Old May 14, 2009, 09:49 AM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Originally Posted by Lead Wings
I see HC are now selling the 6 channels for US$33. Can't see who will buy the 4 channel when you can get a 6 channel with more functionality for only $3 more:
https://www.unitedhobbies.com/UNITED...idProduct=9041
You know you linked people to the Mode 1 Tx?
Melnic is offline Find More Posts by Melnic
Old May 14, 2009, 09:51 AM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Originally Posted by keepitsimple
Hello,
I think one should always use following procedure:
- Setup one of your models, e.g. your mustang.
- If you think that the modelsetup is somewhat acceptable , save these settings in e.g. "mustang.set".
- Every time you improve the mustang settings , save them in "mustang.set".
- Now you can freely setup any other model and save settings in e.g. "other.set"
- If you are going fly with the mustang again, just "open mustang.set" to configure your TX for the mustang.
What I want to say:
- Do not use the TX as a storage device.
- Alway store acceptable settings on the PC in a ".set" file.
- You can than freely "mess things up" in the TX.....
regards from hans
For sure, you should always save changes to the PC.
I have only made I think 3 changes from the default.
I increment my saves since the size of the file is pretty small.
"blueray001"
"blueray002"
etc
Old May 14, 2009, 10:08 AM
Smurphy_ is offline
Find More Posts by Smurphy_
Smurphy_'s Avatar
Joined May 2009
And another one. Actually - not new - just upgraded.
MC19 fully equipped, and Added the Graupner receiver XR-20 IFS and Emitter XM-J3 IFS so I still can use the old 35MHz A-Band.
Will do my first flight test with an old airplane this Week-end... All tests though seem go so far.
Smurphy_ is offline Find More Posts by Smurphy_
Old May 14, 2009, 10:23 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
melnic,
What is wrong with Mode 1?
earlwb is offline Find More Posts by earlwb
Old May 14, 2009, 11:40 AM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Originally Posted by earlwb
melnic,
Nothing unless you fly mode 2 (throttle on left)
Mode 3 tx
https://www.unitedhobbies.com/UNITED...x_&_Rx_(Mode_2)
You know what?
The only difference is probably how they set up the default programming. Since you can change it in the SW, it does not really matter that much does it?
Old May 14, 2009, 12:29 PM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Hi guys,
thank you very much for the help concerning the knobs!
I will try this immediately when I am back home.
Greetings from Spain,
Julez
Julez is offline Find More Posts by Julez
Old May 14, 2009, 01:34 PM
MoFl is offline
Find More Posts by MoFl
MoFl's Avatar
Espaņa, AL, Sevilla
Joined Apr 2007
Julez
Bienvenido!
(not too much Kraut arround here!)
MoFl is offline Find More Posts by MoFl
Old May 14, 2009, 01:56 PM
crucial is offline
Find More Posts by crucial
crucial's Avatar
USA, SE Wisconsin
Joined May 2009
I just ordered a 4channel version 2 days ago and would have waited and bought this model for sure. This really sucks.
crucial is offline Find More Posts by crucial
Old May 14, 2009, 01:58 PM
renns is offline
Find More Posts by renns
Joined Nov 2004
If they haven't shipped yet, contact customer support, and they may be able to make the change. I did that after-the-fact on one of my orders, and it was handled with no problems.
renns is offline Find More Posts by renns
Old May 14, 2009, 02:03 PM
F-111 John is offline
Find More Posts by F-111 John
R.I.P, Aardvark.
F-111 John's Avatar
Holt, MI
Joined Jan 2009
Originally Posted by Melnic
You know what?
The difference between mode 1 and mode 2 is both software programming and hardware. Mode 1 has the throttle stick on the right, while mode 2 has the throttle stick on the left.
So if you wish to convert a radio from mode 1 to mode 2 or visa versa, you need to also swap the centering springs and throttle ratchet on the two joysticks.
F-111 John is offline Find More Posts by F-111 John
Old May 14, 2009, 02:08 PM
crucial is offline
crucial's Avatar
USA, SE Wisconsin
Joined May 2009
I did email CS. I got a shipped notification email the next day but the tracking info doesn't show anything yet. Hopefully the # was just generated and it hasn't gone out yet.
Unfortunately their email sent a reply saying their server is having problems and they will reply in 48-72 hours.
Maybe I will try calling them.
Old May 14, 2009, 02:16 PM
doh2doh is offline
Find More Posts by doh2doh
Joined Feb 2005
Dose the 6ch radio have expo?
doh2doh is offline Find More Posts by doh2doh
Old May 14, 2009, 02:21 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
No.
AJ
ajbaker is offline Find More Posts by ajbaker
Old May 14, 2009, 03:05 PM
renns is offline
Joined Nov 2004
What's the thoughts on running this unit from a 2s lipo? Seems like 3s lipo or 8x1.5V is overkill when it's regulated down to 5V anyways. Here's what I'm thinking:
1.) Add appropriate battery connector to battery tray - JST-style in my case.
2.) Modify low-voltage LED drive circuit to match new battery voltage.
3.) I assume the std 7805-type regulator will cut out as battery voltage drops much below 8V, which is a problem for 2s lipo operation. So...what about swapping out the on-board regulators for low drop-out or switching types. The TO220 regulator should be easy for the average guy to swap out, but that smaller one may be more of an issue.
In the end, reduced thermal load on the regulator circuits, extended battery life, and a 2s rather than 3s battery are all advantages of making these mods. Any comments from the electronics hackers in the crowd?
Old May 14, 2009, 04:04 PM
MoFl is offline
MoFl's Avatar
Espaņa, AL, Sevilla
Joined Apr 2007
Agree.
Have a look at this post and this one (A note for modders...)
In order to improve efficiency, a switching regulator would be much better than a linear one (in this case you can also use 3s lipo with almost same efficiency). A suitable part for this mod would be this one, also avaliable at ebay
New Product X8---new 2.4GHz Radio System ASSAN Radios 5740 Mar 06, 2016 01:21 PM
Yippee! New 2.4GHz DSM radio - New standard? PrasadL Scratchbuilt Indoor and Micro Models 12 Jun 03, 2013 07:03 AM
For Sale NEW - 2.4GHZ 2 channel Pistol R/C system SRM Cars - Cars and Parts (FS/W) 0 Oct 22, 2008 09:39 AM
FS: 1x Used 1x New 2.4ghz Wireless video cameras with receiver Nik-rc Aircraft - Electric - Airplanes (FS/W) 4 Nov 30, 2004 06:21 PM
