Nitroplanes / Art-Tech Eurofighter 2000 RTF Review
Nitroplanes EF2000 RTF is ready to take out to the field in about 45 minutes, and has everything short of receiver batteries included.
Wing span:25.5"
Wing area:325.7 sq in.
Length:38.5"
Weight:22.9 oz.
Wing loading:1.1oz sq ft.
Servos:3x 9g servos
Transmitter:Art-tech 4 channel FM
Receiver:Art-tech 6ch micro
Battery:3s 1600mah
Motor:Brushless inrunner
ESC:30A
# of Fans:1
Fan Dia.64mm
Fan Thrustapprox. 16oz (470g)
Manufacturer:Art-Tech
Available From:Nitroplanes.com
MSRP:$155
Over the last few years, the popularity and achievements of electric flight have progressed very rapidly. Two of the markets that have seen some of the largest growth are the foamy EDF (Electric Ducted Fan) and RTF (Ready To Fly) offerings. Art-Tech, manufacturer of those very things, has been around for a few years and produces quite a diverse range of products including R/C airplanes, helicopters, batteries, ESCs, gyros, servos and a slew of other assorted electronics. For those of us in North America, Nitroplanes.com carries quite a few of Art-Techís products, including the Eurofighter 2000 RTF kit featured in this review.
<font size=-2>Eurofighter Typhoon</font>
Eurofighter Typhoon
<font size=-2>Typhoon inbound</font>
Typhoon inbound
The EF2000 is marketed as a RTF, 95% complete kit so I expected a high level of prefabrication. I have never owned a, RTF package, and I found opening the box and inspecting the components quite fun. All of electronics come pre-installed, the components seem to be of decent quality, and all that was required was some final assembly.
<font size=-2>Box as it arrived to my doorstep</font>
<font size=-2>Lots of stuff packed inside that foam chunk...</font>
<font size=-2>Everything included in the kit</font>
<font size=-2>Battery, charger and DC wall unit</font>
<font size=-2>Art-Tech 4 channel TX</font>
<font size=-2>Front canards and optional simulator software/USB cable</font>
Kit includes/features:
  • Art-Tech 4 channel FM Transmitter
  • Pre-installed Art-Tech 6 channel micro receiver
  • Art-Tech 3s 1600mah lipo battery
  • DC charging unit
  • Pre-painted and decaled foam fuselage / wings
  • Pre-installed and painted pilot / canopy
  • Pre-installed 9g servos and linkages
  • Pre-installed Fan/Motor unit
  • Pre-installed 30A ESC
  • Instruction manual
  • Glue
Kit requires:
  • 8 AA batteries for the transmitter
Power system
A single 64mm fan unit with a brushless inrunner motor mounted at the factory powers the Eurofighter on the kit 3s 1600mah lipo. According to factory specs, the thrust output of the fan unit is in the 16oz range, which on paper should give the Eurofighter plenty of power. Bench testing showed my setup making just under 250W @ 20A on the stock freshly charged battery, and about 275W @ 24A on a 2200mah 20C pack that I also had in the workshop. Either way the stock 30A ESC is more then enough to cover the demands of the fan/motor combo.
<font size=-2>Fan unit/ESC</font>
Fan unit/ESC
<font size=-2>Fan unit/motor</font>
Fan unit/motor
<font size=-2>Battery</font>
Battery
I simply glued the wings and canards in place, installed the landing gear, plugged in the servo wires, charged up the battery and headed out for the maiden. If you've got some build/assembly experience, I'd bet you could complete the assembly in the amount of time it takes to charge the battery with the supplied wall charger (about 30 minutes for initial charge).
Main Wing
To attach the wings, I pushed the tabbed wing into a precut slot on the fuselage for both the left and right side. To ensure the wings were aligned properly, I kept the top / bottom of the wing flush with a ridge that runs the length of the fuselage. The servos and control linkages are already done at the factory, so once the wing was in place all that was left to-do was plug them in.
<font size=-2>Wings out of the box</font>
<font size=-2>Pre-installed horns and linkages</font>
<font size=-2>Completed wing assembly</font>
Canards
The Art-Tech Eurofighter comes with fixed canards, and to install them I slipped the tabbed end of the canard into a precut slot on the fuselage and glued them into place (just like the wing). Aligning the canards is done for you once the canard is fully inserted into the tab, but I still ensured everything looked symmetrical before I glued in place.
