Old Mar 11, 2009, 09:12 PM
congo is offline
Find More Posts by congo
Joined Feb 2009
keepitsimple,
I just tested your application under "XP Pro x64" and "ATEasy6-136a" and it made no difference to those errors above, however, I seem to have full functionality otherwise.
The following screenshots were taken from my XP Pro x86 PC.
The Mixer, Switches and Variable screens all have missing functionality as can be seen from the shots.
I do not get any load errors (my previous screenshots from XP x64) when initiating the software under XP x86.
Note that the same screen appears for both the Switches and Variable buttons on your software, so I have only included one screenshot of that screen.
I wondered why you have two separate buttons when both functions are accessed from either one?
Your software does not auto-detect and then default to the valid com port (once configured from first run) on my systems.
I assumed this was normal behaviour, but include this note just in case it's not.
The hardware on both my XP x86 and XP x64 machines is almost identical, the OS is the primary difference between the two.
I cannot guarantee that I have all current updates for these OS's, or the correct versions of .Net Framework if those are possible factors.
I also modify my XP install media for my own purposes, so don't wrack your brain over this if no one else is experiencing problems :P
congo is offline Find More Posts by congo
Last edited by congo; Mar 11, 2009 at 09:57 PM. Reason: fix accuracy of post, add relevant attachments
Old Mar 12, 2009, 02:12 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Running and some info
Originally Posted by keepitsimple
Pfff, at least (at last) one person that got it running...
I couldn't imagine that the program does not run on any other PC's then on the 10 PC's (at work) that I tested it on.
What exactly is the problem with the Acer notebook?
Can it be that it has something to do with XP professionel and Home editions?
thanks Borlax
hans
Hi hans, and a BIG THANK YOU for all your wonderful work. I have it working on 3 different laptops (HP, Dell, and homebuilt) and 2 desktops. All of those are running XP Performance Edition (available to MS developers only). I tried it on a laptop and 2 desktops running Vista and Small Business Server respectively. I get the same errors as Congo on all three. Then, I researched the AtEasy program and discovered they are still using some old 16-bit dll's in their software. They will not be compatible with Vista, SBS, or any x64 operating system. The best I can recommend to Congo is to find or buy a cheap laptop with XP on it. Then, all should be well. Oh, BTW, I tried it on an old Win98 machine and I had to rewrite the drivers. But, AtEasy6.0 worked great. I hope this helps.....
AJ
ajbaker is offline Find More Posts by ajbaker
Old Mar 12, 2009, 02:24 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Info
Originally Posted by congo
keepitsimple,
I assumed this was normal behavior, but include this note just in case it's not.
Update: I just downloaded AtEasy 7.0 (30-day trial) and installed just the runtime program. It works perfectly on the computers above (Vista, SBS, x64). So, download it here (right side of page 1/2 way down) and fill out the registration (must use valid e-mail - but not netzero, gmail, or I am sure a lot of other "free" emails).
Good luck. I can assure you it is more than well worth the time you will invest. keepitsimple's application is AWESOME. He really outdid himself on this one.
AJ
Old Mar 12, 2009, 06:48 AM
MoFl is offline
Find More Posts by MoFl
MoFl's Avatar
España, AL, Sevilla
Joined Apr 2007
@keepitsimple
Hi, Hans.
Have another look at thread about the Turborix ESC LCD programming card:
http://www.rcgroups.com/forums/showthread.php?t=943988
There´s some new info.
I´ve also tried your PC program, but without the RC connected, and, to this point, it seems to work OK. I´ll report again when I make a complete test.
MoFl is offline Find More Posts by MoFl
Old Mar 12, 2009, 07:13 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Good thing you had a alternate download site.
I think the Geotestinc.com website has problems, at present their website isn't working for downloading anything. Sort of like they are missing a lot of files.
earlwb is offline Find More Posts by earlwb
Old Mar 12, 2009, 07:32 AM
abbydawn is offline
Find More Posts by abbydawn
Joined Sep 2008
keepitsimple,
I just tested your application under "XP Pro x64" and "ATEasy6-136a" and it made no difference to those errors above, however, I seem to have full functionality otherwise.:P
I get the same results as Congo running XP Home SP3, ATEasy6 or 7.
abbydawn is offline Find More Posts by abbydawn
Old Mar 12, 2009, 10:11 AM
geotrouvetout is offline
Find More Posts by geotrouvetout
geotrouvetout's Avatar
Rouen (FRANCE)
Joined Nov 2003
Hi MoFl,
thanks for the schematic on the other topic, why not replace (pin to pin) the ??? MCU with an other (Pic or Atmel).
