Old Mar 02, 2003, 02:33 AM
Nowell York is offline
Find More Posts by Nowell York
Nowell York's Avatar
Columbus, Ohio
Joined Nov 2001
Build a WASP Micro Air Vehicle!?
The WASP is a 13", 170gm flying wing MAV. In October of last year it made a MAV record flight of one hour and 47 minutes. It was built by AeroVironment and funded by DARPA. Control is via throttle, elevator and rudder. Power is Lithium ion, averaging 9 watts. All parts off the shelf.
I saw a blurb about it in Backyard Flyer, the pinnacle of aviation journalism, and my creative...ehh...replicative juices started to flow. Many of us have had 1 hour lithium powered flights without trying that hard. With a highly efficient tractor flying wing, I think 2 hours would be possible--especially since that 170g figure is a bit portly.
Looking at the picture, I'm guessing root chord is 5.5" and the tip is 4" for a leading edge sweep of 13 degrees and 61.75 square inches of wing area. 25% MAC at 2" back. Couple degrees of dihedral with the vert stab/rudder/landing skid beginning right under the nose. EPS cores, no spar, with a balsa trailing edge (with the elevator cut out) and a fiberglass or light film covering. The motor is a sub IPS direct drive (help me with the ID) with what appears to be a GWS 3x2 prop painted black with a Sharpie! I was thinking of using 2 1020 (or larger) Kokam cells--one in each wing panel, permanently installed. Receiver would be a tight fit--not much room if I went with a MH45 airfoil and a 5.5" chord. Pair of WES servos. Could work.
Nowell York is offline Find More Posts by Nowell York
Old Mar 02, 2003, 02:49 AM
Columbus, Ohio
Joined Nov 2001
WASP in hand...
Old Mar 02, 2003, 03:44 AM
Matthew Allen is offline
Find More Posts by Matthew Allen
Formerly of mcba fame
Matthew Allen's Avatar
Luxembourg
Joined Apr 2001
That would be real cool, though i'm guessing these tiny planes must me kind of squirrelly. Where are the control surfaces? Does it use wing warping or something?
Matthew
Matthew Allen is offline Find More Posts by Matthew Allen
Old Mar 02, 2003, 04:31 AM
Columbus, Ohio
Joined Nov 2001
Matthew
It has a little elevator at the midpoint of the trailing edge (hard to see in photos) and a landing skid+rudder on the underside.
Squirrelly--I bet it would be. Hopefully the dihedral with the rudder/elevator tames it down over conventional elevons without dihedral.
Old Mar 02, 2003, 06:37 AM
Luxembourg
Joined Apr 2001
Ahh..., I saw that but I thought it was too small
Matthew
Old Mar 02, 2003, 09:15 AM
Mike Taylor is offline
Find More Posts by Mike Taylor
Team 30 Micro EDF
Mike Taylor's Avatar
Camarillo, California
Joined Apr 2002
Matt's stuff all seems to use his own-built 900Mhz radio systems and actuators, either MW or some intricate 100 step stepper motors that are ~1/2" long and the diameter of Q-Tip stem. That 'hefty' weight also includes a GPS and TV system. I could be wrong here, but the props are almost certainly not off the shelf items since he CNCs computer designed props for everything he flies...
Mike Taylor is offline Find More Posts by Mike Taylor
Old Mar 02, 2003, 10:49 AM
kenny_dilger is offline
Find More Posts by kenny_dilger
United States, IN, Evansville
Joined May 2001
I would love to build this. You think you would need the 1020 or would a pair of 560 be able to handle a single GWS DD motor?
Let me know your progress. This would be really neat.
Kenny
kenny_dilger is offline Find More Posts by kenny_dilger
Old Mar 02, 2003, 11:00 AM
Acer is offline
Find More Posts by Acer
Acer's Avatar
Loveland, Colorado
Joined Mar 2000
I built a 16" wing. I had pico servos and receiver in it. The AUW was 2 oz. but if I used smaller gear and lighter foam (used 2 lb. density) I could have reduced that quite a bit.
