Dec 21, 2008, 12:50 PM
Swansea, Illinois
Joined Nov 2007
E-Flite J-3 Cub 25 ARF (new in box)
E-Flite J-3 Cub 25 ARF for sale, New in box !! Perfect Condition ! Retails for $199
Santa messsed up, my loss is your gain
My price is $165 with free shipping in CONUS
Paypal required, PM if interested
Key Features:
Outstanding scale detail, including the factory-painted fiberglass cowl with molded engine detail
Scale aileron design sets the E-flite® J-3 Cub apart from other 25-size electric Cubs on the market
E-flite's optional 25-size floats are easy to assemble and attach to the J-3 Cub, and offer thrilling performance during water taxi and takeoff
Built-in float mounts
Removable one-piece wing for fast transition to the flying field
Factory-painted landing gear with authentic Cub wheel caps
Quality balsa and light plywood construction, and genuine UltraCote® covering
Outrunner-ready firewall—perfect match for E-flite’s Power 25 Outrunner, 870Kv
Flies great with Li-Po or Ni-MH packs
Overview
This is the only 25-size Cub with scale ailerons. Quality balsa and light plywood construction make for a sturdy, lightweight airframe that handles incredibly well in most flying situations. The firewall is set up for use with an outrunner motor, such as E-flite’s Power 25, making a perfect power match for the airframe. Optional floats add a new dimension to the scale flying experience, and the one-piece wing allows for easy transportation to and from virtually any flying field, pond or lake.
Specs:
Wingspan:62 in (1575mm)
Overall Length:35.5 in (900mm)
Wing Area:550 sq in (35.5 sq dm)
Flying Weight:4.0–4.25 lb (1.8–1.9 kg) with Ni-MH battery pack
Motor Size:Recommended: E-flite Power 25 Outrunner (not included)
Radio:Minimum Required: 4 channels (not included)
Servos:Required: 4 mini servos (not included); Recommended: 4 JR SPORT MN48
CG (center of gravity):2-5/8 in (66mm) from leading edge
Prop Size:12 x 6E
Hardware Included:Y
Speed Control :Required: 40-amp brushless; Recommended: E-flite 40A Brushless
Recommended Battery:E-flite 10-cell 12V 1800mAh Ni-MH, or 3/4-cell 3200-4200mAh Li-Po (not included)
Flaps:None,
Retracts:None,
Approx. Flying Duration:8–10 minutes on Ni-MH and 15–18 minutes on Li-Po,
Needed to Complete to fly this plane, you will need:
Radio System: 4 channels or more,
Motor: Power 25 Outrunner,
ESC: 40A Brushless ESC or larger,
Battery: 10-cell 12.0V 1800mAh Ni-MH, or 3-cell, 4 cell Li-Po (3200-4200mah),
Servos: 4 JR-MN48 or Hitec HS-225, or similiar size servos
Reason: typo
