Old Mar 02, 2003, 11:44 AM
Biggles604 is offline
Find More Posts by Biggles604
Blissfully Ignorant
Biggles604's Avatar
Port Moody, BC, Canada
Joined Oct 2002
Problem with charging NiMH cells on a Hitec CG-340
I've got a CG-340 which I have used to charge my AE600 cells many times with no problem. I just bought a pack of HECell 1100s and whenever I charge them the charging status light goes out after a short while, making it look like I haven't touched the start button. I can press the start button, but I am afraid to put too much charge into the cells. Has anyone else had this problem?
Steve
Biggles604 is offline Find More Posts by Biggles604
Old Mar 02, 2003, 11:58 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
What do you mean by "a short while". In NiMH mode the charge light does go out when it is complete i.e. there is no trickle. Are you sure it is not just full ?
OTOH perhaps your new pack just needs a slow charge or two first to form it and get it ready for fast charging. Of course you can't do that on the CG340 because it has that 2 hour cut-off.
Steve
steve lewin is offline Find More Posts by steve lewin
Old Mar 02, 2003, 03:19 PM
Blissfully Ignorant
Biggles604's Avatar
Joined Oct 2002
I have some HEcell 1100s and I had them on charge at 0.2C, which should have been 5 hours, I checked at about 4.5 hours, so it may have been that I had a lot more charge left on my batteries (It was my first flight on them yesterday with my Slowstick and I brought it down after 25 minutes because ot was dark)
What's the 2 hour cut off?
Steve
Old Mar 03, 2003, 02:27 AM
N. Staffs, UK
Joined Jan 1997
From the instructions that came with my Hitec CG340 / Capabilities and Specifications
"Shuts down after 120 minutes"
It is designed as a fast charger. It will not charge for longer than 2 hours in one go. Seems clear what happened .
For slow charging you will need a different charger. I bet the CG340 will be just fine at around 1A.
Steve
help with Hitec cg-340 pcpacker Batteries and Chargers 2 Feb 13, 2003 07:28 AM
Hitec CG-340 & Radioshack 25 AMP PS On Special Right Now Double Dutch Batteries and Chargers 2 Jan 31, 2003 11:47 AM
Charge leads with Hitec CG-340 and other stuff konaboy Batteries and Chargers 2 Nov 18, 2002 12:14 PM
FS NIB Hitec cg-340 charger and 2-1300 nimh 7 cell packs Etonic Aircraft - Electric - Airplanes (FS/W) 0 Aug 18, 2002 10:33 AM
