Old Dec 19, 2008, 02:44 PM
I-Love-Jets is offline
Find More Posts by I-Love-Jets
Joined Dec 2008
The OPS engine thread
Hello,
this post does provide some technical info including supplier sources for OPS high performance glow engines and spare parts.
Also known for high quality RC1 FIRE and FISE pattern power, certain OPS engines are well suited for the serious F3S speed freak (looking for >220 mph with an appropriate airframe).
Namely the 10 to 13 cc OPS RIRE engines featuring 5-ports (called Super SPP VAE / FAN / RCB) deliver more than enough power and rpm even non-modified.
However, the usage of continuous strand carbon fiber props is mandatory for these speed engines!
http://www.rcuniverse.com/forum/m_7954952/tm.htm
http://www.rcuniverse.com/forum/m_7984561/tm.htm
http://www.rcuniverse.com/forum/m_52...tm.htm#5226695
http://www.rcuniverse.com/forum/m_48...tm.htm#4908441
http://www.rcuniverse.com/forum/m_53...tm.htm#5310838
http://www.rcuniverse.com/forum/m_73...tm.htm#7375462
Some additional pics:
I-Love-Jets is offline Find More Posts by I-Love-Jets
Old Dec 19, 2008, 04:14 PM
Jeffery is offline
Find More Posts by Jeffery
And You're Not
Timbuktu, Mali (Happy?)
Joined Oct 2002
Yeah, yeah. Carbon fiber mandatory props that only a couple of people make and won't sell. That's why these engines are sitting in a box on a shelf (and I have the venturi's, one just has an RC carb in it for a pic).
See ya...
Jeffery is offline Find More Posts by Jeffery
Old Dec 19, 2008, 04:22 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
I have a couple marine OPS .45 I'm going to convert to airplane use. The pistons and liners are junk so I'll make some new ones for diesel.
gkamysz is offline Find More Posts by gkamysz
Old Dec 19, 2008, 09:54 PM
downunder is offline
Find More Posts by downunder
downunder's Avatar
Adelaide, South Australia
Joined Sep 2003
I'm sure Bolly will have a prop to suit your needs.
downunder is offline Find More Posts by downunder
Old Jan 07, 2009, 08:27 AM
Joined Dec 2008
Below we can see a quite exotic OPS engine:
The OPS .60 Super SPP RCA VL
The reed valve intake system of this engine allows about 12000 rpm maximum. In combination with an – in this case – low timed liner that engine is perfectly suited for the famous 60. sized pattern planes of the 80's for instance.
So this RCA VL engine comes with plenty of low-end torque!
Unlike its high timed 5-port OPS .60 goldhead RIRE disc or drum valve brothers this VL engine isn't intended for speed planes at all.
There was also a helicopter-edition identical to the RCA VL except for a longer heli-typical crankshaft.
Old Jan 07, 2009, 06:26 PM
I TOBOR is offline
Find More Posts by I TOBOR
I TOBOR's Avatar
Joined Feb 2007
This is my lone OPS, and RC .60, I used to have a 1.20 fourstroke and a 30 MAXI but sold those. It is a fine smooth running engine.
I TOBOR is offline Find More Posts by I TOBOR
Old Jan 29, 2009, 04:51 PM
25wood is offline
Find More Posts by 25wood
Joined Feb 2008
ops 60 rc
Hello, Does anyone know how many horse power the OPS 60 RC engine of the 1980's puts out? I need to know what RPM the engine will achieve on say a 12/6 prop. Regards Tony
25wood is offline Find More Posts by 25wood
Old Jan 30, 2009, 07:26 PM
chase4556 is offline
Find More Posts by chase4556
newbie
Spring, Texas
Joined Dec 2005
A buddy of mine has an OPS 5L in his boat(a .21). DO you guys know where he can find parts for this engine? The crankshaft snapped right infront of the rear bearing.
Or anyone have one of these motors they wouldnt mind us taking off your hands?
chase4556 is offline Find More Posts by chase4556
Old Feb 16, 2009, 10:12 AM
Joined Dec 2008
Hello guys,
many of your questions can be answered after using the links of post #1 (OPS parts suppliers, useable prop sizes etc).
In future it would be nice to post pictures your OPS engine(s) here while asking.
We will then be able to identify the exact version of that specific OPS engine
  • FIRE
  • FISE
  • RIRE
  • RISE
  • aero
  • heli
  • car
  • marine
  • low-timed
  • high-timed
  • low-nitro
  • high-nitro
  • drum valve induction
  • disk valve induction
  • reed valve induction
  • etc
leading to a more precise answer and hopefully speedy solution of your problem...
Old Feb 19, 2009, 11:03 AM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
I have experience with the big OPS Maxi twin if anyone is interested. I know it's not for F3S, but it did make my models go pretty fast. I saw a lot of poor info when I just ran a search. People saying a G62 has more power. I think not. It has a 5 port cylinder unlike just about any other large motor. Get enough fuel in it and it can really go.
Steve C
Steve C is offline Find More Posts by Steve C
Old Mar 12, 2009, 12:37 PM
mattpalmeris is offline
Find More Posts by mattpalmeris
Joined Mar 2009
I just picked up an OPS 60 Marine motor and I am wondering what type of fuel I should be running in terms of nitro content etc and the glow plug number.
mattpalmeris is offline Find More Posts by mattpalmeris
Old Mar 13, 2009, 08:57 AM
Joined Dec 2008
Hello,
generally all OPS engines starting from 6.5 cc capacity and bigger should be running at 20% of oil minimum. The OPS .80 (13 cc) and OPS .90 (15 cc) engines with at least 22% of oil for better internal cooling.
However if you have one of the needle bearing conrod versions (lower conrod end), then you can reduce the oil content to about 15%.
The nitro percentage mainly depends on the head button volume. Many OPS marine engines do come with either a "standard" or a "nitro" head button. The latter comes with a larger volume allowing for increased nitro content up to 40 %.
So it would be helpful to post a picture here of your OPS marine engine and also of the head button's bottom side...
As for the glow plug choice you can't go wrong with Rossi R8 or K&B HD high performance glow plugs.
Old Apr 24, 2009, 11:38 AM
Joined Dec 2008
This brand-new OPS 90 “BIMETAL“ engine basically is a bored-out OPS .80 (5+2 ports). It comes with additional tungsten weights implemented into the counter-weight of the crankshaft. The familiar needle-bearing conrod of the OPS .67 and .80 has been taken over as well as the drum valve induction unit.
http://ne-stuff.blogspot.com/2009/03/new-ops-90.html
Some pics of an aero conversion (for straight-line speed competition) of this engine:
Old Apr 24, 2009, 11:51 AM
Joined Dec 2008
A typical aero-speed-application of the OPS 90 you will see here:
http://www.rcgroups.com/forums/showt...0#post12100530
Old Apr 24, 2009, 07:02 PM
mjd is offline
mjd
Find More Posts by mjd
mjd
MikesRC
Canada, ON, Orangeville
Joined Aug 2003
OMG - that is one beautiful engine. Whimper.. I want one..
MJD
mjd is offline Find More Posts by mjd
Question PB carburater on a OPS engine coaxial-gyro Engines 0 Dec 16, 2005 04:13 PM
FS: Prather 31" deep vee 3.5 OPS Engine kd1942 Boats (FS/W) 0 Aug 27, 2004 01:29 AM
