Old Dec 12, 2008, 05:05 PM
kestasxxx is offline
Find More Posts by kestasxxx
kestasxxx's Avatar
Baltic States
Joined Jun 2008
RC TX & RX (not video)range test results for FPV.
Hello.
I this week i tested TX&RX.I have only know distance for FPV. Test results in the ground(not flight)
Conditions are as follows:
1.There must be a direct vision (not to be barriers).
2.Measured the distance to the ground.
3. Is measured accurately (driving under the speedometer)
4. Measure the first to link the loss or disruption
5.Measure the full connection to the disappearance (if possible)
6.Transmiter antenna and receiver antenna should not be closed no side effects.
7.Data write as follows:
a) transmitter model
b) The receiver model
c) The first disruption or disappearance of communication distance
d) Complete disappearance of communication distance
I think this is not end...
Distance (meter)
More results coming soon....
(Sorry from my english)
kestasxxx is offline Find More Posts by kestasxxx
Old Dec 12, 2008, 05:10 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I'd suggest you change the subject to include "R/C" e.g. "R/C TX & RX.... "
Otherwise people will come here looking for wireless video Tx/Rx range.
Was the testing done on flat ground, or with one end on top of a high point
somewhere? How high above the ground was Tx and Rx?
What's the difference between the two colored bars next to each combo?
ian
Daemon is offline Find More Posts by Daemon
Old Dec 12, 2008, 05:17 PM
kestasxxx's Avatar
Baltic States
Joined Jun 2008
All TX&RX I tested in even reservation position.
Collor bars:
Old Dec 12, 2008, 06:16 PM
Mr.Pibb is offline
Find More Posts by Mr.Pibb
Mr.Pibb's Avatar
Lewis Center, OH
Joined Jun 2006
Interesting!
Are the Spektrum radios you used the lower power European versions?
I wonder why the DX7/AR9000 combo didn't work as well as the 9303/AR9000 combo. I thought they had the same transmit power.
Mr.Pibb is offline Find More Posts by Mr.Pibb
Site Sponsor
Old Dec 12, 2008, 06:48 PM
typicalaimster is offline
Find More Posts by typicalaimster
typicalaimster's Avatar
United States, CA, San Diego
Joined Jan 2005
I'd love to see a Futaba FASST system in there.
typicalaimster is offline Find More Posts by typicalaimster
Old Dec 12, 2008, 07:07 PM
ApachePilot is offline
Find More Posts by ApachePilot
Father Francis, formerly Apach
Joined Oct 2006
Even the JR XP9303 72mHz version...
ApachePilot is offline Find More Posts by ApachePilot
Old Dec 12, 2008, 11:48 PM
twinturbostang is offline
Find More Posts by twinturbostang
Fly FPV, sleep; repeat
twinturbostang's Avatar
United States, MD, Hagerstown
Joined Mar 2006
Me too!
twinturbostang is offline Find More Posts by twinturbostang
Old Dec 13, 2008, 12:39 AM
JettPilot is online now
Find More Posts by JettPilot
JettPilot's Avatar
Miami
Joined Apr 2005
Very Interesting data Kestasxxx. Thanks for doing the work and posting your results !!! It will help a lot of people asking questions about this.
JettPilot
JettPilot is online now Find More Posts by JettPilot
Site Sponsor
Old Dec 13, 2008, 12:56 AM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Of course all these results can and will change, when you put a
high powered video Tx onboard the plane. Some R/C Rxs will
be overloaded by harmonics and just general high noise
floor produced by some video Txs. The effective range of my 2.4Ghz XPS Rx
with onboard 900Mhz Tx was zero, while FASST Rx is good
to at least a mile with stock antennas. Same relative placement
of video Tx and R/C Rx.
I've found similar results with various 72Mhz FM Rxs. Some are
very solid to over a mile near the video Tx. Some experience
front end overload and lockout at only a couple hundred yards
with the video tx, but work fine without it.
ian
Old Dec 13, 2008, 09:11 AM
MDreamer is offline
Find More Posts by MDreamer
"Here birdy birdy birdy..."
MDreamer's Avatar
Israel
Joined Sep 2006
Great stuff. I am using JR9303 2.4 + AR900 and almost lost my ship, at 1 KM (1000m) i had some glitches. I can tell by experience, the chart is very accurate when talking about the JR9303 2.4.
MDreamer is offline Find More Posts by MDreamer
Old Dec 15, 2008, 10:24 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
The 200m only of T4 started here real storm of protests.
Are you sure about the corectness of the test conditions ?
renatoa is online now Find More Posts by renatoa
Old Dec 21, 2008, 08:28 AM
Bindle83 is offline
Find More Posts by Bindle83
The FPV Ninja
Bindle83's Avatar
Brisbane, South East QLD
Joined Dec 2008
I would Love to see a Spektrum DX7 with (AR9100 4 Reciever set) test. what predicted range benifit would there be with a 8dbi patch antenna mod?
Brendan.
Bindle83 is offline Find More Posts by Bindle83
Air/JR/Fut RX Range test/results article in 3-D Flyer Mag. Peter Khor Radios 3 Aug 26, 2005 10:07 AM
tx, rx , crystal questions Clifford B Electric Plane Talk 37 Sep 25, 2001 07:29 PM
Wanted: Old "Cheap" TX & RX DeweyBob Aircraft - Electric - Airplanes (FS/W) 1 Sep 10, 2001 07:19 PM
need heli.i have gyro,tx,rx,hs81mgs,batts allready Kevin Graehl Electric Heli Talk 9 Aug 03, 2001 12:07 AM
ECO 8 Flight Test Results RC Man Electric Heli Talk 22 Jun 01, 2001 04:23 PM
