer would make it easier to straighten out?
Warsaw is offline Find More Posts by Warsaw
Old Jul 30, 2009, 12:54 AM
NinetySix is offline
Find More Posts by NinetySix
Melbourne, Australia
Joined Mar 2009
Mine was worse than that after a few nose landings, but just get some boiling water onto the bent/crushed foam parts and it should pop back to its original shape. dont forget to rub it with a spoon afterwards to get the bubbles out.
If its still a littled bowed out then put a little tape on to hold it in the right position after gluing the cracks
NinetySix is offline Find More Posts by NinetySix
Old Jul 30, 2009, 04:27 AM
pghern is offline
Find More Posts by pghern
Crashing in Melbourne
Australia, VIC, Rowville
Joined Jan 2009
Hello All, Great thread,
I have just go my Clouds Fly from Singapore along with Spectrum DX6i.
This is my first plane but hopefully not my last therefore I chose a good Tx.
My question is can I put the ESC directly under the battery or will it get too hot.
I have got a 2200mha battery, cut out a little and have a snug fit.
There is still room for the ESC under the battery.
Also any issue with the 2.4ghz Rx being close to the battery and and power wires?
Peter
pghern is offline Find More Posts by pghern
Old Jul 30, 2009, 04:32 AM
pghern is offline
Joined Jan 2009
One other thing...
I see the Y connector for the Ailerons servos included in the kit - given that I have a 6ch TX would I be better getting two servo wires and use the program capabilities of the DX6i to set the ailerons?
I was thinking about setting up spoilerons as everyone is saying how well this thing glides - it might better for control when landing?
I welcome all comments please.
Peter
Old Jul 30, 2009, 08:08 AM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Should I just remove the electronics and just ''dip'' the nose in boiling water or use a spoon and drop water to the bent areas ?
Thanks for the help!
Old Jul 30, 2009, 11:15 AM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
This EPO foam is simply amazing!! Dipped the hole front fuselage in boiling water and everything went back to its original shape!! Final touch with some foam safe CA glue and packing tape and I'm back to the field after lunch time!!
Thanks for the tip !
Old Jul 30, 2009, 02:14 PM
Medvidek is offline
Find More Posts by Medvidek
Medvidek's Avatar
Prague, Czech Republic
Joined Mar 2009
Originally Posted by ajbaker
THIS is a significant improvement.
AJ
Hello Ajbaker,
would be so kind and give exact dimensions of this motor as there are confusing info on Hobbycity site.
Medvidek
Medvidek is offline Find More Posts by Medvidek
Old Jul 30, 2009, 05:16 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Originally Posted by Medvidek
Hello Ajbaker,
Medvidek
Here are the specs on that motor:
http://www.hobbycity.com/hobbycity/s...idProduct=2046
AJ
ajbaker is offline Find More Posts by ajbaker
Old Jul 30, 2009, 06:38 PM
EDGEE400 is offline
Find More Posts by EDGEE400
United States, NJ, North Bergen
Joined Feb 2009
Peter
I wouldnt recomend putting the esc under the batt cause they both will get hot. I put the esc behind the servos in the fuselage it will help balance it with the 2200 batt also put the receiver there also. I too use a dx6i and i use the y connectors but to each his own i like the extra channel available to add stuff.
EDGEE400 is offline Find More Posts by EDGEE400
Old Jul 31, 2009, 01:37 PM
daveyedgar is offline
Find More Posts by daveyedgar
www.RCdavey.com
daveyedgar's Avatar
New York City
Joined Jun 2009
Hey I was wondering if it is possible to use a wild hawk receiver and radio on the axn. can it be so?...
daveyedgar is offline Find More Posts by daveyedgar
Old Jul 31, 2009, 03:15 PM
Joined Mar 2009
thats a 3 channel radio isnt it? If so, no you cant... the axn is a 4 channel aileron plane. get a hobbyking 4ch or 6ch radio if you are cheap
Old Aug 01, 2009, 02:59 AM
jaccies is offline
Find More Posts by jaccies
The Netherlands, LI, Venray
Joined Dec 2008
Hello Ajbaker,
Medvidek
Check this website:
Towerpro motor
jaccies is offline Find More Posts by jaccies
Old Aug 01, 2009, 11:49 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Originally Posted by jaccies
Check this website:
Towerpro motor
That site has LESS information than the HC site. And, they are the manufacturer. You would think they would give more info.
AJ
