Old Jul 16, 2009, 11:18 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Originally Posted by jaccies
I use this lipo , also a perfect CG at 48mm ( this one is 33gr heavier then yours)
Yes. But, you have to hack away some foam to get them to fit. The 1800mah slips in nice and tight and can move further forward if necessary. But, yes. They both work.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Jul 17, 2009, 04:55 AM
AD. is offline
AD.
Find More Posts by AD.
AD.
Team Better Than Yours
AD.'s Avatar
London, UK
Joined Jul 2009
Yeah i love bidproducts its really cheap and i find the servos good quality.
AD. is offline Find More Posts by AD.
Old Jul 17, 2009, 04:49 PM
RCengineer is offline
Find More Posts by RCengineer
Joined Jan 2007
I just wanted to say that Phillip from PW-RC (Link) has fantastic communication and very fast service.
Within 1/2 hour he had responded to my email and sent me a request for money as my order would not go through. He had it repackaged and shipped the very next morning (it was 8:00 pm EST when I ordered).
Great stuff! I will do business with him again.
I just looked and he as them available now.
RCengineer is offline Find More Posts by RCengineer
Old Jul 18, 2009, 02:47 PM
jaccies is offline
Find More Posts by jaccies
The Netherlands, LI, Venray
Joined Dec 2008
I bought this :propadapter
But is not a success because i have a lot of vibrations .
Is this caused by that the prop is quite far from the motor?
Anyone used a propadapter?
jaccies is offline Find More Posts by jaccies
Old Jul 18, 2009, 03:57 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Did you balance the prop?
Could be. But not likely. 1st, remove the old prop saver (you certainly don't need it with the collet type prop adapter). Try it. Next, make sure the prop is balanced (most likely problem). If those don't fix it, cut off the motor shaft until the collet is right up next to the motor. One of those will probably fix your problem. Balancing the prop is very critical in these high kv motors.
AJ
P.S. I have many of the very same collet adapters (7) that you have and they work perfectly. BTW, while I suggested cutting off the motor shaft, I have never had to do that.
Old Jul 19, 2009, 02:00 AM
Warsaw is offline
Find More Posts by Warsaw
Warsaw's Avatar
Iowa
Joined Jan 2006
It can't be removed.
Warsaw is offline Find More Posts by Warsaw
Old Jul 19, 2009, 02:51 AM
jaccies is offline
Joined Dec 2008
Yes thats is what i also see.
And AJ it is not a collet adapter its is 3mm grubscrew type adapter
Old Jul 19, 2009, 03:24 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Yeah. I got my motors confused. Still, the prop balancing will probably fix it. Or, cut off enough of the shaft so the collet kisses the prop saver. Still, though, I am pretty sure it is the balance or maybe the collet was not center drilled properly. I have never seen that happen though.
AJ
Old Jul 19, 2009, 03:30 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Still, it comes to the same end. Is the prop balanced? 90%+ of the times I have run into your problem with props, the prop was not balanced. Do you still have the other prop to try? Oh, I just read my notes. Both of the props that came with mine were out of balance. I never tried them until I balanced them. Also, I prefer the collet adapters because there is almost no chance they can cause a problem. I only had one grub screw type PA and it kept coming loose. So, I finally put lock-tite in the grub screw and it is still on the same motor. BTW - mine is still as stock as when it came out of the box and is flying great. It is the first plane that I put in my car when I go flying. I hope you get yours sorted out because I am sure you will love it.
AJ
Old Jul 19, 2009, 03:36 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Prop Balancer
Just in case you don't have one, I have tried 5 different balancers and THIS is the one that I like the best (by far). The price happens to be good too.
AJ
Old Jul 19, 2009, 04:55 PM
metRo_ is offline
Find More Posts by metRo_
Joined Jul 2009
Had someone bought the plane here http://www.rc-model.cn/Plane.htm ? Can i trust in that?
metRo_ is offline Find More Posts by metRo_
Old Jul 19, 2009, 11:27 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Yes. However, that is the distributor. You have to buy in quantity from them (Like 20 or more as I recall).
AJ
Old Jul 21, 2009, 02:59 AM
AD. is offline
AD.
AD.
AD.'s Avatar
London, UK
Joined Jul 2009
I thought other people had bought only one off here. I would like to purchase two so I sent them an email on Sunday but no reply yet.
Old Jul 21, 2009, 07:35 PM
JW0847 is offline
Find More Posts by JW0847
JW0847's Avatar
Maumee OH
Joined Apr 2009
Check out PW-RC
If you want a little more control over the electronics - putting in your own servos, receiver and ESC. You may want to consider PW-RC. Phillip does a good job repackaging at no additional cost to reduce the shipping box size - to reduce the cost. The savings in the shipping would pay for the class of servo used in the HC version so it comes out a wash. The advantage is if you prefer your servos.
Check it out: http://www.pw-rc.com/product_info.ph...nnh0gau0ua5n53
I am thinking about buying another one - since pilot error caused a couple hard nose "landings" and worst case I can move my electronics to the new plane.
John
JW0847 is offline Find More Posts by JW0847
Old Jul 22, 2009, 11:18 PM
RCULONE is offline
Find More Posts by RCULONE
France, Picardie, Pont-Sainte-Maxence
Joined Jun 2008
Yes i bought one directly but they only accept china to china for one piece
68$ plane , servo , esc , motor and postage to china.
RCULONE is offline Find More Posts by RCULONE
