Thessaloniki, Greece
Joined Feb 2010
I really start worrying now guys. I heard a lot about this plane, everybody saying that they coocked motors, ESC, and a new prop is needed.
I also blown an ESC and ordered a new one at 25A and a 6x4 Prop. Is that enough to make this bird flying ok?? It's just some people also saying that a 30A ESC is needed and the Stock motor get's too hot very easy. Maybe the 6x4 prop will do a nice job? Any help appreciated!!
West Texas USA
Joined Mar 2008
Motor
The BEC section of the ESC might actually be your problem. Keep reading the thread(s) and stay tuned. |
Had a bad experience when flying today - my prop-saver rubber-ring was too soft, and I made the stupid mistake of using a normal rubberband pulled around several times. Ended up with the propeller almost cutting the tail off the plane - it actually chopped out a good piece of foam...
The good part is that I got the plane down safely - and didn't lose the propeller. Of course my original spare rubber-band was at home, but have added it now. Does anybody know if these ones from HobbyKing can be used for our plane: http://www.hobbycity.com/hobbycity/s...idProduct=8234 |
West Texas USA
Joined Mar 2008
rubber ring
AJ |
Melbourne, Australia
Joined Mar 2009
Its a monster that can shoot straight up vertical till you can hardly see it from a hand launch. Its still not a 5" pitch, as the stock TGS 5x5E looks & measures steeper... but its probably more pitch than a powered glider will ever need.But I'm taking my suppo 2212-06 off the CF and putting it onto a 28" Skyray depron parkjet I'm building, and gonna give a TowerPro 2409-12 a try with a 'APC-style' 7x6E prop. Did a little bench testing with a Turnigy 2409-12 and 7x6E, but its a pretty cheap-ass motor.... rear bearing is seriously small, and the bell fell apart when I tried to change the shaft for a non threaded item. While it was working it pulled 22-23A and got very hot from the rear bearing. Either of the two TowerPro motors should be able to take that. Ordering one of each
Will it take a 7" prop without chopping itself in half? |
Joined Mar 2009
Joined Mar 2009
I think you could fit a 8" prop if you really wanted to, I've got some shims (errr, folded up cardboard) under the bottom of the motor mount to get the thrust line closer to the CoG anyway, and she flys a lot nicer for it.
Joined Jul 2007
Not sure if this already been noted, but the OKHOBBY 5x5 prop appears to be the same as the ones supplied with the CF.
It looks identical except it doesn't have EMP stamped in it, nor the EMP logo. The adapter rings appear to be the same, including none that fit the CF motor shaft. However, the printed paper in the packaging says they are for 2, 3, 3.175, 4, 5, and 6mm shafts. Of all the sizes, the only one that measures correctly is the 5mm one. |
The Netherlands, LI, Venray
Joined Dec 2008
i use 3 of them on the propsaver |
Joined Feb 2010
And even if i had a 50A esc, if the plane doesn't have enough air intake to cool the electronics the 50A esc will be coocked too? Because i live in Greece and we have a very hot climate here. |
