Old Dec 15, 2008, 05:07 PM
SafeLandings is offline
Find More Posts by SafeLandings
It was a GLITCH! Honestly!
SafeLandings's Avatar
Stourport on Severn ,Worcestershire, United Kingdom
Joined Dec 2007
Build Log
My RC Pusher Autogyro designs
Well my PT25 is basically finished and I just cant afford to press on with my Large DAG right now.
I needed a new project to keep my mind active during these cold winters evenings and I have been really impressed with Peter O's latest creation so I thought I would have a go at my own pusher gyro.
I cant buy any materials at the moment so I have had to use what I have in my workshop which is basically balsa and ply. I have DAG blades, an electric motor,esc and batteries so it has been roughly designed around these. My thoughts are if I can build a pusher with an AUW lighter than my R2 then there is no reason why it shouldnt fly??
The only trouble is I have never built, flown or even seen a pusher autogyro fly so I am totally in the dark with this subject.
I know there are experts out there so I am calling on you guys to point me in the right direction if you wouldnt mind please
Things like thrust lines, hang angles, mast heights,motor heights etc, etc,etc
Heres a few photos of what I have done in a few evenings..if you see that I have gone about something the wrong way please tell me I wont be offended.
Your thoughts and ideas will be greatly appreciated.
Regards Rich
PS thanks for the photo Peter
SafeLandings is offline Find More Posts by SafeLandings
Old Dec 15, 2008, 10:29 PM
Forensic Flyer is offline
Find More Posts by Forensic Flyer
Bedford Indiana
Joined May 2004
Rich. I don't know squat about pusher gyros but what you have done looks very, very nice. I have only heard they are more difficult to fly as an RC. I did build the EXP kit offered by Hippo but never got to maiden it so I don't know how it would have done. Good luck on your project. I will be watching here for progress. Merry Christmas.
Chuck
...somewhere in Indiana...
Forensic Flyer is offline Find More Posts by Forensic Flyer
Old Dec 16, 2008, 02:03 AM
HobbyCAD is offline
Find More Posts by HobbyCAD
Ozzie GyroNut
Hervey Bay, Australia
Joined Mar 2007
Hi There,
Download Mickey's BeGi plans at http://www.mickeynowell.com/sitebuil...i_12_18_07.pdf
Use his angles of thrust, balance, and so on. This will help you to get yours going.
Regards,
Francois
HobbyCAD is offline Find More Posts by HobbyCAD
Old Dec 16, 2008, 05:12 AM
PeterO_UK is offline
Find More Posts by PeterO_UK
PeterO_UK's Avatar
Joined Aug 2006
Originally Posted by HobbyCAD
Hi There,
Regards,
Francois
Bearing in mind Rich is using his spare DAG blades I would suggest starting from some of Jochen's 3 bladed designs rather than one of Mickey's a 2 bladed design. I know Jochen has experience of using both 2 and 3 bladed heads on similar airframes and there are differencies.
When asked about 2 vs 3 bladed Minimums Jochen said "flying the three-bladed Minimum is fun, flying the two-bladed version is hard work."
PeterO_UK
PeterO_UK is offline Find More Posts by PeterO_UK
Old Dec 16, 2008, 05:14 AM
PeterO_UK's Avatar
Joined Aug 2006
WOW Rich, it's look like it is already almost ready to fly
It's nice to know I've inspired someone to do something, but Jochen deserves the real credit.
Watching with interest,
PeterO_UK
Old Dec 16, 2008, 05:20 AM
mnowell129 is offline
Find More Posts by mnowell129
I'm not as bad as they say.
Joined Nov 2004
PeterO_UK
Just to be clear, this statement applies to tilting spindle type heads. BEGi uses a swashplate and flybar and is quite stable compared to a two bladed TS head.
Francois' suggestion about thrust angles, etc are still valid.
Comparing TS to swashplate heads is comparing apples to oranges.
mnowell129 is offline Find More Posts by mnowell129
Old Dec 16, 2008, 05:27 AM
PeterO_UK's Avatar
Joined Aug 2006
Indeed, I was probably thinking more of the fact Rich will be using a TS head rather than a swashplate when I suggested starting from Jochen's designs would be more appropriate than starting from your designs.
PeterO_UK
Old Dec 16, 2008, 05:34 AM
Boneswamped is offline
Find More Posts by Boneswamped
RC Group therapist
Boneswamped's Avatar
DeRidder LA.
Joined Nov 2008
Rich,
That is looking good man! Mickey speaks the truth brother. 2-blade teetering can be done, but the amount of work required to fly it will most likely ruin the fun. A true Teetering two blade is like the holy grail of R/C autogyros. If you must have two blade you should definately go with the setup that Mickey designed and uses. I would just go for the three blade with the flex-plate head myself(primarily because I'm lazy). Keep up the posts, she's looking the part for sure!
