AJ |
AJ |
From the photo I could see it was an original prop. I just checked with an original one and checked the lettering. So from his first post (after a few drinks) I thought this would be the best way to comment. It is a great drawing and I completely understand it. All the best. |
AJ |
You keep saying to replace the original ESC but I say the NEW 25amp ones are all right. But you got your way as I am currently putting the ESC on top of the body like the Easy* so stupid not to change the ESC I suppose. I'll have a Turnigy 30amp on in a few minutes with a Turnigy 3amp BEC seeing I am putting in a FY20. |
![]() ![]() ![]() ![]() I think it is time for you to go visit the sandman... AJ |
Thanks AJBaker. I've moved the ESC to behind the servos and also moved the battery back to as close as I can get it to the servos while still allowing movement. I'm hoping this will solve the issue, but if not I may look into getting a new 1800mah battery. I haven't had a chance to fly due to t-storms yesterday (wth, it's June in CA!). Today is looking decent though, so hopefully I will be able to get out and test the modifications.
