Old Jul 04, 2011, 02:55 PM
theothercliff is online now
Find More Posts by theothercliff
Much happier at LibrePilot!
Temple, GA, USA
Joined Jun 2009
Originally Posted by galognu View Post
Holy crap, what a voluminous thread.
Too long to search, so hope someone has modified their motor due to the original crappy one.
I am wondering about the proper thrust angle. Mine had flown easy with a 2200, but after the motor change, it's had issues. The most significant one is that after I throw it, and hit throttle it pitches down violently. Elevator goes up and down appropriatedly, like it did before the motor change.
After making the thrust angle look more like stock it did the exact same thing today, and as I was looking at it after a nice bump on the nose, I noted that the elevator servo is loose!!!!!. SO I am hoping that helps once I fix it, but still wonder if anyone has an answer for the proper thrust angle. I switched to some tower hobby outrunner I had available.
If you mounted the motor higher above the wing you may need to tip the back of the motor up a lot to avoid the nosing over.
If the motor you added has a lot more power, you will need to launch with less power because the "nose down from hitting the gas at low speed" problem will have even more gas to cause the problem with.
Cliff
theothercliff is online now Find More Posts by theothercliff
Old Jul 04, 2011, 04:41 PM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Some video of the AXN this weekend out at the cottage in Summerside PEI.
Recorded with HD Keychain cam attached just behind the canopy.
Locke Shore Summerside PEI - AXN Floater-Jet Flights (6 min 7 sec)
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Jul 04, 2011, 06:15 PM
JLT_GTI is offline
Find More Posts by JLT_GTI
JLT_GTI's Avatar
Spain, Principado de Asturias, Oviedo
Joined Jun 2010
Amazing!.. simply beautiful
did you used a #11 keychain cam?
JLT_GTI is offline Find More Posts by JLT_GTI
Old Jul 04, 2011, 06:17 PM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Yes the #11 from this thread with the version 2 firmware. Got to say I love this cam for what it is and the price. Great quality and wiper simple to mount on almost anything compared to my gopro.
Site Sponsor
Old Jul 04, 2011, 09:55 PM
galognu is offline
Find More Posts by galognu
galognu's Avatar
United States, NY, Jamestown
Joined Dec 2004
Well, fixed the servo, rechecked the CG which was actually a bit forward. Bit the bullet threw it and it took off quite nice. Had to trim down the elevator, and it flew like the floater she is.
galognu is offline Find More Posts by galognu
Old Jul 05, 2011, 12:42 AM
rogueqd is offline
Find More Posts by rogueqd
Quads, 4 times the fun.
Australia, NSW, Brookvale
Joined Apr 2011
Yes the #11 ... with the version 2 firmware.
What's the version 2 firmware? Can the firmware be updated?
rogueqd is offline Find More Posts by rogueqd
Old Jul 05, 2011, 04:40 AM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
All the info on the cam can be found here http://www.rcgroups.com/forums/showthread.php?t=1362692
Site Sponsor
Old Jul 05, 2011, 04:20 PM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
short video CF in action :-)
New location for FPV (6 min 16 sec)
nakelp86 is offline Find More Posts by nakelp86
Old Jul 06, 2011, 03:44 PM
km28104 is offline
Find More Posts by km28104
km28104's Avatar
Indian Trail, NC
Joined Oct 2009
Nj
Nice video... where in NJ was that?
Ken
km28104 is offline Find More Posts by km28104
Old Jul 06, 2011, 04:12 PM
JLT_GTI is offline
JLT_GTI's Avatar
Joined Jun 2010
I finally ordered the 2212 motor...
Anyone uses it? Whats the recomended prop for it? the stock 5X5? or its worth going up to 6X4 or maybe 6X5?
Old Jul 06, 2011, 05:20 PM
TwoHeadsBrewing is offline
Find More Posts by TwoHeadsBrewing
Moderately Dangerous
TwoHeadsBrewing's Avatar
United States, CA, Chico
Joined Apr 2011
Which motor is that?
TwoHeadsBrewing is offline Find More Posts by TwoHeadsBrewing
Old Jul 06, 2011, 05:29 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Ken
Thx
I think Keyport area
Old Jul 06, 2011, 05:56 PM
JLT_GTI is offline
JLT_GTI's Avatar
Joined Jun 2010
2212-6 2200KV
Weight: 50g
KV(rpm/v): 2200
Max Power: 342W
Battery: 2-3Li-Po
Test Prop: 7x3/7x4
ESC(A): 30A
Old Jul 06, 2011, 06:23 PM
Joined Apr 2011
Anyone ever use this motor from hobbypartz?
http://www.hobbypartz.com/93a16-09-motor2600kv.html
2600kv/2750kv (hard to tell based on title and listed specs)
78g
Max Efficiency: 30-35A
Seems like it might be a great upgrade with the 5x5 or 6x4 prop.
Old Jul 06, 2011, 09:53 PM
garymcc is offline
Find More Posts by garymcc
West Texas USA
Joined Mar 2008
I have the RCTimer 2826-6 2200kv on my AXN. With a 6x4E it performs well without FPV gear. Mine will not climb vertical.
garymcc is offline Find More Posts by garymcc
