Old Aug 19, 2009, 04:04 AM
EnzoFalconi is online now
Find More Posts by EnzoFalconi
Joined Nov 2006
My Piaget was built using low cost components. I used an HXT900 on the ailerons and HXT500's for the tail. I moved the servos quite a ways forward during my build to allow me to use lighter batteries and still get the correct cg. My plane will fly hands off whether upright or inverted using the Rhino 2s 360 or 460. My battery is about 35- 45mm's from the motor mount plate. You can see where I mounted the servos in the photos on page 13 of this thread.
Cheers
Michael
EnzoFalconi is online now Find More Posts by EnzoFalconi
Old Aug 19, 2009, 08:30 AM
ian84 is offline
Find More Posts by ian84
Melbourne, Australia
Joined Feb 2009
motor for Paiget
I have the Techone C20 in stock,
I have it running with a 9*5 slow prop
the stock 10A esc runs cool. very low amp loading when Full throttle.
With a 800mah 7.4V Hovers at half stick, I am not even intereted to see how it performs with a 3S... Cos i am very happy with the 800mah 2S with the 9X5 + C20 motor setup. Runs very well!
The motors are $25.00 each
Also have very limited stock of the 9*5 props. (more comming in soon)
www.flyhobby.com.au
ian84 is offline Find More Posts by ian84
Old Aug 21, 2009, 11:10 PM
Harrow is offline
Find More Posts by Harrow
Yes, I know it's upside down.
Sydney, Australia
Joined Dec 2008
Cheers
Michael
Enzo, thanks for your build thread. I am putting mine together this week and will use all of your ideas to keep it light and slow it down for indoor.
Regards,
Harrow.
Harrow is offline Find More Posts by Harrow
Old Aug 21, 2009, 11:47 PM
Joined Nov 2006
I can't take credit for the thread. I only added a few posts to an existing thread to show what I did to my plane to improve it. The experienced f3p guys could probably make it fly better than I did mine. My changes were just guesses as to what to do based on some of what I've seen on f3p's.
Michael
Old Aug 23, 2009, 12:02 AM
kevinc is offline
Find More Posts by kevinc
what motor
I use a motrolfly 2205 1800kv in mine and its unreal heaps of power and use a 1000mah 2 cell scpower lipo a great combo.
kevinc is offline Find More Posts by kevinc
Old Aug 23, 2009, 01:10 AM
Royster is offline
Find More Posts by Royster
Fly Big, Fly Hard!
Royster's Avatar
Brisbane, Australia
Joined Jan 2007
Originally Posted by kevinc
I use a motrolfly 2205 1800kv in mine and its unreal heaps of power and use a 1000mah 2 cell scpower lipo a great combo. You should check them out at scmodels.com.au
I gather thats for outdoor use by the pack?
How does that motor perform with a 350 2S?
Royster is offline Find More Posts by Royster
Old Aug 23, 2009, 09:54 PM
Draven is online now
Find More Posts by Draven
Infinite Zenith
Draven's Avatar
United States, TX, Arlington
Joined Sep 2006
How can you guys fly with a 360mah? I once tried that and it had to be moved up to the motor mount and it still wasn't enough, small lipos make it tail heavy
Draven is online now Find More Posts by Draven
Old Aug 24, 2009, 03:45 AM
Joined Nov 2006
Move your servos towards the front and the CG can be perfect for a plane that will fly level inverted or upright with the tail trimmed to center. I use a 2s Rhino 360 or 460 on mine. The 360 requires only a very small amount of forward stick when inverted. The 2s 460 is hands off for level flight whether upright or inverted. You can see my servo positions in photos I posted earlier. Move them a little farther forward than I did if you want the proper cg with a 360. I like the smaller batteries because the plane will fly a little slower by weighing less.
Old Aug 25, 2009, 07:42 PM
Infinite Zenith
Draven's Avatar
Joined Sep 2006
Originally Posted by tallflyer
Once you get the cg right on this plane she is a Hover Machine
gotta love hd video stills there good for shooting crisp indoor pictures of your own flying
Where do you have your CG?
Old Sep 01, 2009, 01:15 AM
Royster is offline
Fly Big, Fly Hard!
Royster's Avatar
Brisbane, Australia
Joined Jan 2007
Anyone use Blenderm tape for the hinges and is it still staying on?
The hinges that come with the kit look OK but would like to seal the gaps.
Old Sep 01, 2009, 01:40 AM
takiss is offline
Find More Posts by takiss
Patras, Greece
Joined May 2007
Yes. I use blenderm for sealing gaps and extra hinge protection. Works fine.
takiss is offline Find More Posts by takiss
Old Sep 01, 2009, 01:54 AM
Royster is offline
Fly Big, Fly Hard!
Royster's Avatar
Brisbane, Australia
Joined Jan 2007
On the Piaget?
Old Sep 01, 2009, 04:51 AM
rmgmag is offline
Find More Posts by rmgmag
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
I used it instead of the supplied hinges, it worked fine on mine. When building with EPP I always spray on some 3M77 adhesive prior to putting on the blenderm.
Bob
rmgmag is offline Find More Posts by rmgmag
Old Sep 01, 2009, 05:23 AM
Royster is offline
Fly Big, Fly Hard!
Royster's Avatar
Brisbane, Australia
Joined Jan 2007
Bob
Yep I have used Super 77 on EPP before. So how didi you spray it without spraying the whole plane?
Old Sep 01, 2009, 05:34 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
I used Blenderm without any additional adhesive and it's sticking fine so far, probably 40 or 50 flights so far.
Azarr
Azarr is offline Find More Posts by Azarr
