Old Jun 29, 2010, 08:00 PM
Telemachus is offline
Find More Posts by Telemachus
Heli Humbled Daily
Riverside, CA
Joined Jul 2006
Probably not. Every house around you is using 2.4 ghz cordless telephones, and that doesn't affect much.
Telemachus is offline Find More Posts by Telemachus
Old Jun 29, 2010, 10:26 PM
F-111 John is offline
Find More Posts by F-111 John
R.I.P, Aardvark.
F-111 John's Avatar
Holt, MI
Joined Jan 2009
Then again you're not carrying around a 2.4 GHz cordless phone inches away from the receiver in your airplane.
Actually, as long as the receiver front end doesn't get overloaded, the old FlySky radio system stands a better chance of working with 2.4 GHz wireless video FPV cameras because it doesn't frequency hop. The newer V2 radios do frequency hop, which means they're going to spend a lot of time in the video interference.
2.4 GHz camera video takes up about half the band. The older (V1) FlySky radios simply picked a clear frequency to use. So if you fire up your camera first, then turn on your transmitter, the transmitter will see what part of the band is being used, then come up on an unused frequency.
The new V2 stuff will probably come up as well, but for the time it's hopping its frequencies in the video interference, your receiver latency will go way up.
F-111 John is offline Find More Posts by F-111 John
Old Jun 30, 2010, 12:58 AM
CoolBudz is offline
Find More Posts by CoolBudz
RCPlaye
United States, CT, East Hartford
Joined Aug 2009
thanks a million
CoolBudz is offline Find More Posts by CoolBudz
Old Jul 02, 2010, 10:24 PM
Darkwolfe is offline
Find More Posts by Darkwolfe
Ground plower
Joined May 2010
Did anyone post any flight performance info on the HK systems. I'm seriously looking at it because I am cheap so-and-so, but only if it works.
Darkwolfe is offline Find More Posts by Darkwolfe
Old Jul 03, 2010, 11:38 AM
Kokopeli is offline
Find More Posts by Kokopeli
Curiouser and curiouser
Kokopeli's Avatar
Rochester, NY, USA
Joined Oct 2005
I use them ALOT.
However, my opinion is that they are such a "moving target" that someone else's data is not too useful.
The first issue is that there is sometimes significant variability in a batch of motors that the performance varies.
The other issue is that the mfg. sometimes makes significant changes in the design and it is sold as the same model motor - so even more variability.
I buy my HK motors and label them with a number unique to me and test them all to catalog all my motors. Then I select what I need from the box and hope that they haven't changed
Walt
Kokopeli is offline Find More Posts by Kokopeli
Old Jul 04, 2010, 12:04 AM
vfrjohn is offline
Find More Posts by vfrjohn
Joined Apr 2010
Help! Part number needed
Waaayy back, in post #989 on page 66 of this thread...
mis_b provided a spiffy circuit diagram to modify the voltage detection for the HK T6A transmitter.
On that diagram is a device (which appears to be a zener diode) labeled "4U7".
What kind of device is it?
I can't find (ie., Google) anything called a 4U7 that makes sense. If it is a zener, what voltage and current should it be?
Thanks in advance -
John in Texas
vfrjohn is offline Find More Posts by vfrjohn
Old Jul 04, 2010, 12:13 AM
captaingeek is offline
Find More Posts by captaingeek
master of the universe
captaingeek's Avatar
USA, CA, Novato
Joined Jul 2008
doesn't ~ 250 pages convince you? ive been using this system for quite awhile and cant complain.
captaingeek is offline Find More Posts by captaingeek
Old Jul 04, 2010, 01:47 AM
PJG is offline
PJG
Find More Posts by PJG
PJG
Ad astra per alia porci
PJG's Avatar
Joined Jul 2009
Re Part number needed
Hi, John in Texas,
The zener diode in mis_b's circuit is 4v7. This means a 4.7 volt zener diode; the v indicating where the decimal point lies.