Here's a pic of it in my transmitter case.
-- Acer
Acer is offline Find More Posts by Acer
Old Mar 02, 2003, 01:44 PM
Columbus, Ohio
Joined Nov 2001
According to the BYF article it has neither of these, but the next gen WASP will. The point of the WASP is to experiment with using the battery in the wing structure. It's essentially a flying Li ion battery.
The WASP was designed using "off-the-self components". I blew up the picture and compared the prop to a GWS 3x2 in hand--if it isn't a GWS 3x2 somebody reproduced it with a great deal of effort. I'm sure he CNCs props for his planes, but it doesn't appear to be the case here, given the spirit of the project. If you know him personally, it'd be great to get a little info on the design!
Acer--that is REALLY nice!
DARPA pdf
Old Mar 02, 2003, 05:38 PM
Basketcase is offline
Find More Posts by Basketcase
an earth bound misfit, I
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
Hi Acer, the 16" MSW looks cool. Is it just cut down 24" wings or did you design it differently? Any wing cores available or plans to offer a kit?
BC
Basketcase is offline Find More Posts by Basketcase
Old Mar 02, 2003, 08:15 PM
Columbus, Ohio
Joined Nov 2001
After discussing the motor issue on the indoor/micro forum, I believe it is a Mabuchi # FF-N20PN. The recommended voltage is 1.5 to 3. Probably scream on 2 cell Li, but at just $2 a pop, short motor life won't be a problem. As I think about it, finding the higher voltage version may be a good idea!
The prop is a Jamara B2.
Both available from Todd's Models .
Old Mar 02, 2003, 08:27 PM
Kallikrates is offline
Find More Posts by Kallikrates
Gainesville, Fla
Joined Aug 2002
The UF MAV research team has 6-5" planes that can fly for 20 min and cary a wireless camera (no camera = more duration) we are always working on smaller but our designs are usualy taylored to what ever the rules are for the competition that year and what our competition is doing
Kallikrates is offline Find More Posts by Kallikrates
Old Mar 02, 2003, 10:49 PM
DNA is offline
DNA
Find More Posts by DNA
DNA
registered user
DNA's Avatar
NE Ohio
Joined Jun 2001
How does it turn without a rudder or visible ailerons?
The motor doesn't look like a DC5-2.4, but I have a 5-2.4
and have done some experiments with it. With the 8:1
gears and a 5x3 prop it ran for 30 minutes when using
just a 150ma 9 volt rechargable transistor radio battery.
So it was only drawing about 300ma. With 560ma lipos it
should run for a lot longer. The motor itself only weighs 10 gms.
http://www.toddsmodels.com/dc5.htm
DNA is offline Find More Posts by DNA
Old Mar 02, 2003, 11:27 PM
Columbus, Ohio
Joined Nov 2001
See above.
Old Mar 02, 2003, 11:33 PM
frankenfoamy is offline
Find More Posts by frankenfoamy
Strange Plane Central
frankenfoamy's Avatar
Poway (near San Diego), CA US
Joined Dec 2000
Saw the plane fly in Sepulveda.
I took video of it but it is so tiny and fast, you barely could see it in the video.
The servos are about 1/4" square.
frankenfoamy is offline Find More Posts by frankenfoamy
Micro air Vehicle propulsion system charles27 UAV - Unmanned Aerial Vehicles 7 Jul 31, 2005 02:05 AM
WASP Micro Air Vehicle nanoflite Scratchbuilt Indoor and Micro Models 3 Apr 07, 2005 10:13 PM
Question Micro Air Vehicle Project Viper2000 Scratchbuilt Indoor and Micro Models 101 Apr 19, 2004 03:26 AM
Micro Air Vehicle Science Project KatanaGuy Scratchbuilt Indoor and Micro Models 11 Sep 07, 2003 09:31 PM
DARPA's Micro Air Vehicle has batteries for wings.... Steve McBride Batteries and Chargers 0 Dec 31, 2002 02:17 PM