<font size=-2>Canards</font>
Canards
<font size=-2>Sliding into place</font>
Sliding into place
<font size=-2>Completed assembly</font>
Completed assembly
The only remaining step that is required to complete the fuselage is attaching the nose cone. I simply glued it into place after it was aligned appropriately.
<font size=-2>Before installation</font>
Before installation
<font size=-2>Nose cone glued into place</font>
Tail
Since itís a delta wing, there is no horizontal stab. And since the vertical stab is molded into the fuselage there is no assembly required. The rudder servo and linkages are pre-installed at the factory.
<font size=-2>Tail assembly</font>
Tail assembly
Landing gear
The steerable nose gear comes installed out of the box, so all that's left is to install the pre-bent mains which plug into a plastic base plate that is pre-mounted into the wing and which are held in place by 4 screws. For this step, I found it necessary to clean out some of the flash left over from the molding process with an exacto blade. It was preventing me from getting the gear to mount flush inside its housing.
<font size=-2>Landing gear out of box</font>
<font size=-2>Landing gear close up</font>
Radio Installation
All that remains for the builder to-do is to plug your servos into the RX. To gain access to the RX, start by removing the bottom 'cover' which retains and masks the electronic components installed underneath of it from the bottom side of the aircraft. Then plug your servo leads into the RX. I recommend you verify everything works as expected and then once you're satisfied everything is operational, pop the 'cover' back into place and secure with the provided screws.
<font size=-2>Bottom cover removed</font>
<font size=-2>Art-Tech 6 channel micro RX</font>
<font size=-2>8 AA batteries</font>
8 AA batteries
I balanced the model, charged the battery, checked the throws and glued the wing tips on. The battery took about 30 minutes to charge on the provided wall charger, and then I was off to fly! There is no mention of throws in the manual, so I feel it's worth noting that I did not use the stock settings for the control horns on the ailerons. I ended up adjusting them so that they were placed in the hole closest to the aileron itself (ie maximum throws).
<font size=-2>Charging battery</font>
Charging battery
<font size=-2>Battery Installed</font>
Battery Installed
<font size=-2>Balancing</font>
Balancing
<font size=-2>Completed model</font>
Completed model
The Eurofighter is a stable aircraft which scoots along nicely above 3/4 throttle. With the provided 3s 1600mah pack, Iím getting just under 4 minutes of full throttle flight. Unfortunately, I don't have any way to scientifically measure the aircraftís speed, but I would guess the straight and level passes are in the 45mph range and downwind speed passes are upwards of 55mph.
Having flown the Eurofighter in winds varying from 0 - 15mph, I think itís safe to say it handles them very nicely, and as with most of my EDFs I actually prefer to fly in winds of 5 - 10 mph; It helps to slow down and stabilize the aircraft on approach and during takeoffs.
Full throttle rollouts had my Eurofighter airborne within 10 - 25 yards (depending upon the runway surface) with plenty of momentum for a nice scale climbout. Much like my J-10 (also a delta wing w/ canards), the plane didn't want to become airborne on its own, so I found myself needing to apply a good amount of up elevator to get the plane in the air.
Landing the Eurofighter is no different then any other EDF with the exception of the cool nose high attitude the canards give it on approach. Simply chop the throttle to about 1/8th, line up on the runway and grease her in.
The EF2000 rolls incredibly well, and handles nicely inverted with a slight bit of up elevator. I've found I can eek out a single loop from flat-out level flight, but the plane much prefers to enter them via a shallow dive on the stock 1600mah pack.
Absolutely not. The Eurofighter is fast, nimble and provides no self-righting characteristics. All of which are essential to the success of a trainer aircraft.
<font size=-2>Tail feathers</font>
Tail feathers
<font size=-2>Taxi to the active</font>
Taxi to the active
<font size=-2>Eurofighter smile</font>
Eurofighter smile
<font size=-2>Pilot included is pretty cool</font>
<font size=-2>On the hunt</font>
On the hunt
<font size=-2>Over the gate</font>
Over the gate
<font size=-2>Overhead</font>
Overhead
<font size=-2>On patrol over the secret test grounds</font>
<font size=-2>The real dark knight?</font>
<font size=-2>Just cruisin</font>
Just cruisin
<font size=-2>Another overhead</font>
Another overhead
<font size=-2>On short finals</font>
On short finals
<font size=-2>Turn 'n Burn</font>
Turn 'n Burn
<font size=-2>Taking off</font>
Taking off
<font size=-2>Author shot</font>
Author shot
Eurofighter in action  18.97 MB
I find it hard to believe that for about $150, you can purchase a plane that looks great, assembles easily, flies well and everything short of some AA batteries is included right there in the box for you. For the price, I think it's a great bang for the buck, and I am glad to have it as part of my fleet.
