| Wingspan: | 78.74" / 2000mm -2M |
| Wing Area: | 632 sq. in. / 39.2 sq. dm. |
| Weight: | 30 oz. / 830g |
| Length: | 44.7" / 1137mm |
| Wing Loading: | 6.608 oz/sq. ft. / 21g/sq. dm. |
| Servos: | SV80 Sub Micros |
| Transmitter: | Spektrum DX5e 2.4 GHz DSM2 |
| Receiver: | Spektrum AR500 Full Range |
| Battery: | 11.1 V LiPo - 30 Minute Flight Times |
| Motor: | PKZ 480-size, 960Kv Brushless Outrunner |
| ESC: | E0flite 30 amp brushless with switching BEC |
| Features: | RTF, Plug-in wings, 2.4 GHz, Charger, Brushless, Z-Foam, folding prop |
| Manufacturer: | Parkzone |
| Available From: | Your Local Hobby Shop |
| MSRP: | $249.99 RTF and $159.99 PNP |
The Radian is exemplary of all things good in powered three-channel gliders and trainers: slow in flight, visible, predictable, stable, hand launch-capable, easy to land and it is mildly aerobatic. Add that it’s a true blue RTF that requires about 30 minutes of building and you have a plane that provides a quick path to instant gratification. Parkzone has followed a formula for RC success in this plane that includes good design, quality components and great flight characteristics. That in itself that is enough, but Parkzone has also included the Spektrum DSM2 2.4 GHz DX5e transmitter and an AR500 full-range receiver to make it even better, and it is also available as a PNP.
Mine arrived in a huge box, double packaged, with only a few slight dents in box. Everything inside was secured well.
For those of you new to 2.4 GHz this RTF version includes one excellent starter 2.4 GHz transmitter. The DX5E is fully functional with buddy-box compatibility, servo reversing, digital trims, elevon mixing, dual rates (preset), channel five switch, and it all operates on 4.8 volts (four AA cells). It is also upgradable to rechargeable batteries.
The airframe and wings are Z-foam. Z-foam is resilient, easily repairable and looks good with its slick finish. The horizontal stabilizer is layered with a finished hard surface for stiffness and durability. The vertical control stabilizer and rudder are Z-foam.
RTF Includes (this is a complete parts list - all components are installed):
Optional Components:
The Radian is a quick build, so I suggest you get that battery on the charger so it will be ready when you finish!
“Assembly” is a six step process from unpacking to taking to the air.
Get those included batteries installed in your transmitter. The Spektrum 2.4 GHz radios differ from your FM radio in their much more efficient use of power. Those four batteries will give you nearly 24 hours of flight time. After several trips to the flying field you will notice the LED lights showing less than full power.
The 2-3 cell balancing charger uses the balance tap (Charge Lead) for charging. The charger is capable of charging 0.3 and 2.0 amps. There is a switch to set the cell count and a rotary dial to adjust the amperage. Connect the charger to a 12 volt power source, listen for the beep and look for the green LED to light up. Set the amps and the voltage switch, connect the battery and push the start button. It’s as easy as that! The charge takes about an hour. The green light flashes to indicate the battery is balancing, a beep signals the completion for the charge.
There are no ailerons on the Radian. The wings are two pieces with a large carbon spar. I pushed the spar into one wing, taking care that it was seated. I slipped that wing into the fuselage and then slipped the other wing onto the spar. It takes some force to fully seat both wings. I used the contours of the wing saddle to gauge the mating. Over time there will be some movement. A small piece of tape is all that is needed if you feel like having a second line of defense.
The vertical stabilizer is complete. It is hinged and the rudder servo is connected.
The horizontal stabilizer slips into the receiver in the fuselage and tapes in place. I squared the tail with the wings and used the metal canopy mount instead of the wing tips. The wings move, so using them to square is not a good idea. I used the provided tape to secure the top and bottom of both sides.
The radio is located on the underside, and the battery is under the canopy on the topside. It is obvious the Radian 2.4 GHz AR500 electronics were intended for this location from the beginning as evidenced by the molding in the fuselage.
Tail and forward skids are provided under the fuselage, and seams are sealed with tape.
The preferred CG location is 2.5 inches behind the leading edge of the wings at the wing root. I moved the battery aft as far as I could.
The Radian AR500 comes bound to the DX5e from the factory. If for some reason you have to rebind (for example, setting your fail-safe option):
A quickstart guide can be found here.
Fail-safe features:
The DX5e makes range checking so simple that it should become a habit whenever you fly.
I turned on my transmitter and then the receiver, secured the plane to the ground and walked about 90 feet away from the model. Facing the model, I pulled and held the trainer switch and then toggled the Hi/Lo rate switch four times. The transmitter LEDs flashed and an alarm sounded indicating the range check was programmed. You should have total control of your model, and all control surfaces should move with your control inputs. To return to normal operation, I turned off the transmitter and then turned it back on. When turned off, the fail-safe returns the control surfaces to their fail-safe positions.
