Old Sep 11, 2013, 10:09 PM
Zedtwitz is offline
Find More Posts by Zedtwitz
United States, NY
Joined Jan 2012
Resoldered properly and stabilized with 0.2mL of epoxy. Here it is.
Zedtwitz is offline Find More Posts by Zedtwitz
Old Nov 05, 2013, 11:12 PM
Altbob is offline
Find More Posts by Altbob
Altbob's Avatar
Joined Oct 2012
Does anyone know if you can somehow get the FlySky CT6B to work with Phoenix Sim?
Edit: Nevermind - I found the answer here: http://www.mycoolheli.com/CT6BHOWTO.html
Altbob is offline Find More Posts by Altbob
Old Jan 20, 2014, 12:16 PM
CalebRC is offline
Find More Posts by CalebRC
Joined Aug 2013
My HK-T6A is stuck like this. When I move the sticks nothing works but channel 4, which I don't even use in my plane. I've tried everything I know to do, and nothing works. I had everything working a few days ago and have done nothing to it to make this happen, and I don't know what to do! Today I was going to maiden my plane but this stuff won't work, any help would be very much appreciated.
CalebRC is offline Find More Posts by CalebRC
Old Jan 20, 2014, 02:25 PM
JMP_blackfoot is offline
Find More Posts by JMP_blackfoot
JMP_blackfoot's Avatar
United States, OH, Galena
Joined Jul 2003
Originally Posted by Zedtwitz View Post
Hey, is it okay if I replace the 8 AAs in here with two lithium cells (18650s)? The main controller board is labeled as requiring 12v input but I've seen Turnigy 9x mods where a 7.4v lithium pack is substituted in.
Another possibility is to run the transmitter off 4 cells NimH:
http://www.rcgroups.com/forums/showp...&postcount=722
http://www.rcgroups.com/forums/showp...&postcount=726
http://www.rcgroups.com/forums/showp...&postcount=727
http://www.rcgroups.com/forums/showp...&postcount=769
http://www.rcgroups.com/forums/showp...&postcount=772
http://www.rcgroups.com/forums/showp...&postcount=783
etc...
I have been flying three transmitters (one 4-channel and two 6-channel) modified as described with zero problem.
JMP_blackfoot is offline Find More Posts by JMP_blackfoot
Old Jan 21, 2014, 03:29 AM
ReSt is offline
Find More Posts by ReSt
Joined Jul 2009
Try T6Recalibrate
http://www.rcgroups.com/forums/showt...6#post13515597
I know it helped with problems like yours.
Reinhard
ReSt is offline Find More Posts by ReSt
Old Jan 21, 2014, 10:36 AM
CalebRC is offline
Joined Aug 2013
Originally Posted by ReSt View Post
Try T6Recalibrate
Reinhard
You can see in the picture I attached I was using that then, it really didn't do anything... I think i'm just going to return it and get something better. Thanks anyway.
Old Jan 22, 2014, 04:38 AM
ReSt is offline
Joined Jul 2009
Sorry, didn't look hard enough.
Can you use a voltmeter/ohmmeter?
Open the radio and measure the voltage across the stick pots.
There should be 5 volt between the outer pins of the pots.
The voltage of the middle pin should vary + - 1 volt or something like that, when you move the stick from end to end.
Measure the +5 volt side of the pots against a ground spot on the main board to make sure the ground side is connected or with power off, measure the resistance of the + side of the pot against the +5v side of the voltage regulator
Do the same with the minus side of the pot against - on the board.
With power on measure the voltage on processor pins 18 to 21. these are the analog voltage inputs of the processor that are fed from the stick's middle pins.
If all that looks good, it's not a hardware problem anymore.
Reinhard
Old Jan 23, 2014, 12:57 PM
CalebRC is offline
Joined Aug 2013
I do have a voltage meter but I don't quite understand all that, sorry
I did, however, manage (don't ask me how) to get it working again, and I must say, pretty well. Everything works as it should again. Thanks for trying to help though
Old Mar 14, 2014, 01:50 PM
Bob A is offline
Find More Posts by Bob A
United States, IA, Keosauqua
Joined Sep 2010
Software for CT6B Tx
I had to replace my computer & now am having trouble making the software for my FlySky CT6B work. After all kinds of problems, I had the T6config program working on Windows XP but my computer now uses Windows 7. I tried to download the trial version of the Digital Radio program but am not getting anywhere with that.
Can anyone point me to somewhere that explains to a non-computer-savvy dummy how to download & try the Digital Radio Program?
Thanks for any advise
Bob
Bob A is offline Find More Posts by Bob A
Old Mar 14, 2014, 02:01 PM
jmdlcar is offline
Find More Posts by jmdlcar
USA, OH, Marysville
Joined May 2010
Bob
It works on my Windows 7.
jmdlcar is offline Find More Posts by jmdlcar
Old Mar 14, 2014, 02:02 PM
jmdlcar is offline
USA, OH, Marysville
Joined May 2010
This might been ask but here I go. Has anyone use this T6CONFIG on or for a Quadcopter? I'm building a Quad and have this type of TX and I using the HK Multiwii Pro flight Controller.
Old Mar 16, 2014, 05:47 PM
Bob A is offline
Joined Sep 2010
Well, I KNOW many have had success downloading the trial program on a Windows 7 computer. My problem is in not knowing how to go about doing that. I guess I'm just stuck until I get someone who can download it for me.
Bob
Old Mar 18, 2014, 12:52 PM
jmrobert is offline
Find More Posts by jmrobert
United States, AZ, Show Low
Joined Sep 2003
jmdlcar:
Yes, I do. You only need 4 channels to control a quad. I set mine up as an airplane in T6CONFIG.
jmrobert is offline Find More Posts by jmrobert
Old Mar 27, 2014, 03:36 AM
KIWINB is offline
Find More Posts by KIWINB
Auckland New Zealand
Joined Sep 2010
I got T6config working on win8.1, I had to find a new driver for the serial to USB converter before the T6config would connect to the Tx. The driver for XP won't connect in win7 or 8.
The driver I used is http://www.sgr.info/usbradio/Windows...S2K3_Vista.zip
I found it on the digital radio site.
KIWINB is offline Find More Posts by KIWINB
Old Mar 29, 2014, 06:11 PM
Zedtwitz is offline
United States, NY
Joined Jan 2012
If you can't get T6Config working there's always Turborix.
New Product X8---new 2.4GHz Radio System ASSAN Radios 5732 Jan 11, 2016 12:33 AM
Yippee! New 2.4GHz DSM radio - New standard? PrasadL Scratchbuilt Indoor and Micro Models 12 Jun 03, 2013 08:03 AM
For Sale NEW - 2.4GHZ 2 channel Pistol R/C system SRM Cars - Cars and Parts (FS/W) 0 Oct 22, 2008 10:39 AM
FS: 1x Used 1x New 2.4ghz Wireless video cameras with receiver Nik-rc Aircraft - Electric - Airplanes (FS/W) 4 Nov 30, 2004 07:21 PM