Regards,
-Mike
Boneswamped is offline Find More Posts by Boneswamped
Old Dec 16, 2008, 07:20 AM
JochenK is offline
Find More Posts by JochenK
JochenK's Avatar
Joined Jan 2005
Rich,
you seem to be aiming at something like the DAG R2 in size and weight. Why don't you start off with a DAG R2 head, keeping all the angles and control throws and whatnots?
The thrust line of your motor shuld be parallel to the 'axis' of your fuse, and you should make the motor position adjustable vertically and to the right of the gyro. On a pusher the distance between the motor and the c.g. is very small, and it's far more efeective to offset the motor then to tilt it. I can explain that in detail, if you want to, but that's a post of its own. You probaly have to offset the motor to the right, to compensate the prop wash effects on the tail unit. If you don't know this video
http://www.rcgroups.com/forums/showt...93#post7087583
have a look at it.
The horizontal position of the c.g. should be before the thrust line of the rotor, otherwise the gyro will become unstable around the vertical axis. If you are using full head control - the two servos indicate that - the c.g. should be before the thrust line, even if you are pulling up elevator.
I'd put the motor position about a centimeter or so above the c.g. for starters. If your gyro has a tendency to climb too steep, move the motor up a bit.
The tail unit should have a minimum of 3 to 5 cm clearance to the prop. If your c.g. is too far out front, you can move it further back without problems.
That's the basic advise I can give you at the moment. It would be nice, if you posted some more details concerning dimensions and weight and so on.
Jochen
JochenK is offline Find More Posts by JochenK
Old Dec 16, 2008, 08:10 AM
PeterO_UK's Avatar
Joined Aug 2006
Jochen,
When Rich asked me about CofG on my Minimum I produced the attached picture. I suspended the model from the top of the mast, and from the two collets at either end of the 8mm tube.
I think its CofG is in about the right place ?
PeterO_UK
Old Dec 16, 2008, 08:47 AM
Joined Dec 2007
Wow gents ..thanks for all the info links and videos etc lots of information for me to look through.
So to get the CG position I really need to build the boom and tail feathers, from this I can start to determin the CG posion and thus the motor height etc
For now I will stick with the 3 blade head as I have one to hand, as for the teetering 2 blade head or the swash plate type..that would be nice but I dont think I have the skill to build or fly such a gyro at this moment in time.
I will post some photos later on with some dimensions and weights..the rotor span will be around 50" for now..if once the gyro is built and they dont look look correct I will alter them to suit...kind of 'suck it and see'. will also be load sharing type head like alot of others!
Thanks again chaps
Regards Rich
Old Dec 16, 2008, 09:57 AM
JochenK is offline
JochenK's Avatar
Joined Jan 2005
Peter,
yes, looks alright.
Jochen
Old Dec 16, 2008, 03:59 PM
Joined Dec 2007
I managed to get a little done today, I have boxed in the mast, started on the load share head, made an alloy UC up and started the boom.
I am unsure as to whether i should make it a tail dragger or tricycle UC?? could anyone suggest the best option or is it personnel tastes?
I have also noticed on most pushers that the fins are quite large, does this have to be in the propeller wash to help things?
So a few dimensions etc
Mast tilt back is around 8 degress and from the base of the fuz to the top of the spindle mounting plate is 470mm. From the centre line of the mast to the nose is 370mm and the boom has been made longer than needed as Im not sure on its final length??
Its weight as you see it with one servo mounted ,uc and alloy rotor spindle is 500g..which I think is a touch on the heavy side.
Regards Rich
Old Dec 17, 2008, 03:26 AM
JochenK is offline
JochenK's Avatar
Joined Jan 2005
Rich,
as the motor position of a pusher is higher than that of a tractor, it's better to use a tricycle configuration. You don't have to worry about the gyro toppling over.
My Minimum and Nanomum have the horizontal stab more or less directly in the prop wash, on the Micromum the position is very much lower. All of them fly. Just build something that looks sensible to you.
You haven't mentioned your rotor diameter yet, so it's hard to tell about the weight of your gyro.
Jochen
Old Dec 17, 2008, 09:48 AM
Joined Dec 2007
Jochen,
Sorry..I forgot to mention the most important thing! ..the blades I have to hand have a 50" rotor disc diameter, I have got some longer blades I could use which would give me a diameter of aroung 58"...the smaller ones are covered and ready for use.
Thanks for the info on the tailplane, I will go down my shed and start shaping some balsa sheet..I will post some photos later.
Regards Rich
Pusher motor help needed pulquijet Power Systems 3 Nov 02, 2005 05:51 PM
Alert Gyro Help Needed silverwing Micro Helis 3 Sep 20, 2005 01:31 PM
My 2nd. electric aircraft. help needed Vagabond324 Power Systems 2 Mar 11, 2005 01:41 PM
Question Futaba GY240 Gyro Help Needed kagreen2k Micro Helis 10 Jul 19, 2004 02:34 PM
