Old Dec 10, 2012, 11:11 AM
esu-ov is offline
Find More Posts by esu-ov
Česká republika, Moravskoslezský, Ostrava
Joined Mar 2010
Bluetooth module JY-MCU BT_ BOARD v1.2
Hey fans of Bluetooth
The module is set to 9600 baud rate by default. On the web site Alejandro Pirola is set this modul to 115200 baud rate. Use the command
AT+BAUD8.
Other settings are not required. Pins can be connected directly to the transmitter connector.
esu-ov
esu-ov is offline Find More Posts by esu-ov
Old Dec 11, 2012, 01:51 AM
willy163 is offline
Find More Posts by willy163
willy163's Avatar
Italia, Piemonte, Strambino
Joined Feb 2010
AT+BAUD8.
esu-ov
Many thanks!
I'm a Bluetooth fan!
Willy.
willy163 is offline Find More Posts by willy163
Old Dec 21, 2012, 10:13 AM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Anyone with a TM001 (FlySky Version A) module?
Willing to pay top dollar
Make so dough if you're not using yours
Regards
erh7771 is offline Find More Posts by erh7771
Old Dec 21, 2012, 11:45 AM
JMP_blackfoot is offline
Find More Posts by JMP_blackfoot
JMP_blackfoot's Avatar
United States, OH, Galena
Joined Jul 2003
PM sent
JMP_blackfoot is offline Find More Posts by JMP_blackfoot
Old Jan 17, 2013, 02:02 AM
HappyMan2009 is offline
Find More Posts by HappyMan2009
North West of Italy, Lake Maggiore
Joined Jul 2009
AT+BAUD8.
esu-ov
Hi,
here
http://www.sgr.info/usbradioandroid/bluetooth.htm
I've written a page describing how to set a Bluetooth module.
After the Bluetooth version now I'm going to write an application for Android tablet using the standard USB-Serial adapter.
Bye
HappyMan
New software for the Hobby King, FlySky, Turborix, Exceed, Storm, CopterX and Jamara radio - V1 and V2 - For Windows, Linux and Android
http://www.sgr.info/batterymanager
New software to manage your set of LiPo/LiFe/NiMH batteries
HappyMan2009 is offline Find More Posts by HappyMan2009
Old Jan 21, 2013, 06:03 AM
keepitsimple is offline
Find More Posts by keepitsimple
keepitsimple's Avatar
The Netherlands, OV, Almelo
Joined Sep 2008
Bluetooth Adapter
This is what I created a while ago.
Use it with Samsung smartphone
Works fine for small correction in the field
keepitsimple is offline Find More Posts by keepitsimple
Old Jan 27, 2013, 02:20 PM
Anhydrite is offline
Find More Posts by Anhydrite
Joined Dec 2012
I have a FS-CT6B and I want to remove the transmitter board and put it in a JR module case so I can use it in my 9X.
Will that work? I relize I need to make some sort of pin connector to mate with the 9X pins...is that it though?
Anhydrite is offline Find More Posts by Anhydrite
Old Jan 27, 2013, 02:34 PM
Joined Jul 2003
The transmitter board needs a 5V regulated supply, so you'll have to have a 5V regulator and also have to add a bind button.
Old Jan 27, 2013, 02:38 PM
gulio is offline
Find More Posts by gulio
That's a funny word
NE Ohio
Joined Apr 2003
I had to remove the module form the Turnigy 9x and I now need to re-install it. Is this just a single wire that I can simply solder back onto the board once I get the wire pulled thru the case again?
I can't quite see good enough to make it out. I had no trouble removing it, I think I just cut it at the solder point on the board.
gulio is offline Find More Posts by gulio
Old Jan 27, 2013, 03:20 PM
Joined Jul 2003
It is not a simple wire, but a coax which requires some fine soldering. In my opinion, it would be better to remove the antenna from the transmitter and attach it to the module, so you could eventually use other modules.
Old Jan 27, 2013, 03:31 PM
gulio is offline
That's a funny word
NE Ohio
Joined Apr 2003
I was afraid of that. I will perhaps just get a module that has it's own ant. Thanks.
Old Jan 29, 2013, 02:25 AM
ReSt is offline
Find More Posts by ReSt
Joined Jul 2009
Have a look at this picture
http://static.rcgroups.net/forums/at...4-144-Wire.jpg
Reinhard
ReSt is offline Find More Posts by ReSt
Old Jan 29, 2013, 12:25 PM
iksbob is offline
Find More Posts by iksbob
United States, DE, Newark
Joined May 2011
The T6 transmitter board is functionally identical to the stock 9X module. The 9X simply has a JR case and an adapter board which provides a bind button and lets it work with the JR pinout (including 5V regulation from raw battery voltage).
iksbob is offline Find More Posts by iksbob
Old Feb 10, 2013, 10:09 PM
77095066 is offline
Find More Posts by 77095066
Joined Feb 2013
Hi , I tried this mod for one of my CT6B's and it is not working as a trainer, just to be sure you connected the end of the yellow wire going to the transmitter module to the center position of the switch, the end going to the main board to end one and the cut red wire from the trainer port (next to the black wire) onto end two of the switch?
I have scoured the thread and did not find any other discussions on this mod but it has been a very active thread sorry if it has already been addressed and I missed the update.
This is in reference to the original post #1697 where directions were given to add a momentary switch to the CT6B to allow it to be used as a master buddy box.
Has anyone had any luck with this modification, and if so can you help me understand where I might have gone wrong?
Thank You in advance for any useful advice!
77095066 is offline Find More Posts by 77095066
Last edited by 77095066; Feb 10, 2013 at 10:38 PM. Reason: I had omitted reference post
Old Feb 21, 2013, 12:49 AM
gsking is offline
Find More Posts by gsking
SF Bay Area
Joined Jan 2013
I can't get my throttle to map below 66%. I tried calibrating it, to no avail. Ideas? Thanks!
gsking is offline Find More Posts by gsking
New Product X8---new 2.4GHz Radio System ASSAN Radios 5740 Mar 06, 2016 01:21 PM
Yippee! New 2.4GHz DSM radio - New standard? PrasadL Scratchbuilt Indoor and Micro Models 12 Jun 03, 2013 07:03 AM
For Sale NEW - 2.4GHZ 2 channel Pistol R/C system SRM Cars - Cars and Parts (FS/W) 0 Oct 22, 2008 09:39 AM
FS: 1x Used 1x New 2.4ghz Wireless video cameras with receiver Nik-rc Aircraft - Electric - Airplanes (FS/W) 4 Nov 30, 2004 06:21 PM
