Old Dec 14, 2008, 09:14 PM
United States, IN, Fort Wayne
Joined Oct 2008
Can't replace prop shaft...
Not sure what to do here... I tried to 'unscrew' this chrome part in the video with no luck... what do I do? Thanks a million...
Kevinfred is offline Find More Posts by Kevinfred
Old Dec 14, 2008, 09:16 PM
Joined Oct 2008
http://www.youtube.com/watch?v=1f6Gwu0PReE
Old Dec 14, 2008, 09:28 PM
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
Is the grubscrew stuck or stripped?
If it is stuck you can heat the piece up and that sometimes helps. If its stripped you can try a new wrench or cut your old one down as it can become rounded.
If that fails you can try and glue the wrench to the grub but I have not had luck with this, others have. You can buy one of those stripped screw removers. Or just simply drill out the grubscrew.
Atom1025 is offline Find More Posts by Atom1025
Old Dec 14, 2008, 09:35 PM
Joined Oct 2008
where is that at?
Old Dec 14, 2008, 09:43 PM
Atom1025's Avatar
Sacramento
Joined Jun 2005
There are two types of adapter Setscrew(grub) types and collet types. Setscrews use a screw to bite into the shaft while collets use a compression on the shaft.
http://www3.towerhobbies.com/cgi-bin...&I=LXMSF1&P=ML
What do you have?
Collets can get stuck but simply prying on the outer retainer breaks it lose.
Old Dec 14, 2008, 09:45 PM
Yea..When mowers fly!
Jay-viator's Avatar
The White House?
Joined Apr 2008
Is it bent or something? That looks like an outrunner from a T-28, I think you'll need a APC prop. Please give more detail as to why your wanting to remove it?
Jay-viator is offline Find More Posts by Jay-viator
Old Dec 14, 2008, 09:48 PM
Doing it in the Lateral Axis
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
yea..why do you want to remove it?
modfly is offline Find More Posts by modfly
Old Dec 14, 2008, 09:49 PM
Joined Oct 2008
oops... spaced that... the prop shaft is bent on this J3 Brushless Cub from Parkzone...
Old Dec 14, 2008, 09:59 PM
Multirotors ROCK!
Get Real's Avatar
Illinois
Joined Feb 2006
Theres a small set screw for that type of prop adapter,use an allen wrench to loosen the screw then the prop adaper will come off. The screw will be behind the threads and disc area of the adapter.. you can see it in the video at about 6 second mark. Its a solid adapter without cone.. heres what it looks like removed Adapter removed .
Get Real is offline Find More Posts by Get Real
Old Dec 14, 2008, 10:04 PM
Jay-viator's Avatar
The White House?
Joined Apr 2008
Here ya go Kevin,Motor shaft: 370 Outrunner
http://www.parkzone.com/Products/Def...ProdID=PKZ4518
[PKZ4518]
Retail: $3.79
Available For*: $2.99
Take the motor off the plane, look on the backside of the motor, rear part of the shaft there's a "C" clip you take loose and the whole shaft will slide out.
Old Dec 14, 2008, 10:16 PM
Jay-viator's Avatar
The White House?
Joined Apr 2008
Here's replacement adapter and spinner:
Prop Adapter & Spinner Set: J-3 BL
http://www.parkzone.com/Products/Def...ProdID=PKZ1013
[PKZ1013]
Available For*: $5.99
Old Dec 14, 2008, 10:18 PM
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
Thats the nice thing about these PZ planes..readily available parts
Old Dec 14, 2008, 10:33 PM
Jay-viator's Avatar
The White House?
Joined Apr 2008
Yea, $9 and whatever for shipping, you'll be back in business. Check your local hobby shop, they may even stock PZ gear.
Old Dec 15, 2008, 05:47 AM
Joined Oct 2008
thanks sooo much! Don't laugh but what's the diff. between these parts and the prop shaft that I ordered?
http://cgi.ebay.com/ParkZone-Prop-Sh...QQcmdZViewItem
Old Dec 15, 2008, 07:52 AM
Beaumont, TX
Joined Feb 2007
That looks to be the replacement shaft for the geared, brushed motor version. Yours is the brushless version.
Pete Miller is offline Find More Posts by Pete Miller
Discussion Bent shaft on turnigy, can I replace the shaft? Erik S. Electric Plane Talk 5 Mar 16, 2008 12:12 PM
AXI or hacker outrunners.... can you replace the shaft? FlybyPDX Power Systems 6 Mar 13, 2005 11:13 PM
Can't find folding prop for Ascent (odd motor shaft size of 3mm) ptglass Electric Sailplanes 5 Nov 22, 2004 02:20 PM
How hard is it to replace a AF 05 prop shaft. twinster2 Electric Plane Talk 7 Aug 11, 2002 08:50 PM
TM - Bent prop shaft or fix or replace? (m100?) dpoles Parkflyers 6 Jun 20, 2002 10:53 PM