Thanks to Keepitsimple, i didn't try your program yet, but i'll do it when i'll get my Xp computer back, i have only a laptop on Vista at this time.
Géo .
geotrouvetout is offline Find More Posts by geotrouvetout
Old Mar 12, 2009, 09:50 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I installed the AtEasy runtime Ver 6 OK and the Programmer app runs OK on my PC. it took a minute to figure out what to set the COM port to (com3) in my case, but other than that it ran with no errors.
This is on a Dell 3ghz Pentium machine running XP-Pro with current Service pack and updates.
Pretty cool app, thank you very much.
Old Mar 13, 2009, 11:40 AM
Kuba is offline
Find More Posts by Kuba
USA, IL, Chicago
Joined Aug 2004
The HK receivers are back in stock.
Why bother with programing card, when You can get Palm m10* for ~$10, we just need someone to write software for PalmOs.
Kuba is offline Find More Posts by Kuba
Old Mar 13, 2009, 11:45 AM
nikvan is offline
Find More Posts by nikvan
Joined Mar 2009
Hello, new in site and in RC generaly.
I just bought the Turborix 2.4gh 6ch package and managed to bind it with the receiver.
But when i connect the servos (9g plastic) the become "crazy" and they do not respond to tx's inputs.
They work prerfect with my old 27mhz Tx-Rx package.
Thank you,
Best Nikos
nikvan is offline Find More Posts by nikvan
Old Mar 13, 2009, 12:18 PM
waqa is offline
Find More Posts by waqa
have foam, will fly
waqa's Avatar
San Diego
Joined Dec 2008
Thank you,
Best Nikos
I had this happen as well with one receiver. It turned out to be a bad satelite receiver. Try disconnecting the little satelite receiver and try the servos.
waqa is offline Find More Posts by waqa
Old Mar 14, 2009, 10:13 AM
nikvan is offline
Joined Mar 2009
Thanks Waqa,
I will do so
Old Mar 14, 2009, 05:53 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Good News - Bad News
Originally Posted by 86waterpumper
Hmm odd, well does the led blink on the rf even if no rx is present though and trying to bind? Oh well I sent you a pm Ajbaker and I thank you for the offer. It would be bad I guess to have to chunk two good rx. It is frustrating but that's nobody here's fault, not the first or the last rc equipment I will have this to deal with I'm sure. That is cool about the digital multimeter tip you gave me too! I got 3 of those things for 2.50 apiece so that right there to me is worth alot HAHA
The Good News: Both Receivers work.
The Bad News: Both Receivers work.
I guess the problem is the transmitter. Ah well, at least we know one more thing that it isn't. I will be returning these to you on Monday 3/16. You should get them in 2-3 days.
AJ
P.S. Here are the videos:
http://www.youtube.com/watch?v=m5PbGovRlvs
http://www.youtube.com/watch?v=6KSvFu7lWTw
Old Mar 15, 2009, 12:47 AM
waqa is offline
have foam, will fly
waqa's Avatar
San Diego
Joined Dec 2008
One of my tx's does the same thing if I leave the antenna down and have it within a 2 feet of the rx, ie binds ok but servos are erratic. If I put the tx antenna up and move it 3 feet or more from the rx all is fine. My old Futaba AM tx did similar things.
Old Mar 15, 2009, 02:38 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Re-check
Good Point. I rechecked the rx that had twitchy servos and sure enough, I moved 3 feet away and it worked perfectly. Thanks for the reminder.
AJ
New Product X8---new 2.4GHz Radio System ASSAN Radios 5742 Aug 25, 2016 06:45 AM
Yippee! New 2.4GHz DSM radio - New standard? PrasadL Scratchbuilt Indoor and Micro Models 12 Jun 03, 2013 07:03 AM
For Sale NEW - 2.4GHZ 2 channel Pistol R/C system SRM Cars - Cars and Parts (FS/W) 0 Oct 22, 2008 09:39 AM
FS: 1x Used 1x New 2.4ghz Wireless video cameras with receiver Nik-rc Aircraft - Electric - Airplanes (FS/W) 4 Nov 30, 2004 06:21 PM
