Old Jan 29, 2009, 10:31 PM
3 Strykers,your out !
junglegym's Avatar
Lurking Melbourne Australia
Joined Apr 2008
Asw 28.....
Got mine from u\h ,H\C, h\k and i know what you mean about this sort of high aspect model's flying characteristics, i got a CM Pro discuss a while back and elecrtofied it, it has flexy wings and tends to want to go fast what ever CG or trim settings you use.
CG , thanks for the info, tail heavy to me is never an option, specially for the maiden flight, 3D is not my thing, but i can see how tail heavy would be avantageous when setting up those planes. I plan to follow your advise and use the recommended setting plus do a few test glides into long grass before venturing skyward, and will have some stick on lead weights at the ready, it's what i do with most of my planes, as i've been caught out a couple of times following factory suggested CG's and ,correct, ended up doing the re-kit of a brand new model!! Which is always depressing .
I noticed in the tail boom of the ASW 28 a carbon spar which was not attached or glued to the foam, so i cut along the top seem of the boom and dropped a few drops of CA onto the spar when set it reduced the tails rotational movement a little ....
Careful that CA doesn't run back onto or into the end of the internal pushrods!! I used thick CA and tilted the fuse foward till the glue set.....
Plan to fly ASW 28 this weekend, will post result (s) ...
Cheers jim
junglegym is offline Find More Posts by junglegym
Old Jan 30, 2009, 02:03 AM
guy5927's Avatar
Gistel, Belgium
Joined Mar 2004
Mine flew over from UH/HC/HK last week , also with the zippy 1300mah 20C
Haven't got the time to take her out now, so I will follow your findings very closely, Jim ! Good luck !
guy5927 is offline Find More Posts by guy5927
Old Jan 30, 2009, 02:41 AM
Good Better Best quest.
olmod's Avatar
Australia, VIC, Cranbourne East
Joined Apr 2004
Jg
I remember having a look and feeling the comliance of the alerons and wondering how they managed to get it so good with no horns, it did not look like a swivel crank type but i could be wrong.
olmod is offline Find More Posts by olmod
Latest blog entry: For motor builders
Old Jan 30, 2009, 03:01 AM
junglegym's Avatar
Joined Apr 2008
Interesting that , i will have to consult with you more on the subject Les, all i know is, it works,and as you observed, works well ???
guy5927, Hope to have a post maiden de brief for you after the weekend
Old Jan 30, 2009, 04:10 AM
I'm torquing to you!
Mr Kamikaze's Avatar
Wattle Grove NSW Australia
Joined Nov 2006
Someone posted pics of the mechanism here
http://www.rcgroups.com/forums/showp...6&postcount=58
Mr Kamikaze is offline Find More Posts by Mr Kamikaze
Old Jan 30, 2009, 04:32 AM
olmod's Avatar
Joined Apr 2004
OK but still not clear to me whats in the aleron or is the secret in the block that the lever goes into
Old Jan 30, 2009, 06:40 AM
junglegym's Avatar
Joined Apr 2008
Thanks for the link, bendy hinges, never seen them before
Old Jan 31, 2009, 06:20 PM
Joined Nov 2006
Originally Posted by evo62
Woah!
That's heaps, unless your battery is lighter then the stock one. (bear in mind I'm a noobie at this so wouldn't question your setup). I am used to flying radically rearward CoG from my 3D ships.
I took about 10 grams of lead out this morning and it's better. It was pretty windy about 20kph but it still went up fine and flying with an EHawk 1500 we were managing to find some pockets of lift, actually got a real good one that took me pretty high. Still managed an easy 20-25 minutes from one battery in less than ideal conditions.
Old Feb 01, 2009, 04:13 AM
junglegym's Avatar
Joined Apr 2008
ASW 28 maiden !!!
No go this weekend !! Blowing a frigg'in gale in Melbun, will try one evening during the week ......
Q : ? I received a small metal cylinder with a threaded internal end and an O ring
in the box of accessories that came with the ASW 28 , got no idea what it's for, anybody else know ??? Maybe in the kit by mistake , can't see it mentioned in the destruction manual either ??
Old Feb 01, 2009, 03:12 PM
Nup, I got nothing!.....
evo62's Avatar
Gold Coast, Australia
Joined Jun 2007
I don't remember seeing that in my box, maybe just a random part from something else.
I've been surprised how much wind this plane can handle -probably not the best conditions for your first flight though!
evo62 is offline Find More Posts by evo62
Old Feb 02, 2009, 02:56 AM
junglegym's Avatar
Joined Apr 2008
Yes, it's always tempting when you are trying out a new model to chuck it and see .... I'm pretty sure I would have regretted it tough ...
Mystery component pictured below, I'm stumped !!!???
Old Feb 02, 2009, 03:21 AM
Joined Nov 2006
HEY!!! I didn't get one of those!!!
Old Feb 02, 2009, 03:44 AM
junglegym's Avatar
Joined Apr 2008
LOL, Guess I lucked out for once , I think .???
Old Feb 02, 2009, 03:57 AM
Joined Nov 2006
I think you should start a "What the hell is this?" thread!
Old Feb 02, 2009, 05:47 AM
junglegym's Avatar
Joined Apr 2008
Top idea ...........
HF Model: ASW28 Fully Molded, 3m rthorne Aircraft - Sailplanes (FS/W) 9 Jun 06, 2005 04:09 PM
ST MODEL Lipos? OzDragonFlyer Batteries and Chargers 2 Mar 14, 2005 03:21 AM
Motor for ST model YAK TooLyr 3D Flying 7 Oct 26, 2004 04:17 PM
Any Experiences with ST Model Lithiums? CustomPC Batteries and Chargers 8 Jun 09, 2004 10:15 PM
ST Model KA-V1000R lipo charger jbird Batteries and Chargers 3 Nov 11, 2003 07:38 PM
