Old Jan 22, 2010, 09:26 PM
RotorJockey is offline
Find More Posts by RotorJockey
Fly Low-Crash-Rebuild-Repeat !
RotorJockey's Avatar
Jackson, MO
Joined May 2009
Subscribed.
Seriously considering one of these!
Gonna go back through the thread.
Anyone want to offer their approval/disapproval? strengths/weaknesses etc.?
Fred
RotorJockey is offline Find More Posts by RotorJockey
Old Jan 22, 2010, 11:58 PM
Harrow is offline
Find More Posts by Harrow
Yes, I know it's upside down.
Sydney, Australia
Joined Dec 2008
Great when you don't want to break your 3mm depron indoor plane. Definitely not as precise or floaty as 3mm depron indoor. But, does everything reasonably well. Doubt you'd find an indoor EPP that flew 3D much better. Knife edge is particularly good.
Harrow is offline Find More Posts by Harrow
Old Jan 23, 2010, 08:03 AM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
I was flying mine last night (indoors), along with a new ultra micro 4Site. I think the Piaget looped tighter, and needed less space!
Bill Glover is offline Find More Posts by Bill Glover
Old Jan 23, 2010, 09:06 AM
rmgmag is offline
Find More Posts by rmgmag
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
I take mine with me wherever I go. I mainly fly outdoors with it. It's fun, easy, and doesn't break. I mainly use it for 3D flying.
rmgmag is offline Find More Posts by rmgmag
Old Jan 23, 2010, 02:18 PM
matjon is offline
Find More Posts by matjon
matjon's Avatar
Sverige
Joined Oct 2007
I have now flown the Piaget a couple of times indoors.
When I turn around using the rudder it drops quite much in altitude and I have to use quite a lot of opposite aileron. Is this common for you guys to? Anything I can do to make it better?
My setup
Donuts E-power 2203 1700kv
Turnigy 10A esc
Graupner 8x3
Dymond D47 servo
2S 360mah & 600mah
Weight: under 200g AUW, dont have exact weight right now.
matjon is offline Find More Posts by matjon
Old Jan 23, 2010, 05:27 PM
Joined Nov 2000
Other people have reported this, but mine seems OK. It did flat turns a little nicer without the side-force generators on the wings, but there wasn't much in it.
Where is your CG? Mine is a long way behind the specified range, but the plane is still perfectly controllable. Maybe having an aft CG helps with rudder turns.
Old Jan 23, 2010, 11:47 PM
Harrow is offline
Sydney, Australia
Joined Dec 2008
I think that is just what it is going to do, since it is a lot heavier than a 3mm depron foamie, and so with a tight turn, it is going to drop the inside wing a lot more due to the reduced lift. You will find after a few more flights that you compensate for it without thinking.
Old Jan 24, 2010, 03:44 AM
matjon is offline
matjon's Avatar
Sverige
Joined Oct 2007
CG w/ 2S360 about 100mm from where wing meets fuse
CG w/ 2S600 about 85mm from where wing meets fuse
AUW with 2S360 173g and with 2S600 192g.
I was thinking about putting sideforce generators under the wing aswell, maybe that helps out.
Old Jan 24, 2010, 04:05 AM
Joined Nov 2000
AUW with 2S360 173g
How on earth did you achieve that (left bits off?)?
With 2S 360 mine is 197 grams. So my CG must be further aft, I would try that first.
Old Jan 24, 2010, 04:06 AM
Mike Smart is online now
Find More Posts by Mike Smart
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
My setup
Turnigy 10A esc
Graupner 8x3
Dymond D47 servo
2S 360mah & 600mah
Thats exactly what mine did. You can try moving the battery back further and maybe removing the single strake on top of the wing. My suggestion is sell it and buy a Clik 2.
Mike Smart is online now Find More Posts by Mike Smart
Old Jan 24, 2010, 04:09 AM
Joined Nov 2000
I have an Ikarus Yak that has a little more wing area than the Piaget and is 159 g AUW. I prefer the slow speed handling of the Piaget!
Old Jan 24, 2010, 04:14 AM
matjon is offline
matjon's Avatar
Sverige
Joined Oct 2007
Well, first oof all I don't know if my scale is correct.
But I have used lightweight parts. Motor is only 18g, servos 4,7g. I switched the flat carbon to 0,6mm and used as little glue I could.
The RX is a Spektrum AR6110.
I dont like to have the CG to far aft because then I find it hard to fly knifeedge.
Old Jan 24, 2010, 08:02 AM
Joined Nov 2000
Mine knife-edges very nicely, the biggest issue is that only a touch of rudder is needed so even with lots of expo it is easy to over-control.
Old Jan 24, 2010, 09:20 AM
matjon is offline
matjon's Avatar
Sverige
Joined Oct 2007
Yep, exactly what happens to me.
Yesterday I did som inverted flying, and I noticed that when I turn while inverted it does not have the tendency to loose altitude or fall in.
Guess I have to fly inverted from now on
Old Feb 28, 2010, 09:51 AM
Joined Nov 2000
Well I have another Piaget "handy hint"
The motor bulkhead is just a ring of ply. If your motor has a lightweight X shaped rear mount (like my Hacker) and you hit something, the motor can move back ... bending the mount.
This happened to me yesterday after a mid-air. The plane was unmarked, but I noticed it now had a load of left sidethrust
So fill in the centre of the bulkhead with balsa, so the motor mount cannot be bent backwards.
