Old Mar 19, 2009, 02:22 PM
Draven is offline
Find More Posts by Draven
Fly Low Fly Fast
Draven's Avatar
United States, TX, Arlington
Joined Sep 2006
If i flew with a 350mah 2s Lipo that weighs 23g, is it enough to get the correct CG?
Draven is offline Find More Posts by Draven
Old Mar 23, 2009, 03:06 PM
takiss is online now
Find More Posts by takiss
Patras, Greece
Joined May 2007
Hi.
I just finished my Piaget, with Futaba S3114 servos and Axi 2204/54 motor on 2S LiPo. Very happy with this one and I have another one (the same!) waiting in the box.
There is one thing that bothers me, mentioned in one post, but never discussed.
There is a HUGE differential in ailerons with much more down deflection. What did you do for that?
Do you fly with such differential? If not, how did you compensate that?
Best
Takis
takiss is online now Find More Posts by takiss
Old Mar 23, 2009, 03:13 PM
rmgmag is offline
Find More Posts by rmgmag
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
I don't mind the differential. It makes rolling circles easier. If you use a round servo control horn and if you place the push rods at the top of the circle (or maybe the bottom, I don't remember), I believe you can remove most of the differential.
rmgmag is offline Find More Posts by rmgmag
Old Mar 30, 2009, 12:11 PM
burb is offline
Find More Posts by burb
Burb
burb's Avatar
United States, MN, Hopkins
Joined Mar 2008
Build question
Hey guys ...
When I buildt this I squared up the bottom fuse perfectly ( flat on the table )
then fliped over to put on the top fuse.... alot tougher to attach sq..
Now I see a slight twist to the elevator as compared to the wings ...
Can I fix this thru the carbon rods or do I have to cut off the top and reapply ??
Any ideas ???
burb is offline Find More Posts by burb
Old Mar 30, 2009, 12:49 PM
rmgmag is offline
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
Same thing happened to me. I just fly it the way it is, honestly, I don't notice it, but I'm flying outdoors in the wind, where precision flying is almost impossible with a plane this light.
Old Mar 30, 2009, 12:51 PM
BlueAngel2000 is offline
Find More Posts by BlueAngel2000
Flying like an Angel.
BlueAngel2000's Avatar
Austria
Joined Sep 2007
fix it thru the carbon rods, easier to do.
A slight twist, is not a big problem.
BlueAngel2000 is offline Find More Posts by BlueAngel2000
Old Mar 31, 2009, 11:47 PM
burb is offline
Burb
burb's Avatar
Joined Mar 2008
Build Completed
Finished the build ... straightened out the elevator just fine thru the rod placement. Had to use a stronger servo for the alerons, the s75 I installed first couldn't recenter it some times with an extra long dubro arm.
Used the HS65 with dubro ex long arm and now it is perfect...
Made up for the expensive servo by using hx900 everywhere else at $3.49 a piece. Had to cut back the throw to 80% on the alerons..
Added negative expo to the spektrum,,, thats right uisn't it ??
-60% for all controls
Will post some pictures soon and maiden next day or so.
Going to be cold and windy tommorow
Old Apr 01, 2009, 12:05 AM
Coonak is offline
Find More Posts by Coonak
pǝʇɹǝʌuı
Coonak's Avatar
Perth, Western Australia
Joined Aug 2006
Burb,
Spektrum is + Expo.
Cheers
Mick
Coonak is offline Find More Posts by Coonak
Old Apr 01, 2009, 09:50 AM
Draven is offline
Fly Low Fly Fast
Draven's Avatar
Joined Sep 2006
Finished my Piaget!
http://www.rcgroups.com/forums/member.php?u=112816
Old Apr 01, 2009, 08:41 PM
burb is offline
Burb
burb's Avatar
Joined Mar 2008
Completed Pics
Will maiden in the morning .... hopefully
Fixed my expo ...Thanks for straightening me out !!!
Also checked my manual and of course you were right !!
Needed "plus" expo
Old Apr 01, 2009, 08:46 PM
burb is offline
Burb
burb's Avatar
Joined Mar 2008
Power Plant
One thing I noticed when checking out the power system was that the motor gets pretty hot..... I am using the 12a plush esc with 3s 750 Rhino battery
also the 8 x 3.8 slo fly prop
any comments ??
Old Apr 01, 2009, 08:49 PM
Draven is offline
Fly Low Fly Fast
Draven's Avatar
Joined Sep 2006
burb ive got the same prop and lipo, great lipo, but its not for this outrunner. It works best with 2s, It hovers at Half throttle as well. Since the motor was made for 2s, the extra power on the 3s is brought out as heat.
Old Apr 02, 2009, 08:25 AM
Mike Smart is offline
Find More Posts by Mike Smart
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
Originally Posted by groovejet
I think that Coonak's effort of 190g AUW is very impressive, so he appears to be the man to beat .
I'm afraid I failed, mine is 196gms - a real porker
Mike Smart is offline Find More Posts by Mike Smart
Old Apr 02, 2009, 09:09 AM
rmgmag is offline
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
Wow, I've gotta use less glue or something....
Old Apr 02, 2009, 09:30 AM
Patras, Greece
Joined May 2007
190 g withought LiPo?
