Old Apr 02, 2009, 09:38 AM
Mike Smart is offline
Find More Posts by Mike Smart
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
Originally Posted by takiss
190 g withought LiPo?
No 196 gms with Lipo...
Hacker A10-9L
GWS 8 x 4.3 SF prop
CC Phoenix 10 ESC
Futaba R6004FF 2.4 GHz receiver
3No 5gm servos
Evolite 350 2s lipo
Mike Smart is offline Find More Posts by Mike Smart
Old Apr 02, 2009, 01:15 PM
burb is offline
Find More Posts by burb
Burb
burb's Avatar
United States, MN, Hopkins
Joined Mar 2008
Batteries, etc
Ok
I maidened this morning with 3s 750 rhino and 12 a esc
Flew great outdoors and the motor came down just slightly warm ...
Flew for about 9 minutes
Ohhh ,,, it was only 31degrees here this morning .. maybe thats why the motor did not get hot .
In the meantime I ordered a few Rhino 2s 750 ..... so now I will have both
any other opinions
Kept moving the battery back from the stated cob and never found the threshold of pain ... will keep adjusting
anyone have a new measurment
burb is offline Find More Posts by burb
Old Apr 02, 2009, 05:43 PM
Draven is online now
Find More Posts by Draven
Fly Low Fly Fast
Draven's Avatar
United States, TX, Arlington
Joined Sep 2006
I have a spring scale and it said 184g with lipo, i just ordered a digital scale. Just to make sure.
Stock motor, 3X HXT 5 gram servos, custom 2s 610mah, 10amp Pheonix esc, removed case from receiver, and esc. used Hot Glue as my glue.
Draven is online now Find More Posts by Draven
Old Apr 02, 2009, 11:17 PM
takiss is offline
Find More Posts by takiss
Patras, Greece
Joined May 2007
I just finished my Piaget, with Futaba S3114 and Waypoint servos and Axi 2204/54 motor on 2S LiPo. i funally took out differential. 180g withought LiPo (yes I know I lost the weight prize).
It flies very well. Thanks for informing me about this plane.
Takis Katsoris
takiss is offline Find More Posts by takiss
Old Apr 02, 2009, 11:54 PM
Ducati Mechanic is online now
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
do you still have to get these from hobbycity? Do theay sell them in the states yet?
Ducati Mechanic is online now Find More Posts by Ducati Mechanic
Old Apr 03, 2009, 08:07 AM
34Ford is offline
Find More Posts by 34Ford
KF4IVP
34Ford's Avatar
North Carolina
Joined Sep 2005
This is what happens when you have multiple threads about the same dang plane.
moody152 Desire-Hobby-RC over on the other thread, sells them on Ebay here in the US.
http://www.rcgroups.com/forums/showt...=960210&page=7
______
Dennis
34Ford is offline Find More Posts by 34Ford
Old Apr 03, 2009, 07:51 PM
burb is offline
Burb
burb's Avatar
Joined Mar 2008
hobbyking motor
anyone have a suggestion on a replacement motor from hobby king ??
Old Apr 03, 2009, 07:53 PM
Fly Low Fly Fast
Draven's Avatar
Joined Sep 2006
24 gram Blue wonder motor, 1500kv
Old Apr 03, 2009, 08:25 PM
feda is offline
Find More Posts by feda
EP 3D Flyer
feda's Avatar
Hamilton, Canada
Joined Nov 2005
I am building mine with a DualSky XM2822-24, 1450RPM/V, 30 grams in weight. With a 2S battery pack, I can get up to 340-gram thrust. My AUW target for this plane is around 230 grams.
feda is offline Find More Posts by feda
Old Apr 04, 2009, 02:23 PM
oyahhh is offline
Find More Posts by oyahhh
Joined Oct 2007
Hi,
Just beginning the build process and I've gotten to step #2, glue the carbon fiber strips to the wing.
In my package I have two long carbon fiber strips. Each is the perfect length to glue to the trailing edge of the wing. Which, to me implies that that is where at least one of them should go.
Yet, from the photos I can see of other people's builds they have put at least one of the carbon fiber strips in the slit which is cut towards the rear of the wing. And not at all glued to the wing's trailing edge.
Unfortunately, neither of my long carbon fiber strips will fit in the slit which is pre-cut.
- Am I supposed to shorten the carbon fiber strip to make if fit into the slit?
- Or, am I supposed to glue the strip to the trailing edge of the wing where it is the perfect length already?
- Or, am I just missing something altogether?
Also, the two leading edges of the wing are supposed to have carbon fiber strips glued in them. That's obvious enough, but which strips again? None of the strips in my package seem to be the right length. Do I use two smaller strips per side of the leading edge of the wing?
These aircraft kits always seem to make me feel like an idiot. Maybe I should take some really detailed photos of my build so I can help the next person....
oyahhh is offline Find More Posts by oyahhh
Old Apr 04, 2009, 02:25 PM
Fly Low Fly Fast
Draven's Avatar
Joined Sep 2006
Shorten it, non of the Carbon strips and rods are to length. Except the nose strips, they fit perfectly, and the tail strip.
Old Apr 04, 2009, 08:42 PM
feda is offline
EP 3D Flyer
feda's Avatar
Hamilton, Canada
Joined Nov 2005
Originally Posted by oyahhh
Hi,
My understanding is that the 2 long strips are meant for the main wing. One is for the rear part of the wing; the other one should be cut into 2 pieces to be glued to the left leading edge and the right leading edge respectively.
Old Apr 04, 2009, 08:53 PM
oyahhh is offline
Joined Oct 2007
Thank you planelover93 and feda!
Old Apr 05, 2009, 01:22 AM
burb is offline
Burb
burb's Avatar
Joined Mar 2008
Business side shot
Here is a shot of the bottom with the rods all installed ..... wish I had one when I did mine
Old Apr 05, 2009, 02:35 PM
Joined Oct 2008
I might start selling techone planes. minimum order is 10 of one model, but theay are willing to start me at 5. I want to get a few different planes to start out with. Which are your guys favorites? besides the piaget.
