Old Dec 18, 2009, 12:50 AM
beautox is offline
Find More Posts by beautox
Joined Apr 2009
Further examination of the H40A ESC shows that it uses TWO LM317T voltage regulators to implement the BEC. These are 1.5A devices, and as they are connected in parallel, the total BEC current available is not 2A as stated in the user manual, or 1.5A as stated on the HobbyCity site, but 3A
It's quite amazing that this ESC sells itself short! Not only can it deliver more motor amps that it's rating, but the BEC is over-specified as well. I guess it's down to it's larger size and thus there was less need to miniaturize as much.
The LM317Ts are connected across the incoming power supply, and apart from the supporting circuitry shown in the datasheet linked above, that's all there is to the BEC.
LM317T regulators are fully protected against over current and thermal protection.
Quite how a stalled HXT90 could "overload" a pair of LM317T is beyond me. Maybe the battery was no good and could not provide enough voltage to power the receiver / servo tester being used.
beautox is offline Find More Posts by beautox
Old Dec 18, 2009, 12:52 AM
beautox is offline
Joined Apr 2009
AJBAKER : what I see is that you repeatedly make statements that you cannot back up, and when you are called on them, resort to attacking my credentials rather than my arguments.
So I repeat : what is bad about the design. Or was that just a guess?
Oh, and the reason it's not off topic is that you are suggesting solutions to a problem that are wrong.
(And reporting my postings to a moderator doesn't change anything. Hiding behind a moderator is a feeble ploy. )
Old Dec 18, 2009, 03:05 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
First, I suggest learn how to play well with others. This topic is closed.
Meanwhile, back to the thread. Has anyone used gyros on this yet? I have had one on the pitch since it was maidened. Now, that I have many flights on it, I am wondering if it has any value. For several of my planes, a gyro is unnecessary. But, Like is cousin, the Wild Hawk - on that one it is needed IMO.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Dec 18, 2009, 03:39 AM
beautox is offline
Joined Apr 2009
Launching the CF does require quick reactions as it tends to pitch down under full power.
A gyro would be helpful for beginners. Or for anyone who lacks confidence in their flying abilities.
Old Dec 18, 2009, 03:56 AM
jaccies is offline
Find More Posts by jaccies
The Netherlands, LI, Venray
Joined Dec 2008
Talk about not wanting to admit you're wrong...
You see, the "problem" has already been fixed. By setting HIGH timing (as it was clearly a timing problem).
Given that, when I initially tested this, there were no servos connected, how on earth do you reckon that the BEC is failing? Amazing.
By the way, I've been flying the plane successfully now for a few weeks.
There is an issue beautox, why do 98% have no problem , we heard sofar in this thread that only you and lonzar had this issue.
A lot of people who bought the CF assembled it and fly with it, without having the knowledge how to program the ESC so using low timing.
jaccies is offline Find More Posts by jaccies
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Gyros
I need to be clear in my question. Has anyone used a pitch or roll gyro on a CF airplane? I am looking for feedback on their experience.
AJ
Old Dec 18, 2009, 03:58 AM
beautox is offline
Joined Apr 2009
jaccies: I'm using a non standard ESC and motor (as I have explained in several posts). I would guess that the stock ESC and motor work fine together.
Old Dec 18, 2009, 04:01 AM
jaccies is offline
Joined Dec 2008
or use up-thrust
Old Dec 18, 2009, 04:13 AM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
Originally Posted by jaccies View Post
or use up-thrust
I have added 2 deg and it made very little difference to the nose down power launch,
but a local has used an undercarriage with great success.
olmod is offline Find More Posts by olmod
Old Dec 18, 2009, 04:42 AM
jaccies is offline
Joined Dec 2008
Right, my Watt meter arrived today and I performed some tests. Using a 4.75x4.75 prop, on high timing at max throttle it was drawing 24.1A at 11.4V, which makes 274W
On low timing the point where the motor cuts out (roughly half throttle) when the throttle is opened fast is somewhere between 6.3A and 9.1A (V=12.1)
So you can see that a 40A (50A burst) ESC is nowhere near overloaded.
On a related note, has anyone measured the Watts that a stock motor consumes at full throttle?
see post, it is 230Watt
Old Dec 18, 2009, 04:44 AM
jaccies is offline
Joined Dec 2008
I added 2 shims of 1,5 mm thick at the above 2 screws, and it helped a lot
what is an undercarriage , any pictures??
Old Dec 18, 2009, 04:51 AM
beautox is offline
Joined Apr 2009
230W - that's with the stock prop I suppose? Is that 5x5?
Old Dec 18, 2009, 05:01 AM
jaccies is offline
Joined Dec 2008
yes correct 5x5
Old Dec 18, 2009, 06:57 AM
pghern is offline
Find More Posts by pghern
Crashing in Melbourne
Australia, VIC, Rowville
Joined Jan 2009
AJ
I have a gyro on pitch - makes for very stable flight.
I still had issues with hand launching - my reaction either not quick enough or over compensated.
Once I fitted the undercarriage - a single glider wheel in my case - launching has been a breeze. This has meant that I can keep both hands on the controls and don't fumble.
pghern is offline Find More Posts by pghern
Old Dec 18, 2009, 07:05 AM
olmod is offline
olmod's Avatar
Joined Apr 2004
Ill get some pix sunday if the weather is ok.
