Old Oct 26, 2012, 10:38 PM
byteman is offline
Find More Posts by byteman
Somewhere in New York
byteman's Avatar
Joined Aug 2010
asw28
Hi guys .im from NYc im waiting my st ASW28 TO maiden flight.
This is my first glider. I wish that its a nice flier.
byteman is offline Find More Posts by byteman
Old Oct 29, 2012, 03:06 PM
byteman is offline
byteman's Avatar
Joined Aug 2010
Some pictures of my home made glider.
Im waiting until my ASW-28 arrive from tower hobbies....
Old Nov 23, 2012, 08:19 PM
byteman is offline
byteman's Avatar
Joined Aug 2010
asw28
Hi . Its a good glider.
Old Dec 21, 2012, 05:08 AM
vavo is offline
Find More Posts by vavo
Joined Dec 2012
Hi;
@studioRS
May I ask what type of cover was used on the EPP / EPO wings to soften it and give such smooth look, did u covered CA+cottonFiber the hole wing than or just the tipps? did u us an airbrush? I cant find a log for those chemicals used
Martin
vavo is offline Find More Posts by vavo
Old Dec 21, 2012, 08:06 AM
studioRS is offline
Find More Posts by studioRS
Klassische Bilder
studioRS's Avatar
Northern Vermont
Joined Jul 2010
Originally Posted by vavo View Post
Hi;
@studioRS
Martin
All the details are in my ASW-28 blog here
http://www.rcgroups.com/forums/showthread.php?t=1494472
studioRS is offline Find More Posts by studioRS
Old Jun 10, 2013, 05:14 AM
netarc is offline
Find More Posts by netarc
netarc's Avatar
Joined Apr 2013
Originally Posted by Goody63 View Post
Anyway I decided to change the ASW28 to a 3S setup during the week.
I kept the stock motor and prop but changed the esc to a Turnigy Plush 25 amp. With a 3S 1000MAh lipo the power went up to 145 watts at around 15 amps.
When swapping out the ESC for one that will support a 3S battery, is a 25-30amp ESC sufficient, or did you ultimately find you needed more? Also, brush or brushless ESC? And are you still running stock motor & prop?
Thanks for any advice, I'm considering purchasing the ASW28 but would like to do the 3S upgrade.
netarc is offline Find More Posts by netarc
Old Jun 10, 2013, 08:17 AM
mikejincan is offline
Find More Posts by mikejincan
mikejincan's Avatar
Ontario Canada
Joined Nov 2008
A 25~30 amp brushless esc is more than adequate ... as was just mentioned, it uses 15 amps with a three cell battery. He did say that was with the stock motor and prop.
Be advised, if you go to a 3 cell esc & battery you can't run the motor at full throttle/power for more than a few seconds at a time without burning out the motor.
Adding a bigger esc and battery equals more weight, it's no longer a lightweight glider. If you want a hotliner, buy one, don't try to modify this glider to be a hotliner, buy the fiberglass version .
mikejincan is offline Find More Posts by mikejincan
Old Jul 26, 2013, 08:38 PM
pitts is offline
Find More Posts by pitts
pitts's Avatar
Anywhere there is room to fly...
Joined Feb 2004
I have owned this model for about 4 years now, but just got it out again the other day. Its a really enjoyable glider to fly, and other than the pilot figure, I have left it stock.
Heres a little vid of the ASW28 sniffing around for some lift (We are in winter here, so there wasnt much around!!!)...
Flight Of The ASW28 (7 min 58 sec)
pitts is offline Find More Posts by pitts
Old Jul 26, 2013, 09:05 PM
cynr100 is offline
Find More Posts by cynr100
Biomass processor
cynr100's Avatar
Australia, QLD, Cairns
Joined Sep 2012
Very very nice vid Pitts, pat yourself on the back.
Hmmmm think I might one
cynr100 is offline Find More Posts by cynr100
Old Jul 26, 2013, 10:31 PM
jaskel is offline
Find More Posts by jaskel
WHAT U LOOKIN AT!
jaskel's Avatar
Penrith, NSW, Australia
Joined Dec 2005
very nice vid mate
jaskel is offline Find More Posts by jaskel
Old Aug 13, 2013, 02:42 PM
kdwzagi is offline
Find More Posts by kdwzagi
(madkev :) )
kdwzagi's Avatar
United Kingdom, England, Stafford
Joined Dec 2002
wing underside question
Hi
I've had my st models asw28 for over a year now and even though it flies well the underside of the wings always bothered me. the circular moulding that houses the aileron linkage is quite proud from the rest of the wing surface (4mm) and there's a channel that houses a small stiffener outward of this that is quite deep (not full of glue). both wings are the same so i guess they're all produced the same in the factory?
has anyone sanded excess foam from the circular moulding and filled the channel ?
your thoughts please
Kev
kdwzagi is offline Find More Posts by kdwzagi
Old Aug 13, 2013, 04:27 PM
studioRS is offline
Klassische Bilder
studioRS's Avatar
Northern Vermont
Joined Jul 2010
I've been successful removing some of the foam that is near the aileron arm. My best fix for smoothing out was to cover with either white vinyl or clear tape.
Old Aug 14, 2013, 07:08 AM
kdwzagi is offline
(madkev :) )
kdwzagi's Avatar
Joined Dec 2002
when you say some of foam did you remove it so that it was flush or did you just blend it in a bit ?
kev
Old Aug 14, 2013, 08:04 AM
frank48 is online now
Find More Posts by frank48
Went to mow a meadow
frank48's Avatar
United Kingdom, Dur
Joined Feb 2007
Can anyone suggest a replacement motor? Ive hunted high & low for one with a long threaded shaft so the folding prop fits
Frank
frank48 is online now Find More Posts by frank48
Old Aug 14, 2013, 08:42 AM
studioRS is offline
Klassische Bilder
studioRS's Avatar
Northern Vermont
Joined Jul 2010
kev
Both, I removed some foam (and glue bits) underneath the servo arm so movement was smoother and blended the edges on the outside where they protrude past the airfoil surface, then covered with clear tape.
HF Model: ASW28 Fully Molded, 3m rthorne Aircraft - Sailplanes (FS/W) 9 Jun 06, 2005 04:09 PM
ST MODEL Lipos? OzDragonFlyer Batteries and Chargers 2 Mar 14, 2005 03:21 AM
Motor for ST model YAK TooLyr 3D Flying 7 Oct 26, 2004 04:17 PM
Any Experiences with ST Model Lithiums? CustomPC Batteries and Chargers 8 Jun 09, 2004 10:15 PM
ST Model KA-V1000R lipo charger jbird Batteries and Chargers 3 Nov 11, 2003 07:38 PM
