Could be because LED colors are not the same in your level shifter?
Looking at this photo, and post 182, LED marked "RX" (center of the board) should be the one that should be glowing. |
Sometimes, when there isn't any info available it's because it may be old and they don't have it scanned.
When part of the information is purposely omitted, they usually have a "confidentiality request" letter posted among the info. External photos, for example, are not confidential. Look at this one: AZPT6YF-72. Maybe it's not exactly the same, but if it's close enough, in this one the schematic is accesible. Also, this one looks like the 6VA (analog knob): AZPT6YG-72 Have a look at the photos-manual to see which matches best with your model |
MoFl - (I'll write your "handle" correctly yet!), Although the exterior of the TX's in the links are different, they may be the same internally, so I will check into that later. As previously stated, the challenge is to convert a "new" Futaba Skysport 6A from PPM FM to 2.4GHZ using the inexpensive HK 2.4GHz RF components. Thanks again!
abbydawn, the Hitec Optic 6 uses a module, so that is the best way to convert it. The ASSAN X8F module is a simple plug-in and comes with antenna, 2 RXs, a voltage hold-up cap and 2 binding cables (one for each RX) - all for $80 US, so it is a no-brainer. Mine works great, although I did have some difficulty at first de-ciphering the Chinese-to-English binding procedure. The trick is to move the Channel 2 input (elevator?) twice at turn-on and while the red light is still illuminated on the 2.4GHz RF module. Jimaroc |
MoFl,
More good news! After playing around with the program and removing all the crazy heli mixes the radio seems to work ok. Also the intermittent loss of signal seems to have gone away with a fresh set of batteries for the TX. The old ones were starting to blink yellow red on the TX. I think I will have to change the batteries to a 3cell lipo setup with a warning buzzer. I like the idea of a warning buzzer before the voltage drops below what the TX needs to operate properly. Someone else has already done this and I remember them saying they had trouble finding a 3cell that would fit. I will need to go back thru the thread and find that post. Thanks again for all the help! BlueFFF |
@JelleB
Flysky's 2.4 GHz "JR like" module should be compatible with HK and Turborix 6 ch receivers (rebranded Flysky's as well). This module is sold under Imax brand, and seems like you can also buy it from www.flysky-cn.com, but I've read at HK forums that they are going to sell them soon (few weeks they said, a week ago). @Blueff Don't worry too much about low voltage level; the battery voltage is regulated down to +5V in the TX's circutry, so as soon as battery voltage is over 7 volts (even 6,5 V, to provide enough overhead to the regulators), the circuits are OK. Some posts back (726) JMPblackfoot suggested to bypass the regulators and use just 4 NiMH cells. This should work, although you loose the isolation between encoder and RF module power rails, achieved by means of the use of 2 independent regulators, so I think the best hack for this TX's powering is to use a 2s or 3s LiPo (or any kind of battery above 7 Volts), keep the existing linear regulator for the encoder part (which has a low consumption), and replace the bigger 5 volt regulator (which feeds the more power hungry RF module) with a 3.3 switching regulator, connecting it's output directly to the 3.3 volt rail at the RF module (this module is feeded with +5v, but they are directly converted to 3.3 V at the input). This way you have a efficient (up to 90%) conversion from battery voltage to RF power section voltage, thus maximizing battery's energy usage. |
| Thread Tools | |
| New Product X8---new 2.4GHz Radio System | ASSAN | Radios | 5653 | Feb 13, 2013 05:07 PM |
| For Sale NEW - 2.4GHZ 2 channel Pistol R/C system | SRM | Cars - Cars and Parts (FS/W) | 0 | Oct 22, 2008 09:39 AM |
| Yippee! New 2.4GHz DSM radio - New standard? | PrasadL | Indoor and Micro Models | 6 | Oct 24, 2005 05:57 PM |
| FS: 1x Used 1x New 2.4ghz Wireless video cameras with receiver | Nik-rc | Aircraft - Electric - Airplanes (FS/W) | 4 | Nov 30, 2004 06:21 PM |
