Old Dec 19, 2008, 11:09 AM
Paul@SCC is offline
Find More Posts by Paul@SCC
Chalfont St Giles, Bucks, UK
Joined Jan 2007
Ripmax Flying Legends Mustang.
This is one sweet little foamy. If it flies as good as it looks then I will be one happy bunny.
Thanks to tjd models for fast shipping. Ordered yesterday at 11am received today at noon.
It arrived nicely packed and all parts are in excellent condition.
Paul@SCC is offline Find More Posts by Paul@SCC
Old Dec 19, 2008, 11:21 AM
MustangP51 is offline
Find More Posts by MustangP51
East sussex
Joined Jul 2005
sweet i have the spit but am having problems with the ailerons as the pushrod outer filled with glue. had to strip it out and am having trouble getting the new one in. May well go for a two servo set up instead as it would prove much easier! we will see. good luck with your mustang.
MustangP51 is offline Find More Posts by MustangP51
Old Dec 19, 2008, 04:50 PM
Paul@SCC is offline
Joined Jan 2007
Bad luck on the glue in the sleeve
Got the Mus together tonight, pretty straight forward. Put some epoxy around the Aileron & elevator horns and a little around the sleeves where they exit the wing & fuse. Used an EZ connector on the Ele horn and will do the same on the ailerons when I get some more.
Used HXT 9g servos and CoG was easy to achieve with my 2250 3S lipo.
Will set my throws tomorrow and I may get in a flight.
Old Dec 20, 2008, 07:29 AM
Paul@SCC is offline
Joined Jan 2007
Hi Mustang.
Well your not alone. Setting up the throws today and found the sleeve around the wire was loose. This caused binding and the ailerons would not center back. A complete nightmare .
So decided to go for the servos in the wing as you mentioned. It's a simple upgrade and turned out well.
Old Dec 21, 2008, 06:56 PM
East sussex
Joined Jul 2005
yep im gonna have to do this on my spit soon. were the standard horns tall enough for a servo in the wing?
Old Dec 21, 2008, 08:24 PM
Smokescreen38 is offline
Find More Posts by Smokescreen38
Checking CG is for NERDS!
Smokescreen38's Avatar
Joined Jun 2005
Cool... what motor are you running, Paul? What kind of performance do you expect?
Smokescreen38 is offline Find More Posts by Smokescreen38
Old Dec 22, 2008, 04:47 AM
Paul@SCC is offline
Joined Jan 2007
I had no problem achieving the 12mm throw with the stock horns.
Smoke.
The BL motor is supplied as part of the kit already installed. I've not taken it out to inspect.
I have run it up at home and I think it will give a fair performance with the 9X5 prop. If not, I think a Eflite 450 or equivalent would be a perfect set up.
Old Dec 22, 2008, 09:35 AM
Paul@SCC is offline
Joined Jan 2007
Maidened the Mustang today and she's a keeper. Good performance from the stock motor and prop.
I used 2250mah lipo. Dialled in 30% expo on ail and ele. She is as good as my E flite P47 and Sea Fury. No nasty surprises.
I hope they add more models to the Flying Legend series.
Old Dec 22, 2008, 11:30 AM
simon737 is offline
Find More Posts by simon737
Triple boxed goodness!
simon737's Avatar
United Kingdom, Doncaster
Joined Sep 2008
nice looking machine, what size motor and speed controller does it come with??
simon737 is offline Find More Posts by simon737
Old Dec 22, 2008, 11:44 AM
Paul@SCC is offline
Joined Jan 2007
Hi Simon.
Theres no info in the manual about the motor. The ESC is 20amp.
The motor looks small but it certainly does the job.
It looks like this kit is also available without motor and ESC for 39.99. Which in my opinion is fantastic value.
Heres some vid from the maiden today.
Ripmax FL Mustang. (2 min 22 sec)
Old Dec 22, 2008, 11:55 AM
Coop is offline
Find More Posts by Coop
Lawton/Fort Sill, OK
Joined Sep 2002
I wonder if anyone in the US will decide to carry this.
Coop is offline Find More Posts by Coop
Old Dec 22, 2008, 12:34 PM
Jimmy1159 is offline
Find More Posts by Jimmy1159
Jimmy
Jimmy1159's Avatar
United States, NJ, Highland Lakes
Joined Oct 2008
Was asking myself the same question. What's shipping cost from UK?
Jimmy1159 is offline Find More Posts by Jimmy1159
Old Dec 22, 2008, 12:37 PM
Jimmy
Jimmy1159's Avatar
Joined Oct 2008
ps Good looking bird, Who makes the spit in your other vid?
Old Dec 22, 2008, 12:41 PM
Coop is offline
Joined Sep 2002
Jimmy it is probably way too much to be justified.
Old Dec 22, 2008, 02:30 PM
Joined Jun 2005
It looks like a really nice plane and all... but check out the plethora of domestically available and fine flying P-51Ds before you go through the expense of importing one.
Discussion Ripmax Electric P51 Mustang 600 size Build Bigplumbs Electric Warbirds 126 Dec 29, 2011 02:31 PM
Discussion Duxford Flying Legends Video's MarkJayne Fuel Warbirds 5 Jul 25, 2006 08:50 PM
Discussion Flying Legends at Duxford MarkJayne Scale Kit/Scratch Built 50 Jul 23, 2006 02:19 PM
Discussion Video of Spitfire's and Other Warbirds From Duxford's Flying Legends MarkJayne Fuel Plane Talk 9 Jul 17, 2006 03:46 PM
Discussion Flying Legends at Duxford MarkJayne Foamies (Kits) 6 Jul 06, 2006 10:45 AM
