Go Back   RC Groups > Aircraft - General > Radios
Old Dec 20, 2008, 06:26 AM   #1
Site Sponsor
supi7's Avatar
Send a message via MSN to supi7 Send a message via Skype™ to supi7
Converting Skysport 6 to 2.4Ghz
Just got in the DIY Assan modules, and I got an itch to convert my old dusty Futaba Skysport 6.
First I removed 4 screws on the back cover, and removed the 72Mzh crystal and original Aerial.
I located the +, - and Signal connection on the Trainer Plug PCB
  • Name: FUT_SKYSPORT6a.JPG
supi7 is offline Find More Posts by supi7   Reply With Quote
Old Dec 20, 2008, 06:30 AM   #2
Site Sponsor
supi7's Avatar
Next I soldered in the wires, on the back side of the Trainer Plug PCB,
You can solder the wires to any of the 2 points shown, keep it clean.
  • Name: FUT_SKYSPORT6b.JPG
Old Dec 20, 2008, 06:33 AM   #3
Site Sponsor
supi7's Avatar
The Assan DIY 2.4GHz module fits snugly in between the sticks.under the Trainer Plug PCB. (PCB is not shown in this picture)
There are a few pointy wire guides that need to be broken off for the Module to fit
  • Name: FUT_SKYSPORT6c.JPG
Old Dec 20, 2008, 06:41 AM   #4
Site Sponsor
supi7's Avatar
The new "Shorty" aerial that comes with the DIY kit, fits perfectly in place of the old aerail, simply tighten the nuts down on both sides of the plastic case. and screw in the new short Aerial.
Once this is done, place the Trainer Plug PCB back in it's original spot.
some moving around of wires may be needed to get it to stay. It all should fit perfect without compressing on any other component.
If you are particular about the indicator light, you may want to rewire its position to the outside of the radio. I left mine alone, but I will drill a small hole in the case to see it, when I am binding new RX's. Its not needed though since the module will sound a destinctive tones duing this procedure anyway.
UPDATE: I CAN SEE THE LIGHT THROUGH THE TRIM SLIDERS, NO NEED TO DRILL.
  • Name: FUT_SKYSPORT6d.JPG
Old Dec 20, 2008, 07:01 AM   #5
Site Sponsor
supi7's Avatar
Here you see a finished 2.4Ghz SKYSPORT 6 with a 3ch RX, complete for $100 and 20 minutes of labor.
($100 covers the module, new Areial and a 3ch or 6ch RX)
  • Name: FUT_SKYSPORT6e.jpg
Old Dec 20, 2008, 10:51 PM   #6
early retired & loving it
Send a message via Yahoo to bnrusso
Looks good Dan!!
Thanks for showing how you did it.
bnrusso is offline Find More Posts by bnrusso   Reply With Quote
Old Dec 23, 2008, 10:24 AM   #7
Site Sponsor
supi7's Avatar
no problem, I think the same can be done for many other radios, as long as there is enough room to mount the 12mm x 32mm x 55mm 2.4Ghz RF module inside
Dan
Old Mar 25, 2009, 05:27 PM   #8
Hi, I've seen you transformation to your ff6, and I wonder if you are satisfied with the 8XD Module, i.e. does is offer full range? have you done any test?
Any lockouts so far?
How do you managed to stop the 72Mhz(or 35mhz) RF from transmitting, just removed the crystal? is that enough? does it stop the RF from power consuming?
I want to make myself the same upgrade but keeping the the old RF module available for any time I want to change. and if removing the crystal is the only solution the is Ok for me.
Best Regards,
RC_Flyer is offline Find More Posts by RC_Flyer   Reply With Quote
Old Oct 07, 2009, 11:41 PM   #9
Site Sponsor
supi7's Avatar
Sorry for slow reply, I dont visit this thread often.
I have Zero problems with this radio, most recently it was used with a small Helicopter without any issues.
All you have to do is remove the crystal to stop 72Mhz, I have also seen some people instal a switch, to turn off/on 72Mhz and use it again later with their 72MHz RX's
Old Dec 16, 2009, 12:34 PM   #10
Hello,
In old days I was said that the transmitter should not be turned on without extended aerial.
Otherwise the energy generated by RF module would not dissipate and overheat some electronic component on it.
Does anybody know if removing the cristal would prevent enengy consumption / overheat?
SUPI7:
How would you install a switch on this radio to turn off the RF?
Regards,
Mariano is offline Find More Posts by Mariano   Reply With Quote
Old Dec 16, 2009, 07:39 PM   #11
Nice work.........would this work with a Futaba 6DA?
What brand receivers work with this setup.
zero2444 is offline Find More Posts by zero2444   Reply With Quote
Old Dec 17, 2009, 07:19 PM   #12
Helis and Fixed Wing
Originally Posted by Mariano View Post
Hello,
SUPI7:
Regards,
Removing the crystal stops the oscillation. That's all you need.
Daedalus66 is offline Find More Posts by Daedalus66   Reply With Quote
For Sale Futaba 6EX 6-Channel 2.4GHz FASST TX & RX. Perfect Condition. jknust Aircraft - General - Radio Equipment (FS/W) 3 Jul 28, 2008 01:52 PM
For Sale Futaba 6EX 6-Channel 2.4GHz FASST TX & RX. Perfect Condition. jknust Aircraft - General - Radio Equipment (FS/W) 1 Jun 19, 2008 11:42 AM
For Sale Futaba 6EX 6-Channel 2.4GHz FASST Transmitter/Receiver. jknust Aircraft - General - Radio Equipment (FS/W) 3 Apr 15, 2008 10:17 PM
For Sale FS: Futaba 6EX 6-Channel 2.4GHz Transmitter/Receiver/Servos pbx Aircraft - General - Radio Equipment (FS/W) 2 Mar 20, 2008 10:37 AM
Help! Converting Walkera 53 to 2.4gHZ Trev99 Coaxial Helicopters 0 Sep 01, 2007 10:36 AM
Congratulations SimpleM!