  • Nice scale looks
  • FAST assembly
  • Pre-painted/installed pilot
  • Cost per grin (CPG) factor
Dislikes:
  • Fixed canards (wish they were functional)
  • Servo buzzing
  • Instruction manual (poor english, no rec. for control surface throws, etc)
Thanks to nitroplanes.com for supplying the plane for review and to Jon Barnes and Terry Riley for the fine media work.
Old Mar 18, 2009, 05:27 PM
Bombay is offline
Find More Posts by Bombay
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Don:
Very nice review. Sans landing gear the plane would really have a nice silhouette, but it doesn't look like she would be a good belly lander with the airscoop and servo arms positioned as they are.
BTW - how did you manage to slow down drastically upon touchdown on the last landing, down ele after the gear touched?
Rob
Bombay is offline Find More Posts by Bombay
Old Mar 18, 2009, 05:41 PM
Shorty is offline
Find More Posts by Shorty
United Kingdom, England, Blackpool
Joined Sep 2002
help with movements
Hi Don,
I've just bought 1 of these ef2000's today and built it this evening. Like you said the instructions are simple to say the least. I notice from your review you mention 1-2mm up reflex to be setup, thanks for that, what a photo in the manual!
Most importantly can you help me with movement setup. My elevons only move about 3mm either way, which I think may not be enough, can you advise me of the settings you used.
Many thanks and great review by the way!
Regards,
Nick.
Shorty is offline Find More Posts by Shorty
Old Mar 18, 2009, 06:32 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
I got mine on max movement and I believe he mention the same thing. Most outer hole on servo horns and most inner hole in control surface horn. I also glued small plastic ball link to eliminate some pushrod flex.
I find that even with the lipo as far back as possible in the battery compartment, its still a bit nose heavy, mite also be because I replace the stock RX with Spektrum AR500 that I position just in front of the nose gear.
Anyhow, VERY NICE REVIEW & VERY NICE VIDEO & VERY NICE FLYING.
freechip is offline Find More Posts by freechip
Old Mar 18, 2009, 06:59 PM
Shorty is offline
Joined Sep 2002
Big thanks
Thanks for that,makes sense, i get straight on to it now,hope to maiden tomorrow!
Ta,
Nick.
Old Mar 18, 2009, 07:38 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Here's my maiden,
EF2000 (2 min 14 sec)
Old Mar 18, 2009, 08:07 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Upon closer review of you're review and better look at you're pictures, I was wondering if this was a recent model or earlier version and just took awhile for you to do the review. (very nice review by the way)
#1 The canards dont even look like the same materiel as mine and mine dont even look like the same material as the plane.
#2 You either did not install or did not have (disturded pieces) that mount just under the canopy in the line grooved in the side of the fuse.
#3 The ESC does not look like mine (and what's the extra 2 wires coming out of it)
#4 You mention 40-45mpg straight line passes, I too have no way of proving it (no gps or radar gun), But I did gps confirm 58mph on my truggy and this EF2000 look like it was a bit faster. I read somewhere that this mite do 70mph but I have yet to see this for myself. But regardless of its true top speed, its still pretty fast and cover ground or air space quickly. One can easily and quickly go out of range (1000ft stock TX/RX) if one is not carefull.
Main reason for my radio swap with my full range spektrum.
Old Mar 18, 2009, 08:38 PM
Shorty is offline
Joined Sep 2002
disturbs!????
I have them in my kit too but ive not installed them. There a line/tiny slot but am i supposed to cut the slot out more so a can fit them or just push them in?
regards,
Nick
Old Mar 18, 2009, 08:49 PM
marcelo3d is offline
Find More Posts by marcelo3d
marcelo3d's Avatar
USA, CA, Santa Cruz
Joined Mar 2008
Very nice review.
