Old Dec 22, 2008, 01:27 PM
kansascloud is offline
Find More Posts by kansascloud
Checking the wind
kansascloud's Avatar
Aubry Township, Kansas South of KC.
Joined Jan 2002
Friend just GAVE me new AXI
A friend recently handed me a brand new AXi 2212/34 motor!
Not knowing much about brushless motors can someone please tell me what all those numbers mean? Also, I have a bunch of great old models that still have brushed motors in them and I'm going to convert some of these. What size airplane would this motor be appropriate for? What prop?
I have a beautiful Mountain Models Dandy Sport from several years back. Looks like this motor might fit under the cowel? What do you think?
kansascloud is offline Find More Posts by kansascloud
Old Dec 22, 2008, 04:00 PM
Pete Miller is offline
Find More Posts by Pete Miller
Beaumont, TX
Joined Feb 2007
Boy, I wish I could find some consistency in motor numbers!
Here are some specs for it, you just have to wade through the chinglish in the description:
http://www.icare-rc.com/modelmotors_...tm#AXI_2212/34
Pretty low KV, so it can swing a big prop, MM calls for a 10 x 8 in the Sport when using their recommended motors so, might work out OK
Let some of the experts chime in.
Pete Miller is offline Find More Posts by Pete Miller
Old Dec 22, 2008, 05:47 PM
flydiver is offline
Find More Posts by flydiver
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
There is some consistency:
22=stator diameter
12=stator width
34=winding turns. More turns, lower KV
Here's the motor spec site:
http://www.modelmotors.cz/index.php?..._EVP&line=GOLD
flydiver is offline Find More Posts by flydiver
Old Dec 23, 2008, 01:13 AM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
Yes, an AXi 2212/34 will fit in a Dandy Sport using either the Mountain Models or Stevens Aero mounts (the MM fits a bit better). Use a 3s battery and an APC 10x7 slowflyer prop. Here is a thread I started just over five years ago on exactly this combination - I call it the "silent afterburner" for the Dandy Sport and similar sized models....http://www.rcgroups.com/forums/showthread.php?t=180509
I had mine out on DuBro parkflyer skis yesterday....we have a foot of snow (kind of unusual for the Seattle area).
BEC is offline Find More Posts by BEC
Old Dec 23, 2008, 06:17 AM
Beaumont, TX
Joined Feb 2007
22=stator diameter
12=stator width
Ah Ha, my bad! I was trying to equate them to case dimensions.
Old Dec 23, 2008, 01:13 PM
BEC is offline
BEC
BEC
BEC's Avatar
Joined Jan 2001
Some motor makers do use the case dimensions - Himax for example. Many 22xx and 28xx motors are actually the same physical size and if wound similarly they have similar performance.
It's even more confusing because 28xx motors using the AXi naming system (28mm stator) are much larger. These are 35xx (or 36xx) motors if using the outer case diameter instead of the stator diameter in the name.
Discussion wow, someone just gave me a free dagonfly airpower Ornithopters 0 Jan 25, 2008 11:13 PM
Discussion Wow, someone just gave me a plane coloradoskier Micro Ready-to-Fly 8 Jan 04, 2008 01:23 AM
Discussion New to Fans , Santa gave me an F86 ! Duke58 Foamy EDFs 5 Jan 08, 2007 02:27 PM
Just Got My New T-rex Brushless It Really Scared Me To Death !!! agapornis Mini Helis 22 Dec 15, 2005 05:53 PM
Friend gave me a Charger but..... radcast2 Batteries and Chargers 3 Nov 25, 2004 09:31 AM
