Thanks! Maybe a bit too much. Or i need a bigger pond. There is one on the other side of the street, but i don't see any access. May need to make my own...
Here is a video: http://www.rcgroups.com/forums/showt...8#post13128176 |
OK, took The PT over to the pond. The pond is about a mile long, 100 yards across and has a dog leg at one end that is about 200 yards around. I stuck to the dog leg for this run. Wanted to run it for a few minutes at full speed to see how heat is.
No problems with heat. But turning while under way is slow. Or i guess i should say wide. If you stop you can turn on a dime, but she only turns in an arc while going straight. That should level out once i have the rudders working. I have a video here: http://www.rcgroups.com/forums/showt...6#post13137080 The video and pics are low quality because we used our pocket camera. The camcorder uses a proprietary format that i can't edit on my laptop and i can't upload a 500meg HD video anyway ![]() The pic is just a screen capture, but you can see that she really gets up there! That's full throttle. It's a little fast for scale, but i don't need to keep it "floored" all the time either... The wake is incredible but you can't really see it on the video/pic. I could actually see waves hitting the beach! I ran it for about 10 minutes total. The batteries still seem to have plenty of juice. The motors were warm, but not too hot to touch. The ESC was also warm but by no means too hot. I would have run it longer, but the wife and daughter were ready to go. You can hear our daughter in the video. Should have some better video and pictures later. Please ignore the tape... I don't have all of my tools here so i can't water-proof the esc, radio, etc... but the packing tape over the hatch is really doing the trick! |
It's a Vantec: http://www.vantec.com/rdfr.htm
Thanks for the info, i'll look at those next time. This ESC does what you describe and a bit more. It's used in robots, subs, etc... I would have rudder control, but my cheap receiver does not put out enough power to run the ESC and SERVO at the same time. Vantec is sending me a small amp that will fix that. The instructions say that some receivers will work with just a Y connector. My receiver just wasn't one of those. |
| Thread Tools | |
| Discussion imex PT 109 vs proboat(old midwest)PT 109 | aslvrfrostcsvt | Scale Boats | 15 | May 22, 2008 10:32 PM |
| Yet Another, GWS Me-109 first warbird | Aceshigh84 | Parkflyers | 2 | Dec 14, 2004 07:16 PM |
| yanq (aka yet another novice question) | mutron | Batteries and Chargers | 6 | Apr 16, 2004 08:16 AM |
| Yet Another GWS 109.. | TheLost | GWS (Grand Wing Servo) | 12 | Mar 23, 2004 01:03 PM |
| Just can't build yet another Spitfire ? | ChrisP | Scale Electric Planes | 0 | Jun 25, 2001 04:42 AM |
