| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
Hobby Lobby's Waco Biplane RTF
IntroductionSaid Robert Burns, the Bard of Ayrshire, "The best-laid plans of mice and men....", and he sure had me in mind. Yea verily, I had foresworn flying pre-made flying things of foam and other forms of out of the box and into the air in but an hour devilment, and had ordered me up a specimen wrought in ye Olde Waye, a bonny carton of sticks and sheets of laser cut parts which I was going to spend weeks, cutting, carving, breathing balsa dust, and otherwise putting together when enchantment struck and just as the Bard said, all bets were off and me hearte was taken. Someday I will tell you the story of how it came to be that I am vulnerable to things of the yellowest hue and why creatures with two wings and blessed with a round proboscis draw me unto them, but not for now, for I know you are already rumbling "get on to the airplane will you, you long winded knave". And so I shall. When I happened on a Hobby-Lobby WACO bipe serving as an eyeball magnet on my buddy's dining room table I was in gottahavit land, and have it I did. In its blazing yellow paint, Hobby-Lobby's ARF foam WACO captures all the romance of flying in the Classic Age. What a great job. This flying machine looks super on the ground and even better in the air. It assembles quickly, is rugged, flies well, and provides everything you need in one box. I like it a whole lot, and I think you will too. BUT dragons await! There are a few things you need to watch out for, so go ahead, look at the pictures and play the video, but after that, read the text for some important hints.
Kit ContentsThe bright graphics on the box show you exactly what you will be flying. When it comes to packing up an airplane, the folks who designed the WACO's packaging are winners. The parts are in layers, separated by cardboard partitions and foam wrapped or boxed where necessary. This airplane's soft foam can mar easily, but the careful packing did its work perfectly. The WACO builds up from a relatively small number of parts. All the required hardware is provided and is of good quality. I thought this plane was exceptionally well engineered. The task of fitting the upper and lower wings together with struts was made easy with accurately placed strut hardpoints, and the clip that joins the fuselage-stabilizer-rudder also simplified a sometimes complicated task. Though the kit specifies a 1300 ma. battery, the included battery is 1500 mAH is provided with Deans connectors and has had its cells individually tested. Sweet! A 4 channel transmitter is provided along with a battery charger, an extra propeller and 3 tools. There is also a set of instructions with assembly steps fully illustrated in color. AssemblyThis airplane is RTF - Ready to Fly. All the mechanisms are already installed, and the main parts are completed, painted, and decorated. A very short time with a screwdriver will suffice to complete the assembly.
TailThe stabilizer and elevator are one piece. You might want to flex the elevator a few times to be sure that it will move freely. Notice that the fuselage has double sided tape with a layer of protective paper on top. If you wish to use this, peel the paper off, but if you do so, position the stabilizer onto the fuselage very carefully, for the tape will grab immediately and adjustment will be difficult. If you don't want to bother with this, leave the paper on. Nothing will be lost. A hard plastic clip penetrates the stabilizer and projects down into the fuselage and up to hold the rudder. Fasten the stabilizer with screws down through the clip and into the fuselage. Now locate the tail wheel and slip it into the mount on the bottom of the rudder, then slide the rudder into the clip on top of the fuselage with its front end fitting into a slot in the fuselage, and fasten it with screws.
WingNow comes the task of installing the wings to one another and to the fuselage using "N" struts and cabine struts. Take the time to carefully examine the struts. You will notice that small letters mark the top and bottom of the N struts and small letters distinguish the right side cabine struts from the left side struts. Once you have things sorted out, you can follow the instructions and screw things together in short order.
FuselageThe fuselage is already complete. Just slide the landing gear into its slot. Be sure to insert screws in the tabs midway up the landing gear legs, as shown in my photo and as not shown in the instructions. With the screw added (buy a couple at a hardware store if enough weren't supplied) the gear becomes much more sturdy. Install the propeller and spinner, and admire your assembled airplane Radio InstallationIt's all done for you. CompletionNow insert your battery. Notice that you must first drop the battery into the hatch, and then rotate until it is horizontal and slide it as far forward as possible. It is crucial that the battery be as far forward as possible. The instructions say "With the supplied components installed the C.G. (center of gravity) is automatically correct." This might be true in your case. It certainly wasn't in mine. My WACO was seriously tail heavy, resulting in a knee shaking whoopsiedoo of a first flight and necessitating 3/4 oz. of lead buried in the underside of the cowl. The CG location is 3 1/8" back from the leading edge of the upper wing. The rudder, elevator, and aileron control throws are all pre-established. I found these setting satisfactory for initial flights. I suspect that once the plane is "dialed in", most flyers will want to increase the aileron throws. Contact!! You are ready to fly. FlyingBasicsWACOS appealed to the general aviation enthusiast, sport pilots and to those with a yen for air show acrobatics. The model will satisfy sport flyers and, remembering that in the 1930s and 1940s were far more basic than what we are used to now, will put on a respectable vintage air show. Taking Off and LandingBe sure the plane is properly balanced. Mine was tail heavy. The CG should be 3 1/8" back from the leading edge of the upper wing. If the CG is correct there is nothing special about takeoffs. Advance the throttle gradually, be prepared to use a bit of rudder, and introduce a tad of "up" when the plane looks like it want's to fly. Landings are straightforward. Let the plane descend on minimal power, and be prepared for the fact that the landing gear is a little bit springy.You will probably bounce a couple of initial landings, but soon enough will get the hang of it.
