Old Dec 17, 2008, 06:48 PM
BossChase is offline
Find More Posts by BossChase
Joined Dec 2008
Is this the support forum for caliberhobby?
I don't think it is but they link to it for order support... Kinda sucks.
Well maybe one of you guys can help me out. If you've ever ordered a GWS p-40 I'm trying to put together the foam body and its telling me I need to have 6 rectangle hinges or Hinge Plates in step 1.3
Either my package did not comes with all the parts or the instructions I have are wrong. In the rest of the manual all the parts that I have to break off of the brackets are labeled or numbered. That hinge plate is not so it makes me think that it should have came in some other packaging but I don't have 6 of anything.
http://www.gwsus.com/images/note%20book/e_gws40_03.jpg
I hope one of you can tell me I'm an idiot and show me what I'm missing because it takes for ever to get mail from these guys.
BossChase is offline Find More Posts by BossChase
Old Dec 17, 2008, 07:17 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
I haven't seen any GWS hinges before. GWS normally usues the same plastic parts trees for everything. Worst case scenario, you will have to buy some hinges, but they aren't expensive.
Tower Hobbies has these, which look very similar. Plus, since they're already hinged, all you have to do is glue half into the flying surface, and half into the control surface.
http://www3.towerhobbies.com/cgi-bin...&I=LXD941&P=ML
Xpress.. is offline Find More Posts by Xpress..
Old Dec 17, 2008, 07:43 PM
planekiller is offline
Find More Posts by planekiller
Midnight Maniac
planekiller's Avatar
USA, NE, Lincoln
Joined Dec 2006
The hinges should be a separate rectangular piece with perforations.
I believe it would look something like this:
If it is not in the kit I know many people use floppy disc material for hinges.
planekiller is offline Find More Posts by planekiller
Old Dec 17, 2008, 08:42 PM
mpatterson is offline
Find More Posts by mpatterson
portage la prairie,manitoba, canada
Joined May 2003
It would be easy to overlook the hinges - they are, as planekiller said, on a separate sheet in one of the bags. If you can't find the sheet, don't sweat it. You can use floppy disc material if you can still find it, thin plastic from those see-thru containers that cookies or pastries come in from the grocery store, or any flexible, light plastic. I've also used clear acetate (like the cover pouches for loose leaf) from Wal-Mart and tyvek. If you're in the US, apparently you can get tyvek envelopes from the post office for free. Maybe someone else can chime in here with more info...
Bottom line is that you can probably find better material around your house.
Good luck
Murray
mpatterson is offline Find More Posts by mpatterson
Old Dec 17, 2008, 09:08 PM
Laggard is offline
Find More Posts by Laggard
Wind blows
Laggard's Avatar
Minneapolis
Joined Jan 2007
Just make some. Takes a few minutes and is cheap.
Laggard is offline Find More Posts by Laggard
Old Dec 17, 2008, 09:58 PM
Joined Dec 2008
Sweet thanks for the image man that helped me out. Yea I was looking for plastic hinges. I had that sheet in with all the decals. I'm good now thanks man!
Old Dec 18, 2008, 12:12 AM
Midnight Maniac
USA, NE, Lincoln
Joined Dec 2006
Glad you found them. They are excellent hinges.
Old Dec 18, 2008, 11:49 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
I don't know if you have already seen this thread - GWS-40 (P-40 Warhawk) Review
and the slightly older -
New Gws P-40 Thank You Mr.lin
There may be hints, tips, there that help.
eflightray is offline Find More Posts by eflightray
Why is this forum for micros only? Ben74 Coaxial Helicopters 1 Apr 03, 2004 11:43 PM
For Any Complaints About This Here Humor Forum.. DNA Humor 4 Jul 24, 2003 03:56 PM
What is this forum for? Tim Jonas Life, The Universe, and Politics 11 Apr 17, 2002 01:54 AM
