If its slowing down like that even in level flight its 1 of 2 things 1. the incidence angle of wing and tail are positive or 2. your slightly tail heavy which I feel you are hence the sensitive elevator response you dont want a flat glide thats heading to a stall a good glide is slightly nose down and moving making the wing work and creating lift .
SteveW just throwing in 2 cents worth |
Latest blog entry: 4 days
Trimming and CofG
The link evo posted didn't work 4 me.
Try this: http://www.slnt.org/articles/gordys_...e_articles.htm Another from Mark Drela: http://www.charlesriverrc.org/articl...GMarkDrela.htm Funny how you find some conflicting info from some of the best pilots. It is a personal thing, but I think that Gordy's statement about "almost no down elevator when inverted" is a little on the tail heavy side, and prefer a small, comfortable amount of down elevator when inverted to be better. Also the dive test is only useful if you have a very stiff and rigid glider. David hobby's comments on "nose down/nose up" I feel is more about trim and flying speed than CofG IMO. He is right about the control inputs spoiling the glide though. Just my 2 bobs worth.
positive leading edge up in relation to aircraft centreline and leading edge down is negative the difference between the incidence angles of the wing to tail is called the decolage angle of attack is the angle of which the leading edge is presented to the airflow for example giving up elevator incerease the angle of attack of the wing .
SteveW |
Sorry Steve, I should've been more specific. I only notice it slowing down too much when facing into the wind. Yesterday was quite gusty, when there was no wind on the ground it just seemed to float along fine without dropping the nose. When I saw the trees moving and felt the wind blowing stronger - maybe in the 10knt range it slowed down, dropped the nose and then started flying again. I only noticed this when the glider was facing directly into the wind so thought it was just a wind effect.
With a power off hand throw - the glide is as flat as I could get it but the nose slowly drops as it gets further away, eventually landing. I haven't seen any mini stalls from shoulder height which makes me think it is trimmed ok. I wonder about the incidnce angles as everything is so floppy with the EPO. If I can convince the missus to get some video it might help explain it all better. Clovus |
Joined Jul 2008
1) when you say leading edge, you mean the wing leading edge, the stabilizer leading edge, or both, or ? 2) where is the aircraft center line? down the middle of the core center of the fuselage, front to back? Or half way back, at the center of the fuselage? Or? maybe it would be easier, if you had a glider, and could point to this and that, while referring to various things here and there, and it would be easily plainly obvious. Oh well. Until then, I guess I don't get it. My rookie fault, not yours. |
2 / the centre line of the aircraft is an imaginary line through the centre of the fuse some times called the thrust line in power aircraft. SteveW |
Hiya Guys,
I just thought I'd give a little bit of a update..... I was out flying around today, came in a little bit hot for a landing - was shooting long so I turned around to spot the landing when I realised there were a group of guys doing personal training about 10m's behind me. Anyway, I was just about down and had to goose the throttle - ended up hitting a tree trunk head on. The plane bounced down. I noticed it cracked at the widest point on the fuse, just where the canopy fits into the fuse. Why they chose that spot in amongst 6 soccer fields and a baseball diamond I have no idea. I could hear them sniggering after the accident. Funny though, I got the last laugh when I got to watch them dragging a keg attached to their waist by a chain across the grass with their bootcamp sarge huffing and puffing at them..... |
Yeah, A bit of CA and kicker and 5 minutes and she'll be right. This must be the 3rd of 4th time I have cracked the firewall behind the motor. I think the thrust angle might be off slightly. Today the WOT climb was an easy 45 degree angle, a bit more when the wind picked it up.
I have never crashed a plane so much and fixed it so quickly... EPO is cool! |
Come to think of it , I had to glue that top front seem between the canopy and prop when i got the Gilder , it was open and didn't seem to have any glue on it ??? Phuck !!!!!!! I'm sick of these Neanderthol wannabe Yobs !! playing or training on every bit of vacant land on the weekend and every evening after work. Our popular flying site is currently used every night by at least two footy teams and a soccer club to train , so they spend every evening digging up the public park so as to protect their precious ground for the big (Yawn) game on Saturday. That bootcamp crew sound typical , WANKERS !!!!! LOL
| Thread Tools | |
| HF Model: ASW28 Fully Molded, 3m | rthorne | Aircraft - Sailplanes (FS/W) | 9 | Jun 06, 2005 04:09 PM |
| ST MODEL Lipos? | OzDragonFlyer | Batteries and Chargers | 2 | Mar 14, 2005 03:21 AM |
| Motor for ST model YAK | TooLyr | 3D Flying | 7 | Oct 26, 2004 04:17 PM |
| Any Experiences with ST Model Lithiums? | CustomPC | Batteries and Chargers | 8 | Jun 09, 2004 10:15 PM |
| ST Model KA-V1000R lipo charger | jbird | Batteries and Chargers | 3 | Nov 11, 2003 07:38 PM |
