Old May 27, 2011, 12:31 PM
RedStarArmy is offline
Find More Posts by RedStarArmy
RedStarArmy's Avatar
United States, NJ, Middlesex
Joined Feb 2008
For the y harness, there are premade cutouts where the wings come together that is just big enough to fit in the connectors there.
For the esc, I have mine velcroed behind the servos, in the fuse.
The rx I have on the side, where the servos are inside the fuse. It's a tight fit but works out just fine for me.
RedStarArmy is offline Find More Posts by RedStarArmy
Old May 27, 2011, 04:24 PM
Firepower is online now
Find More Posts by Firepower
Firepower
Firepower's Avatar
North Brisbane, Australia
Joined Mar 2010
Originally Posted by Vitamin_J View Post
I agree, I hate FPVing when all you can see is the sky. My cameras are usually pointed at a pretty good angle too, when I hold it level only about 1/3 of the screen is sky.
Here you go:
http://www.youtube.com/watch?v=GMiA2tCurl4
Check out more pics and vids of FPV Floaters here:
http://www.rcgroups.com/forums/showthread.php?t=1439864
Thanks for the photo of the camera mounted in the floater. To the uninitiated it would seem easy - just point the camera down more to see more ground but you need to get the right lens, the right distance from the nose for the camera, the right height of the camera on the body of the plane for the distance from the nose etc etc.
I had a small 1 gram camera on the front of the motor pod but it was too far back. Anyway thanks again and for that link with some different options.
Good latest video also.
Firepower is online now Find More Posts by Firepower
Old May 28, 2011, 10:41 AM
04rdking is offline
Find More Posts by 04rdking
United States, TX
Joined May 2011
Not on mine.......
I made the cut in the fuse bigger and was able to pull the connectors thru. I did a bit of surgery on the belly. I cut a piece out of the belly of the fuse. Mounted the ESC behind the servos and glued and taped the belly back together. Have the receiver mounted just fore of the servos. Used a prop adapter to mount the prop. With a 2200mA Lipo, CG is right in the middle of the spar. Just waiting for a calm day for maiden flight........
I may get a 'hatch' like the one used on the Radian and modify the belly so I can have better acces to things.
04rdking is offline Find More Posts by 04rdking
Old May 28, 2011, 12:48 PM
TopSpin is offline
Find More Posts by TopSpin
Leesburg, VA
Joined Jul 2005
Originally Posted by 04rdking View Post
Still don't have the connectors, but am trying to get everything else ready. I have searched this thread many times. Where do most peeps put the ESC and the RX? Also, what do you do with that Y-cable? I've put velcro on the wings, but I can tell they don't fit properly because of the connectors for the Y-cable.
The ESC is the stock Aoxan 25A and the Rx is a AR600. And how do you fasten them so thet aren't flopping around?
The 2200 Zippy's seem to fit fine. Nice and snug.
RedStarArmy has a good solution for where to put the ESC. Also, an easy way to get the Y cable into the plane is to use a small amout of thread or fishing line. Run it down through the slot in the fuse before you mount the wings. Pull it out the front, put a loop around the RX connector on the Y harness and pull it through. Works pretty easy for those tight spaces.
Pull each Y connector out the channel as you fit each side of the wing in place, save the ro covers for last. I used GWS glue to put the whole thing together and it's rock solid.
TopSpin is offline Find More Posts by TopSpin
Reply With Quote  (Disabled)
Old May 28, 2011, 01:25 PM
TopSpin is offline
Leesburg, VA
Joined Jul 2005
I like it Firepower. I might try that again one of these days. I built an FPV Slow Stick about 5 years ago. It was a blast flying beyond visual but not as easy people might think.
I still have all of my camera and transmitter/receiver stuff so I just might get it out.
I use a 2.4 GHZ system and have a 1 watt transmitter. I also use 4, 10 element yagi antennas on the receiver, with 45 degree diversity on two of them, that reduces fading when the airplanes attitude changes. We also included GPS overlay in the video window.
The picture is just camera and transmitter but there is a seperate battery/power supply board and also a GPS receiver. All of this is in a small plastic housing.
Old May 29, 2011, 12:22 AM
Firepower
Firepower's Avatar
Joined Mar 2010
The picture is just camera and transmitter but there is a separate battery/power supply board and also a GPS receiver. All of this is in a small plastic housing.
Yeh - have another go with it. A while back I bought a new slowstick off someone for $20 but sold it to my mate for the same price.
After I sold it I saw a lot of people put FPV stuff on slowsticks and it probably would have been good for me to start with as it flies slow and gives you a bit more time to react.
Good stuff. Dig out the antennas again.
Old May 29, 2011, 10:45 AM
metRo_ is offline
Find More Posts by metRo_
Joined Jul 2009
i'm buying the parts for my axn floater. i already have bought the batteries(ZIPPY Flightmax 2200mAh 3S1P 20C), servos and ESC. Now i'll buy the battery charger, i saw that two in hobbyking:
http://www.hobbyking.com/hobbyking/s...idProduct=7523
http://www.hobbyking.com/hobbyking/s...dProduct=11444
If you have experience with this i want to know what you advise.
(sorry my english)
metRo_ is offline Find More Posts by metRo_
Old May 29, 2011, 10:53 AM
victapilot is offline
Find More Posts by victapilot
Just thumbing through...
victapilot's Avatar
United States, SC, Simpsonville
Joined Feb 2009
(sorry my english)
They are both good. I have a similar one that has built in AC power supply. You will need to draw power to the charger from a power supply or a car battery
victapilot is offline Find More Posts by victapilot
Old May 29, 2011, 10:56 AM
metRo_ is offline
Joined Jul 2009
i'll use a power source from PC
Old May 29, 2011, 12:25 PM
victapilot's Avatar
Joined Feb 2009
Originally Posted by metro_ View Post
i'll use a power source from pc
a1+
Old May 29, 2011, 05:10 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Charger
(sorry my english)
The most bang for the buck IMO is this one:
http://www.hobbyking.com/hobbyking/s...idProduct=7028
AJ
ajbaker is offline Find More Posts by ajbaker
Old May 29, 2011, 05:40 PM
metRo_ is offline
Joined Jul 2009
AJ
Have you already tested it? or knows someone tested?
Thanks for your opinion
Old May 29, 2011, 05:58 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Yes. I have tested it extensively. I am sure I have charged over 500 LiPos on the ones shown. I generally use 7-8 LiPo's on a flying day - which is about 5-6 days a week (weather permitting) Buy it. You will love it. I think you are already going to use a computer power supply.
AJ
Old May 29, 2011, 06:36 PM
metRo_ is offline
Joined Jul 2009
I bought this bateries http://www.hobbyking.com/hobbyking/s...idProduct=6306 should i buy any connectors when buy the charger?
Old May 29, 2011, 07:27 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Nope. But, it would be a good idea to have a handful of THESE on hand for future use as required.
Oh. If you are going to stay in the hobby for a while, THIS is a MUST have item.
AJ
