Old Dec 20, 2008, 10:02 PM
NX-687 is offline
Find More Posts by NX-687
Joined Aug 2007
Help on Mills Diesel Assembly
Hi
I have the Mills 0.75 cc Indian version , my question is does the cutaway on the piston top go to the back or the front ??????
next question,,,, Do the large transfer port holes go towards the back of the engine or the front , thanks so much
NX-687 is offline Find More Posts by NX-687
Old Dec 20, 2008, 10:05 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
I don't have a Mills, but in general the piston is cut away to clear the crank, so the cut away normally goes to the front.
As far as the transfer holes, the taller one is the exhaust. The exhaust is always open longer than the transfer ports.
Hope that helps,
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Dec 22, 2008, 02:46 PM
Bill Adair is offline
Find More Posts by Bill Adair
Beaverton, OR
Joined Jan 2005
NX,
Just pulled the head and liner from my Russian Mills 75 replica to check.
The piston top cutout goes to the front on mine.
The cylinder exhaust ports are rectangular, and go left and right.
The two large round ports are slightly lower on the liner, and line up with the carb venturi at the rear, the two smaller round ports are to the front.
My cylinder liner has a slot in front that engages a small steel pin at the front of the case. The pin is not pressed into the case, and can easily fall out, so you may have lost yours. Should be easy to cut and fit a new one, but be sure it's not too long, or the head may rest on the pin, and not seat properly.
Hope this helps,
Bill
Bill Adair is offline Find More Posts by Bill Adair
Help on Ark X400 Tail Rotor Assembly Jovsdapogi Mini Helis 19 Nov 14, 2005 11:37 AM
Help on building littlest stick, upsized for 060 diesel t3dIIEr 1/2A Planes 3 Dec 06, 2004 06:38 PM
Question Assembly & CD Help on Wind Dragon (Rookie) Dynofly Beginner Training Area (Aircraft-Electric) 13 Sep 17, 2004 12:35 AM
Need help on buying new Battery! AirVenture Electric Plane Talk 7 Jul 10, 2001 09:03 PM
Help On The Extra 330L CXT Electric Plane Talk 1 Jun 01, 2001 07:50 PM