Cross-link to the other EF2000 review/thread:
http://www.rcgroups.com/forums/showthread.php?t=880646
Marcelo.-
marcelo3d is offline Find More Posts by marcelo3d
Old Mar 18, 2009, 09:56 PM
dawnron1 is offline
Find More Posts by dawnron1
"Have Glue - Will Travel"
dawnron1's Avatar
Ft. Worth, Texas
Joined Jan 2004
Great job on the review Don! Kudos to your photographer and videographer!
Ronnie
dawnron1 is offline Find More Posts by dawnron1
Old Mar 18, 2009, 10:30 PM
gp125racer is offline
Find More Posts by gp125racer
Lipo abuser ... smoke on!
gp125racer's Avatar
Joined Feb 2005
Thanks for the comments fellas!
Bombay:
I was able to slow down as the surface there is loose gravel/small pebbles .... the tires dig down into it and slow me down pretty well. It also is what made the takeoff roll so long in the video.
Shorty:
Use max throws (all the way in) and just be easy on the sticks if you're using the stock transmitter ... remember we don't have any expo
Freechip:
Your bird looks nice! Not sure why we have different speed controls, and also what those two extra wires on mine are .... different connectors maybe? I'm not a great judge on speed, and I don't have a radar gun so I just guesstimated those numbers Also, I got this plane a few months back from nitroplanes so there might be a new version available??
Ronnie:
Thanks! I can't wait to see some photos from your new rig. How are you likin' it so far??
Don
gp125racer is offline Find More Posts by gp125racer
Old Mar 18, 2009, 10:42 PM
Bob Reynolds is online now
Find More Posts by Bob Reynolds
Tucson, AZ, USA
Joined Nov 2000
Mine had a few problems.
The pre installed servos at neutural were not pointing the same way. In other words, UP always gave ROLL.
The control throws were way too much.
I had to open the turtle deck to get to the rudder/steering servo to correct the throw and to center the nosewheel.
The installed wiring was run all over the place into the inlet duct and was not neet and tucked into the housing like it should have been. Tucked mine in and the duct is very clean - well worth the effort.
The radio and receiver had no indication of what channel they were on. Some research through my JR instruction book found that the channel was 55. Now I can fly at a frequency controlled field. There weren't any adjustments such as end point and expodential. Replaced with a Hitec 555/JR tran.
Steering is a joke. The inside diameter of the wheel bearing is about twice as large as the nosewheel wire thereby allowing the plane to go any where except where the steering is commanded.
The plus side.
Once airborn it does extremly well. It looks good.
I've moved the stock battery as far back against the nose gear leg (still allowing steering) and it's still nose heavy according to the directions. But it flies OK.
Would I buy another? Yes, if I could buy without the radio AND realizing that a through search is required to correct the little things that made it through the non exsistant factory quality control.
Bob Reynolds is online now Find More Posts by Bob Reynolds
Old Mar 19, 2009, 02:59 AM
mickydee is online now
Find More Posts by mickydee
Hemet, California, United States
Joined Aug 2001
Hi,
Mine died on it's second flight due to the crappy radio. Personally, I'd rather spend my money elsewhere.
Mickydee
mickydee is online now Find More Posts by mickydee
Old Mar 19, 2009, 02:37 PM
EzEd is offline
Find More Posts by EzEd
NTSB most wanted
EzEd's Avatar
O-Town, FL
Joined Jun 2003
Originally Posted by mickydee
Hi,
Mickydee
Which version of the radio did you have, the 72m or 2.4g?
EzEd is offline Find More Posts by EzEd
Old Mar 19, 2009, 06:58 PM
Joined Aug 2001
Hi,
72 MHZ
Good luck!
Mickydee
Wanted WTB: Omei 2000 EP Kit or RTF hepavirus Aircraft - Electric - Airplanes (FS/W) 1 Jan 15, 2008 08:55 PM
Mirage 2000 EDF kit - Kamdax realdeal Aircraft - Electric - Airplanes (FS/W) 4 Jan 30, 2005 08:04 PM
Graupner BO 209 RTF kit forsale. stealthy Aircraft - Electric - Airplanes (FS/W) 6 Jan 04, 2005 06:32 PM
Logo10 kit arrived, need some setup help. PierreVC Electric Heli Talk 14 Jul 17, 2002 03:42 AM
Eurofighter 2000 / offshore KAMarks Electric Ducted Fan Jet Talk 12 Jan 09, 2002 03:35 PM
