Dec 13, 2008, 01:04 PM
Motor City
Joined Dec 2004
Where to start? Well, if you'd like to build off a nice fiberglass hull, there are several available from Microglass up to 1:16 scale.
I think we're going to need a bigger bathtub...
But this one will be a tad larger... more on that later! But a scratchbuilt hull will be needed. And where better to start than a set of original builder's drawings from Paddlewheels & Props? ("Diesel Harbor Tug").
Note that such drawings do not show how to build a model! But there is nothing like original drawings to work from to get your details right.
My first step is to ignore the drawn hull lines and sections... yes, many just photocopy/enlarge/reduce these to use directly as templates to make frames... but I want to get the geometry in CAD where I can do a lot more with the lines. And for that, I go directly to the Table of Offsets... a rather confusing table that once decoded, lets you draw all the body plan sections. But watch out! The data is recorded in feet-inches-eighths... and in this table, redrawn in 1951 from the original early 40's drawings, several lines are off by a foot. Who knew? And I wonder if there are real tugs out there with the deck a foot higher than planned- which is what this error produces!
Note that the sections do not necessarily represent actual frames on the ship. The naval architect follows standards and divides the hull shape into usually 20 stations (only 10 here) for calculations on volume/displacement/stability etc. Others will create drawings as needed for each of the 33 actual frames used on this tug... but we modelers can usually be happy to use the body plan's stations for a model's frames.
Also, these lines represent the "molded" shape- the volume INSIDE the hull's plating or planks. No big deal on a ship with thin plating, more of an issue on a wood planked ship, where the hull planking is quite thick.
>>> Oops, wrong- of course it's important! The lines reflect NEARLY the outside of the hull for a steel ship... but the modeler needs to offset this line by the substantial thickness of his planking on the model when creating the frames.
The lines also reveal things like the deck's crown at center, and knuckle or bearding lines. Many ships have near-vertical plating from the gunwales and down for a bit-- easier to weld rub rails onto-- and the line where this transitions to the curved hull shape is the "knuckle".
My next steps are to take the drawn lines (drawn at 1:1 scale, BTW!), scale them as needed in CAD, and then develop the actual keel and ribs' shapes. I'll also lay in a datum plane which represents the building board, as the hull will be built upside down with the ribs attached to the board.
Reason: Correcting dumb statement!
