West Texas USA
Joined Mar 2008
Floater ESC failure.
BTW: I think it will be hard to avoid putting China made components into a build. I buy nearly all my components from Hobby King in Hong Kong and have very good luck with them, mostly the Turnigy brand. |
West Texas USA
Joined Mar 2008
6x5E
BTW: After about 60 flights I was forced to replace the servos as two of them had failed or were near failure. |
The RCtimer and TGS packages look the same except the instruction sheet is printed on different color paper. The 6x4's are probably going to be plenty on the 2200kv motor if I ever get around to installing it. I like that the Emax motor uses the stock hole locations, but I had to drill them bigger anyway because I had to go out and buy some #4 bolts as the stock ones were too small, the heads slipped through the Emax's pre-drilled firewall mount. I'm going to stick with the slower motor for now and try to get some level flight and some video, it's probably going to be much easier on battery life too. I put a longer arm on my rudder servo so it has a ridiculous amount of throw now, have to try to get away from using the ailerons with the camera. I'm not sure what the plane comes with for servos from HK, mine had Emax servos and they are working pretty well but I do have a couple HXT900s ready if I need them. This is the first time the plane didn't come home wrecked so it's not like it has a lot of flights on it, going to a big open place with grass this weekend so that should be a hell of a lot less stressful
West Texas USA
Joined Mar 2008
CF failed ESC
If I get another CF it will probably be without any of the electric components installed, including the motor if possible. Thanks for the prop feedback. |
Melbourne, Australia
Joined Mar 2009
I know its 3.17mm, but I've used it on 3.0mm shafts and its gripped fine... I've tried all of hobbykings collet adaptors and they are either really heavy, poorly balanced and the washers have an I.D much wider than the threaded shaft! this collet is the lightest ive ever used too, around 3-4g |
Thessaloniki, Greece
Joined Feb 2010
So i prepared my self for landing... these last 2 minutes were like HELL. I almost had no control of the plane but landed very good (Damn lucker!!! ). Now i'm waiting my new ESC a Turnigy 25A.
Hot ESC
I cut the wrapper and make square hole to let the air cool the heat sink. And also I placed the ESC outside since maiden flight. No problem so far. Becareful if you cut the wrapper, it also hold the heat sink in place, so you might want to tighten it with something. |
Mine was just the type with the postage stamp sized heat sink, and the motor was a little jittery to start up even before I got it wet and was hit or miss if it would arm properly at startup. Seemed like the timing was wrong and I would have to power cycle it. I thought that was normal but the tower pro I have now works great every time.
The Netherlands, LI, Venray
Joined Dec 2008