Aerobatics/Special Flight PerformanceAs mentioned, you can perform 1940's style aerobatics, but don't expect 3D. The plane loops large and small and will roll, although to roll crisply you might find it necessary to increase the aileron throws. The general delight of this aircraft, though, is in just sporting around, enjoying its brightness and realistic appearance.
Is This For a Beginner?Hobby lobby lists this airplane as for "intermediate" flyers, and that makes sense to me. It is a bit small and frisky for beginners, but if you have flown a model or two with ailerons, it isn't going to bite you.
ConclusionSweet!! This is a plane with personality. Want to feel like the Great Waldo Pepper, barnstorming over the heads of an awed crowd, the wind in your hair and a grin on your face? This WACO is what you need. Try one.
Thread Tools |
#2 |
Sam Talley
CoG Excitement Shared!
I, too, had an exciting first tail-heavy flight, but thanks to my extraordinary piloting skills (and an astounding amount of luck) was able to push enough down elevator to get control long enough to trim the airplane and land it.
I had to add 2.75 oz. of lead under the fuselage, just behind the cowl to get the CoG right. Luckily, I found a thread on EZone that provided the CoG location. This is a very good looking and well-mannered airplane. |
#3 |
Great review! Too bad you can't have a higher quality movie.. 1.76mb? That would be "small" for dial-up!
Avi would be nice as well. Thanks again for the review! |
#4 |
great plane! great review! i too have this with a 480 size motor with 960kv and its a really great performer
#5 |
I've got one of these on the bench to build right now. The stock motor looks adequate, but a more powerful motor would be nice. I bet that 480 sized motor does really well.
#6 |
Aerobatic Addict
Just wish they would sell this in something like a plug-n-play or reciever ready version.
#7 |
Hugocraft, I certainly agree with you. I don't understand why they insist on packaging radios with aircraft that are not really meant for beginners and which properly should be bought be people who already probably have radios.
Furthermore, the supplied radio did not last long (just wouldn't work - I don't know what was wrong with it) and I substituted one of my JR radios. Being able to fly with some exponential really made a large positive difference. I will confess, too, that I find that the location of the CG not being furnished in the instructions is very annoying. I had to call up and get a figure from HL. |
#8 | |
#9 |
Dr. Dave
Excellent Alan! I love Waco's especially yellow ones.
#10 | |
Always Ready!
#11 | |||
Check youtube. I've got some vids on there and others have posted some too. Can't say they're better quality, just other videos.
#12 | |
Honey, I got more planes!
#13 |
Anybody know what size prop this comes with standard? My prop doesn't have the size printed on it.
#14 |
Correct url for Waco Classic Aircraft http://www.wacoclassic.com/
#15 |
Ugh ... For as much as I love Hobby Lobby on the whole, a complete and utter lack of after sale support on certain products drives me nuts.
I called up Hobby Lobby today because I bought this plane at their sidewalk sale. All the props in the box ended up being busted, and the motor had a very bent (and unreplaceable) shaft and warped bell on it. So I called Hobby Lobby to find out what size prop it took, and what the ESC was rated at (since the ESC was working, but I didn't want to put a new motor in there and burn it up if the motor pulled a couple too many amps ... we all know how those Chinese parts can be). The customer service rep (Shawn) couldn't tell me any info on either part. He pretty much looked up exactly what I looked up on the website myself - replacement props with no specs, replacement ESC with no specs. He said if he had to guess, he'd figure the prop at being a 9x7 slow flyer. But who's to know? And if it's too much and burns up the ESC, who's going to be to blame? Me for putting on a prop that's pitched too high. I don't like being forced to buy spare parts from the rep who doesn't even know what the spare parts are rated for, especially when I already have a stack of other spare parts (small bell motors and dozens and dozens of props) that can readily be put on and have me back and flying in 10 minutes if I just have the information. I also think it's kind of crappy to read this review, and then find out later down the thread that the reviewer's stock radio he received crapped out and wouldn't work, so he had to substitute his own, yet nowhere in the review was that mentioned. I feel like a reviewer has a responsibility to make others aware of such issues and then detail what the retailer did to correct them, rather than just avoid mentioning it altogether. It's a review, after all, and not an advertisement. Or at least, it should be. Alright, getting off my soapbox now ... just a tiny bit frustrated overall. |
| Thread Tools | |
| Article Hobby Lobby's TB-20 Brushless RTF Park Flyer Review | dawnron1 | Parkflyers | 335 | Jan 15, 2010 10:12 PM |
| Article Hobby Lobby's Pitts Bipe RTF Biplane Review | sun.flyer | Parkflyers | 431 | Nov 21, 2009 09:06 PM |
| Article Hobby Lobby's Honey Bee II Micro Heli RTF Review | Stocker | Ezonemag Archive | 22 | Jul 27, 2009 01:05 PM |
| Article Hobby Lobby Twister "Medevac V2" RTF Coaxial R/C Helicopter Review | 78dave | Coaxial Helicopters | 12 | Apr 21, 2009 08:20 AM |
| Article Hobby Lobby's SkyGo Beginner's RTF Review | Stocker | Ezonemag Archive | 32 | Dec 31, 2007 03:38 PM |
