Old Dec 22, 2009, 03:14 PM
GENE's Fantasy Woman
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Originally Posted by smaerd58 View Post
Well if it doesn't rain it snows here I am grounded because we got 24 inches of snow here in Delaware....
That sure looks like a bunch of layers of fiberglass insulation that someone left laying on your deck.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Dec 22, 2009, 05:18 PM
Sydney
Joined Aug 2009
Originally Posted by ajbaker View Post
I have not had that problem with my CF. But, rehinging the elevator would be a good way to maybe resolve your problem. For me, I would use THESE hinges (2 on each side of elevator). But, I am sure there are many that would work. This is one of those situations that has a lot of "right" answers.
AJ
Hmm.. never seen thoes before. Looks like a great idea! thanks
Impy is offline Find More Posts by Impy
Old Dec 22, 2009, 06:55 PM
Warsaw's Avatar
Iowa
Joined Jan 2006
I used some cheap clear packing tape to hinge mine. The cheaper the better, as the cheap stuff seems to be thinner and more flexible. I didn't fly before re-hinging everything. The ailerons were so stiff I was afraid it would strip the servo gears.
Warsaw is offline Find More Posts by Warsaw
Old Dec 22, 2009, 08:55 PM
Good Better Best quest.
olmod's Avatar
Australia, VIC, Cranbourne East
Joined Apr 2004
I used a fine hacksaw blade cut down from a broken one to clear away most of the hinge line but used live hinges on rudder,
I really liked those horns and have asked if they can be stocked seperately.
olmod is offline Find More Posts by olmod
Latest blog entry: For motor builders
Old Dec 22, 2009, 11:23 PM
FE Finatic
smaerd58's Avatar
Delaware
Joined Jan 2004
AJ
Wish it was...Would be a lot easier to remove. MY BACK IS SCREAMING TODAY
This thread is getting longggggggggg. I wonder if we can get some stickies for things such as. Replacement parts. Motors,ESC,SERVO'S,HOP-UPS,REPAIR TIPS, ETC.?
smaerd58 is offline Find More Posts by smaerd58
Old Dec 22, 2009, 11:32 PM
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
This thread is simple to keep up compared to THIS one that I am active in also. There is some talk of stickies there, too. That thread REALLY needs them.
AJ
Old Dec 23, 2009, 12:04 AM
FE Finatic
smaerd58's Avatar
Delaware
Joined Jan 2004
AJ
Wow 874 I retract.....
Old Dec 23, 2009, 12:31 AM
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Cf
Hey Guys -
30 Cloudys in stock at HK. Hurry like H**L, if you want one. They will probably be gone by 8am PST.
AJ
United States, CA, Redondo Beach
Joined Mar 2005
they're instock at hobbycity, i just ordered mine, plus a few other things to fill the rest of my left over.
jrod155 is offline Find More Posts by jrod155
Old Dec 23, 2009, 10:03 AM
Cubber1's Avatar
Norway, Hordaland, Årstad
Joined May 2009
Yes, there my backorder came through - and another hobbyking plane on its way to me...
Cubber1 is offline Find More Posts by Cubber1
Old Dec 23, 2009, 05:17 PM
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
CF in stock - briefly
Only 4 Cloudys left. Better grab one now.
AJ
Old Dec 23, 2009, 07:20 PM
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
CF's - maybe another day
Poof - Gone
AJ
Old Dec 25, 2009, 09:24 PM
eyeinsky1's Avatar
Halifax NS Canada
Joined Apr 2009
Any Interest in some AP/AV mods
More detail here:http://www.rcgroups.com/forums/showthread.php?t=1155737
Cloud AP/AV II (2 min 3 sec)
Test Flight 25 mph wind (4 min 31 sec)
Raw video fixed wing AP/AV (6 min 57 sec)
eyeinsky1 is offline Find More Posts by eyeinsky1
Old Dec 26, 2009, 06:37 PM
eyeinsky1's Avatar
Halifax NS Canada
Joined Apr 2009
Question to all you AKA floater jet guys
What is with the wing drop that this aircraft does turning in or out of the wind? I know this is a stall of sorts but it sure is unpredictable. Has anyone made any mods to minimize this? I have installed gyros in the pitch and the roll and it does help, but it still experiences as occasional wing drop.
Could it be from the winglets?
Today I did two mods;
-added a 1/2 inch to the elevator
-cut some foam to fit under the leading edge of the wing. This gives the leading edge a droop profile.
Test flight was great, I like it I think it helped but not to much wind today. The leading work improved the low speed and definatly did not run out of elevator. I will try take some video next time. Here are some pics:
I have marked the video section that the wing drops
Old Dec 26, 2009, 07:53 PM
Joined Oct 2009
Are you looking for float plans for the Easy Star, the CF or both? Do you own both planes?
AJ
No I only have the CF. But this is the only example of a seaplane conversion that I have come across.
Are there planes or a build thread of how the CF could be converted to be a seaplane somewhere?
Thanks in advance.
NL_Expatriate is offline Find More Posts by NL_Expatriate
