Old Mar 02, 2003, 03:56 AM
Wollongong, Australia
Joined Feb 2003
How to repair Tiger Moth engine mount?
Flying about an hour before sunset tonight, I lost my Tiger in the sun and when I could see it again and work out which direction it was going I flew it into a power line. It nosed in from about 20' and broke the engine mount stick clean off at the firewall.
Any ideas how to repair this? I'm thinking I might drill about 1/2" into each piece and join them with a 1" long piece of carbon rod that I have. However not sure how to get the correct alignment if I do that , try my luck I guess.
Anyone have any alternative suggestions?
Thanks, Bernie.
bernie01 is offline Find More Posts by bernie01
Old Mar 02, 2003, 07:33 AM
Pat Daily's Avatar
United States, VA, Chesterfield
Joined Mar 2001
Here is how I did it. I drilled a hole in the mount that remains in the plane and put in a 2mm carbon rod and then drilled a hole in the broken piece, glue it all together with 5 min epoxy. Works well.
Pat
Pat Daily is offline Find More Posts by Pat Daily
Old Mar 02, 2003, 10:39 AM
MrFlyer's Avatar
Abbotsford, Canada
Joined Sep 2002
I actaully dug the piece out of mine. It wasn't pretty but it worked. I used Pro bond to glue the new one and eyeballed the angle. No problems.
MrFlyer is offline Find More Posts by MrFlyer
Old Mar 03, 2003, 01:13 AM
galloping gimp's Avatar
Ohio, USA
Joined May 2002
Bernie-
When I broke my TM's motor stick, I did THIS.
- Jeff
galloping gimp is offline Find More Posts by galloping gimp
Old Mar 03, 2003, 01:18 AM
Inbox is almost full
LESLIEx317537's Avatar
Long Island, New York
Joined Nov 2002
I used a round wooden chopstick and now I can use a Dual IPS or Single IPS without having to rotate the stick 90 degrees.
My corsair also uses a round chopstick to mount to the firewall.
LESLIEx317537 is offline Find More Posts by LESLIEx317537
Old Mar 03, 2003, 03:27 AM
Joined Feb 2003
Thanks.
Gentlemen,
thank you all for your responses. I had more time to research this problem via the search engine today and marvelled at the variety of approaches taken; from the 'CA/epoxy the broken bits together 'approach to the elegantly engineered approach of Jeff/Doppler.
In the end I adopted a quick and effective fix; I drilled a small hole approx. 1/2" into both the firewall stub piece and the engine mount piece, then cut a 1" piece of 0.055 piano wire that I had left over from making a slightly beefier undercarriage. I then epoxied the stick back together using the wire piece as a 'dowel joiner'. The slight flexibilty of the wire afforded me a chance to slightly increase the thrust line angle, as the model turned left as originally built. Of course this robust fix means that I'll probably just bend the prop shaft next time, as I doubt it will break at the same place agin! Thanks again.
Regards, Bernie.
Templates for Tiger Moth Motor Mount galloping gimp Parkflyers 10 Feb 05, 2004 10:22 PM
Tiger Moth Motor Mount Stick ml0126 Parkflyers 10 Oct 10, 2003 05:51 PM
tiger moth IPS mount Zoom_b5 Parkflyers 4 Jan 10, 2003 05:19 PM
Tiger Moth IPS mount alternatives? rc_golfnut Parkflyers 4 Jul 12, 2002 02:22 PM
How To Bend Tiger Moth Elevator/Rudder Without Breaking? segal3 Parkflyers 3 Jan 18, 2002 04:48 AM
