Old Dec 20, 2008, 08:18 AM
89 yotta is offline
Find More Posts by 89 yotta
I Am Canadian
Joined Dec 2008
Help!
tricycle landing gear or tail dragger Telemaster 40
Hey guys what are the pros and cons to tricycle landing gear or tail dragger?
I have a telemaster 40 kit and it can be set up either way what does everyone recomend?
Graham
89 yotta is offline Find More Posts by 89 yotta
Old Dec 20, 2008, 09:17 AM
GunnyGlow is offline
Find More Posts by GunnyGlow
piro-maniac........
GunnyGlow's Avatar
United States, CO, Aurora
Joined Dec 2007
I recommend both ways.....
GunnyGlow is offline Find More Posts by GunnyGlow
Old Dec 20, 2008, 11:06 AM
littlewing78 is offline
Find More Posts by littlewing78
I meant to do that
littlewing78's Avatar
Eagle Mountain, Utah
Joined Jul 2004
Try the tricycle gear first. Both have different benefits, but the nose gear will help save props while you are learning. You can always change it later if you want.
littlewing78 is offline Find More Posts by littlewing78
Old Dec 21, 2008, 09:59 PM
jim_ag3y is offline
Find More Posts by jim_ag3y
Hagerstown, MD
Being that this is the beginner's forum, I would recommend going with the tricycle gear, at least first of all, as well.
Ground handling is tricky enough with a tricycle. Believe me, that has been the hardest part of learning to fly for me, and I have broken enough wooden props, and stalled enough engines by digging the prop tip into the ground, even with the trike setup, to know what I am saying !
Good luck ! Merry Christmas! Jim
jim_ag3y is offline Find More Posts by jim_ag3y
Old Dec 22, 2008, 12:08 PM
T.L.A.R. eng is offline
Find More Posts by T.L.A.R. eng
T.L.A.R. eng
Joined Nov 2005
Pros for trike;
1. Good ground handling characteristics
2. good landing and take-off characteristics. Easier to land in a cross wind.
cons for trike;
1. nose gear can be bent on hard landing
pros for tail;
1. no nose gear to bend
cons for tail;
1. a little harder to steer on the ground, especially in the wind.
If you are a beginner, use the trike, it is very forgiving for the most part,just remember to land on the mains and not the nose gear.
Just my observations, I've owned them both ways and prefer the trike set-up.
T.L.A.R. eng is offline Find More Posts by T.L.A.R. eng
Old Dec 22, 2008, 02:15 PM
jim_ag3y is offline
Hagerstown, MD
T.L.A.R. , RE the cons for trike and the prose for tail, you may not bend your nose gear, but you sure can break a prop ! Especially if it is a wooden one. ( don't ask me why I know ! )
Merry Christmas. Jim
Old Dec 23, 2008, 11:08 AM
T.L.A.R. eng
Joined Nov 2005
Yup, good point! Forgot to add that one.
I have on occasion broken props landing both with and without a nose gear!
Yep, it can be done! LOL!
Old Dec 24, 2008, 11:38 AM
T.L.A.R. eng
Joined Nov 2005
Found an old Polaroid that brings back some good memories with my Telemaster 40.
Saito Gold Knight .50, Futaba 6 channel, optional flaps on the 5th channel and a home made snap-roll swith modification to the Tx.
Made for a very fun airplane for fun fly's or just relaxing puttering around.
Old Dec 24, 2008, 08:55 PM
89 yotta is offline
I Am Canadian
Joined Dec 2008
Nice lookin telemaster Thanks for sharing
Merry Christmas
Graham
Old Dec 25, 2008, 06:36 AM
jumpinjo is offline
Find More Posts by jumpinjo
Low, slow and dirty
maine
I prefer nosewheel and don't mind the maintenence that goes with it. I'm using a senior telemaster to learn as a taildragger. I'ts long fuselarge lenght helps with stabillity,when learning. I learned this lesson the hard way after wrecking a goldberg cub on take-off. I have another one that I made into a nosewheel type. It handles and flies very well. It also looks pretty cool.
jumpinjo is offline Find More Posts by jumpinjo
Old Dec 25, 2008, 06:21 PM
Murocflyer is offline
Find More Posts by Murocflyer
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
I don't know if there is a benefit to either to be honest. It really depends on what you are used to. I've flown both and enjoyed both.
Frank
Murocflyer is offline Find More Posts by Murocflyer
Best landing gear type for Easy Star -- trike or tail dragger? JohnSoPA Foamies (Kits) 11 Aug 07, 2008 10:15 PM
Discussion V-tail and Tricycle Landing Gear? hmedina Radios 3 Jan 11, 2006 01:43 PM
My GWS e-starter with tricycle landing gear pc_pilot Parkflyers 10 Mar 19, 2003 11:49 PM
GWS P51 Landing Gear or none??? flipnidaho Parkflyers 5 Jan 31, 2003 09:33 AM
Tricycle Landing Gear Construction Talon Driver Modeling Science 15 Dec 16, 2002 08:00 AM
