Old Dec 19, 2008, 01:26 PM
Mwin is offline
Find More Posts by Mwin
Still Balsa Bashing
Cardiff, South Wales
Joined Aug 2006
Black wire corrosion on a signal lead.
The title says it all.
Today I cut a servo lead with the intention of soldering an extension to it
I noticed the signal wire had a distinctive black discoloration to it, not dissimilar to “black wire corrosion”
The servo in question was a new Hitec 81.
It’s only ever plugged into to set up programme perimeters and horn centring before installation.
The servo is going back to the supplier for a replacement.
Just wondered if anyone else has come across this?
Martin
Mwin is offline Find More Posts by Mwin
Old Dec 19, 2008, 02:53 PM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Partly.
Black wire corrosion happens in a multitude of situations. It is not dependant on any electric effect. Wires corrode on ground, positive, AC, DC, or lying unused in the store.
I attribute this effect to impurities in the copper, lubrication residue from the wire drawing process, acidic contents of the insulation, or interaction of said components.
Julez is offline Find More Posts by Julez
Old Dec 19, 2008, 03:56 PM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
Martin
I doubt that this is true "black wire" but some other form of corrosion. Is the wire now very stiff and brittle? Will it take any solder if flux is used? Is there a bluish ting to the black? In some 45 years in electronics and RC, all the true "black wire corrosion" occurred only in the presence of NiCad batteries and then only if they were wet cells or dry cells that have had the safety pressure release activated. It also ALWAYS started at the battery terminal and slowly worked it way to the next connection or junction where it usually (but not always) stopped. If the wire is blue-black, brittle, won't solder under any condition, then it might be black wire disease. If all these conditions do not exist, then it is some other form of corrosion.
Rodney is offline Find More Posts by Rodney
Old Dec 20, 2008, 02:13 AM
Mwin is offline
Still Balsa Bashing
Joined Aug 2006
Thanks Jules and Rodney for the replays.
I think your both correct it must be some impurities in the copper wire or the insulation.
The insulation was not brittle in any way and yes it would take solder. I did, however see some black spots on the surface after soldering.
I just hope this is a one off.
As a precaution the servo is not being used.
Martin
Old Jan 14, 2009, 01:53 PM
Tony Oliver is offline
Find More Posts by Tony Oliver
Tony Oliver's Avatar
North-East England
Joined Mar 2002
Black wire etc
I just selected one of my servo extension leads to shorten it slightly. Cut off the pins and got this:-
I've flown radio since the early 1960s and have come across this from time to time.
No prejudice here, my lead was brown, not black.
Tony Oliver is offline Find More Posts by Tony Oliver
Old Jan 14, 2009, 05:22 PM
AndyOne is offline
Find More Posts by AndyOne
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
There's good evidence to suggest this kind of black-wire happens when you leave electronics in a damp storage area whilst there is a battery still connected but not necessarily switched on.
Tony, it's still on the negative wire though.
Andy.
AndyOne is offline Find More Posts by AndyOne
Old Jan 15, 2009, 03:17 AM
North-East England
Joined Mar 2002
Andy, all of the ones I've had go black are on the negative.
I rarely leave batteries in the models except where they are difficult to remove without disturbing servos etc. (usually slopers).
None of the corroded ones have been in those models, and all are kept in the house in warm and dry conditions too.
This one, for example was with all my other wires and extension leads in a plastic box which doesn't seal. It's with my cameras which need some careful storage too. I examined all the others but none had any sign of black.
A few years ago, after discovering a similar situation, I started to do a check over the winter of all my models for deterioration after a season's flying. I've replaced chafed wires, some plugs and sockets, mainly due to wear and tear,but no more of this blackening.
I remember commenting on this in earlier posts a few years ago.
It's just somthing which happens. Rare it would seem, but newcomers need to be aware of the possibility, but not get paranoid about it.
Old Jan 16, 2009, 12:17 PM
AndyOne is offline
Oxford Panic
AndyOne's Avatar
Joined Feb 2003
There seems to be more than one cause of black-wire but the moisture plus voltage one is known about so can be avoided. Other causes of corrosion still exist, one of which was postulated as incompatible conductor/insulation combination, or chemical breakdown of the PCV insulation. I have come across old PVC cable that has a definite odour of chlorine about it.
Andy.
Old Jan 16, 2009, 12:57 PM
North-East England
Joined Mar 2002
You got it Andy.
PVC is polyvinylchloride - it does break down in time and can give off chlorine in some conditions. . I don't remember what's left, but it will undoubtedly be unpleasant, probably sticky and toxic to some extent.
Don't tell the PCGreenElfansafety lot!(although California's probably got 'em onto it already)
Old Jan 17, 2009, 08:25 PM
Hugh P is online now
Find More Posts by Hugh P
Quincy IL
Joined Jul 2006
I have been building and servicing radio systems since the mid 1960's.
I have had the "Black wire problem" in every color of wire ever used in RC systems.
I am not sure what causes it but my general impression is that some batches of PCV insulation but not all, cause this. Found many wire colors bad in some old Royal kit systems that passed through for repairs or check outs. Many more never had it and I have several Royal Tech and two Omega TX that never had it.
I recently upgraded one Omega TX with a HiTech Spectra TX module to FM and never found any problems with the old wiring.
JR appears to use silicon based insulation on their wires now and we have never found a problem with JR wiring nor have we seen any problems with the silicon wire on electric cars.
I don't think it is a quality problem as in RC manufactures using low cost wire as IIRC Boeing had the problem with 737 & 727 airframes wiring.
Hugh
Hugh P is online now Find More Posts by Hugh P
Old Jan 18, 2009, 03:38 PM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
Thanks for your insider report.
Question Black Wire Corrosion PeterH Batteries and Chargers 0 Sep 15, 2008 05:22 PM
battery black wire corrosion tipperary Batteries and Chargers 6 Dec 01, 2005 05:53 PM
Question Black wire corrosion in TX yogorilla Radios 11 Feb 19, 2005 04:20 AM
Black (and Red, and White .. ) Wire Corrosion Bill Glover Power Systems 6 Sep 27, 2002 04:04 AM
