Old Dec 19, 2008, 10:42 PM
7ender is offline
Find More Posts by 7ender
United States, CA, Mountain View
Joined Feb 2006
Help with futaba/hitec compatibility
Hello,
I just bought a used plane for my friend with a neg shift, hitec 555 reciever. I also got him an old futaba 6xa transmitter.
I've been searching, but I cant' figure out if these are compatible. I know futaba is negative shift as well, but can I change out the tx crystal to match the reciever (tx is on 44 right now and rx is 40)?
Iv'e never had to worry about this as iv'e been using spectra. I'm confused by dual/single conversion stuff- could someone tell me exactly which crystal I need?
Thanks!
7ender is offline Find More Posts by 7ender
Old Dec 19, 2008, 11:04 PM
Sir Raleigh is offline
Find More Posts by Sir Raleigh
Raleigh, NC
Joined Apr 2007
They should be compatible. Hitec and Futaba both use negative shift.
The main thing you need to be concerned about between Single and Dual conversion is you have to use the correct crystal. Crystals are manufactured for either Single or Dual conversion receivers and cannot be swapped between the two. The Hitec 555 receiver is Dual conversion so you'll need a Dual conversion crystal.
Bill
Sir Raleigh is offline Find More Posts by Sir Raleigh
Old Dec 19, 2008, 11:20 PM
4*60 is offline
Find More Posts by 4*60
most exalted one
Canada, BC, Blind Bay
Joined Aug 2002
You are not supposed to change out the TX crystal, so get a dual conversion RX crystal as stated above.
4*60 is offline Find More Posts by 4*60
Old Dec 19, 2008, 11:35 PM
7ender is offline
Joined Feb 2006
Okay so all I need is a Hitec dual conversion channel 44 rx crystal, correct?
Old Dec 20, 2008, 12:58 AM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
Yes, you have it correct.
Bill
ebill3 is offline Find More Posts by ebill3
Discussion Need help with Futaba 9C and Hitec Spectra synth Module onewoo Radios 9 Sep 17, 2007 09:52 AM
Help...JR - Futaba - Hitec voyantus Radios 13 Jan 20, 2003 09:59 AM
Futaba / Hitec compatibility ?? Uncle Bob Electric Plane Talk 0 Jun 01, 2002 03:20 PM
For Sale GWS2015 Pico-Std Flight Pack with Futaba/Hitec Vertical and 270mAh Ni-Cd gbagley Aircraft - Electric - Airplanes (FS/W) 0 Dec 31, 2001 01:05 AM