The Radian weighs in at just about two pounds and has an incredible wing loading of 6.6 oz. sq. in. You really have to experience this size of a plane with this low of a wing loading.
I waited for the perfect day to fly my Radian for the video. I had flown it several times before, but I wanted some wind to show how it handled. With a steady nine mile an hour wind, I took to the air. The Radian is a soaring sailplane - not a hot-liner, not just a powered glider that lethargically climbs and lets gravity take over - it is a soaring plane of unique character.
In the video I was able to fly without power through most of the video. At the end I bumped the throttle twice, but otherwise I flew without any power assist, and it was really something to experience. The wind was meeting the slope I was flying from at a perpendicular angle so I was able to endlessly go back and forth. If I had had a chair, I really think I could have flown for hours on a single pack. Prior to the video flight, I had flown the Radian twice and never charged the battery between flights. In total, I may have throttled one to two minutes in all those flights.
Soaring requires wind, lift or both. This time of year, thermal lift is just not there but we have plenty of wind. You will see in the video how well the Radian penetrates and the authority the tail and rudder have. I crabbed, and in spite of the crosswind and force on the tail, it did not weather vane into the wind (listen to the wind howling). I turned into the wind and lifted the windward wing, and I got no tendency to push the turn the Radian outside the control I input. I did need to use the high rate in the wind, which is a feature of the Spektrum DX5e.
The Radian has so many great features. There is power when you need it; It is quick and will get you vertical in short order. The wing design is stable, but it does so with the winglets and not with over-stabilizing dihedral. Throughout the video you will never once see the Radian buffet. It is as stable into the wind as it is across the wind and downwind. The Spektrum DX5e is light, which is a good thing because in the right conditions, the Radian will follow your inputs for hours. The instruction manual indicates 30-minute flights, but I found that if I could get some wind or lift and I had the makings for a fun day of flying without the transmitter fatigue.
One word of caution: be sure to keep the wires away from the outrunner. I pulled the battery coupling aft and placed it near the battery. This pulled the wires aft and away from the motor.
A light hand launch is all that is necessary. It leaped out of my hands and climbed straight up quickly; a good attribute on days where wind and lift are difficult to find. Fun flying with power and without power is possible.
Landings are gentle. The Radian will stall, but it’s not something you are likely to see on landings. Stalls were straight ahead. You can see in the video I have a hard time getting it down. Landing was really more of a commitment to ending the flight, and I had to nose it down slightly to grab the ground.
The Radian is mildly aerobatic. It will do loops all day long both powered and unpowered. It will fly inverted, but I had to enter the inverted flight from the top of a loop. I could not get the Radian to roll over very easily. When it is inverted it looks like a huge bird setting its wings for a landing so it is impressive to say the least.
It is for the beginner, but at least get a spotter to help you. The Spektrum DX5e does have a trainer port that connects to another Spektrum master radio or JR radio. It is stable, a slow flyer and the Z-foam construction is likely very durable. Parts are also easily available.
The videos are both bigger than I usually provide. The longer video is worth the download time; it shows the flight stability, and you can hear the wind blowing in the camera microphone. Watch and notice the wing and how it remains under my control and not in the wind’s control. Note the authority of the rudder to push the Radian where I wanted it to go. In the longer version, am able to soar for almost six minutes, and at times, very close to the ground. I was catching uplifting winds coming perpendicular to the hill. It was a blast!
Well, you gotta have one of these! You will learn to chase thermals and winds and enjoy every minute of the experience. It was easy to build, easy to fly and made me want to get more air time in even tougher conditions. You will be amazed at the construction and design and how those join with the flight characteristics to make the Radian one really great soaring sailplane. I highly recommend Radian for all types of flying.
Pluses:
Minuses:
| Thread Tools |
Just waiting on spring here. Thanks for the review!
Latest blog entry: A good watch...
| Thread Tools | |
| Article Horizon Hobby's ParkZone Typhoon 3D RTF Review | Stocker | Electric Plane Talk | 9 | Mar 16, 2009 04:00 AM |
| Article Horizon's ParkZone Slo-V RTF Review | Fred Sanford | Electric Plane Talk | 3 | Dec 14, 2004 10:34 PM |
| F/S Big 100 inch Astro FAI 015 Powered Sailplane w/flaps | Jim Blanchfield | Aircraft - Sailplanes (FS/W) | 2 | Jun 25, 2003 04:07 PM |
| F/S BIG 100 inch Astro FAI 15 Powered Sailplane w/Flaps | Jim Blanchfield | Aircraft - Electric - Airplanes (FS/W) | 9 | Jun 25, 2003 04:01 PM |