You may wish to view my post #1626 0n page 109 where I have posted two small circuit mods.
Regards, GL1000 John in Aquitaine
PJG is offline Find More Posts by PJG
Old Jul 04, 2010, 01:58 AM
MoFl is offline
Find More Posts by MoFl
MoFl's Avatar
Espaņa, AL, Sevilla
Joined Apr 2007
On that diagram is a device (which appears to be a zener diode) labeled "4U7"....
I understand it's a 4.7 volts zener (link to post#989).
MoFl is offline Find More Posts by MoFl
Old Jul 04, 2010, 06:28 PM
vfrjohn is offline
Joined Apr 2010
A Big Texas THANK YOU!!
MoFl and PJG - Thank you for clearing that up for me. That was a bit of nomenclature that is new to me!
Thanks too for the head's up on the changes. Now I'm off to Radio Shack...
(Long live the noble original GoldWing!)
Old Jul 05, 2010, 03:06 AM
iter is offline
Find More Posts by iter
High-power Rocket Gliders
iter's Avatar
Silicon Valley, Calif
Joined Jan 2005
2x V1 RXs for sale
V1 RXs with satellites in the For Sale forum: http://www.rcgroups.com/forums/showthread.php?t=1270325
Ari.
iter is offline Find More Posts by iter
Old Jul 10, 2010, 03:51 AM
rasty15 is offline
Find More Posts by rasty15
Latvija, Valmiera
Joined Jul 2010
Hi, maybe you can help me with my futaba t6x.
See the problem is to change models memory.
I realy don't know wat to do becuase i have two models (DLG-F3K and F3P) and they both have different settings.
The problem is how I can change model memory and save the previous settings?
Can anyone help me?
Wat i have to do???
rasty15 is offline Find More Posts by rasty15
Old Jul 10, 2010, 11:15 AM
R.I.P, Aardvark.
F-111 John's Avatar
Holt, MI
Joined Jan 2009
Can anyone help me?
Wat i have to do???
Sorry, Rasty, but this isn't a Futaba thread.
May I suggest you post your question in the Radio Forum as a new thread.
http://www.rcgroups.com/radios-135/
Manual is here: http://manuals.hobbico.com/fut/6xas-hs-manual.pdf
Old Jul 10, 2010, 11:36 PM
reacher10 is offline
Find More Posts by reacher10
reacher10's Avatar
United States, NY, Shirley
Joined Oct 2008
One for sale
I have one with the Palm V and another radio for parts. Both are V1...no Rx's. Maybe someone can use it.
http://www.rcgroups.com/forums/showt...9#post15513292
reacher10 is offline Find More Posts by reacher10
Old Jul 11, 2010, 04:05 AM
sparks59 is offline
Find More Posts by sparks59
Sic itur ad Astra
sparks59's Avatar
United Arab Emirates, Abu Dhabi, Abu Dhabi
Joined Aug 2009
Ari.
Interesting iter,
For $25 you can buy a new TX/RX V2, and a stack of V2 Rx'ers for about $12 a piece from HK, If you already have a chord, it's only worthwhile if you dont want to change the system.
I guess if you are in USA you will save the postal costs too.
just my two penneth.
sparks
sparks59 is offline Find More Posts by sparks59
New Product X8---new 2.4GHz Radio System ASSAN Radios 5743 Sep 01, 2016 11:51 AM
Yippee! New 2.4GHz DSM radio - New standard? PrasadL Scratchbuilt Indoor and Micro Models 12 Jun 03, 2013 07:03 AM
For Sale NEW - 2.4GHZ 2 channel Pistol R/C system SRM Cars - Cars and Parts (FS/W) 0 Oct 22, 2008 09:39 AM
FS: 1x Used 1x New 2.4ghz Wireless video cameras with receiver Nik-rc Aircraft - Electric - Airplanes (FS/W) 4 Nov 30, 2004 06:21 PM
