Old Feb 23, 2009, 01:10 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Range Check
Originally Posted by congo
I then fitted a 3s 11.1v lipo to the Tx, got a green light, loaded my saved config back in and everything was back to normal. I then range tested and flew my heli. Range test was done to 250 meters. While out there, I depressed the range test button and the model remained un full control with no signs of glitching, making me think the range test button does not function, unless I did not perform the function correctly.
Just thought I'd report that observation. It could be nasty in-flight.
I did pretty much the same thing with quite a bit longer test distance. I hooked up an FPV and ET systems to my 8' Telemaster and flew it 1.1 mi away to a small airstrip. At 2500' up (barely a dot) I tried the range test because I had the FPV (different frequency and batt) in case something went terribly wrong. Well, no change. Continuing my flight on FPV I landed at the airstrip (I was in constant communication via cell phone with a friend that helped me not get lost). I landed fairly well at the airport. Then, with my friend talking to me, I tried the range check button and all still worked perfectly. Not wanting to push my luck, I had my friend disconnect the battery and return it to me. It was scary fun. Afterwards, I thought about all the things that could go wrong and I will not do it again. So, I think it is safe to say that the range (as stated by many) is "As far as you can see". I would just add "and then some" to that.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Feb 23, 2009, 08:59 AM
86waterpumper is offline
Find More Posts by 86waterpumper
Joined Dec 2008
Ok I'm going to show my ignorance here...I'm fine on the continuity test, but how do you check for ohms? I'm not sure my crappy meter will do it but maybe so and I just don't know what to set it on etc..
86waterpumper is offline Find More Posts by 86waterpumper
Old Feb 23, 2009, 09:09 AM
geotrouvetout is offline
Find More Posts by geotrouvetout
geotrouvetout's Avatar
Rouen (FRANCE)
Joined Nov 2003
Hi 86waterpumper,
do you have a reference or model of your "crappy" meter or a picture (Google picture), the scale for Ohm is green, instead of red for current and black for volt, and for the scale it depend if X10, X1 or Ohm, kOhm or MOhm.
Géo .
geotrouvetout is offline Find More Posts by geotrouvetout
Old Feb 23, 2009, 09:26 AM
quigley257 is offline
Find More Posts by quigley257
Say when.....
quigley257's Avatar
United States, MO, Hillsboro
Joined Sep 2005
I don't know if this has been mentioned already, but I just noticed this announcement in the latest email that I got from HC...
NEW 2.4GHZ 9CH FSSS/FHSS ARRIVING
Finally our new 2.4Ghz FHSS/FSSS radio has finished production and will soon be available for sale.
Retail price will be set to around $79.95 with receivers costing about $24.95USD each.
A 9 channel for this price point might be worth a look. I guess it will depend upon mixing capabilities and features.
--quigley
quigley257 is offline Find More Posts by quigley257
Old Feb 23, 2009, 10:58 AM
BlueFFF is offline
Find More Posts by BlueFFF
Up in smoke!
BlueFFF's Avatar
Greenville, TX
Joined Jun 2007
Hopefully the 9 channel TX will work with the 6ch receivers.
BlueFFF is offline Find More Posts by BlueFFF
Old Feb 23, 2009, 11:10 AM
MoFl is offline
Find More Posts by MoFl
MoFl's Avatar
España, AL, Sevilla
Joined Apr 2007
From what i saw in HK forums, must be this one:
http://www.flysky-cn.com/english/pro...sp?prodid=0017
In this case, same OEM as the two models treated in this thread. Also (looking at the pictures), same as iMax 9X 2.4Ghz system:
http://www.rcmodelreviews.com/imax9x.shtml
Considering this review, and as Xjet says in post#224:
http://www.rcgroups.com/forums/showp...&postcount=224
This radio is compatible with our 6ch RXs (turborix/HK).
BTW, in this case, I'm afraid it's not FSSS/FHSS as, from what I've read, this is NOT the case for Turborix/HK.
This week I'm going to try to take the TX to a HF lab at my office, and see how it shows in an spectrometer...
MoFl is offline Find More Posts by MoFl
Old Feb 23, 2009, 12:45 PM
MoFl is offline
MoFl's Avatar
España, AL, Sevilla
Joined Apr 2007
Originally Posted by MoFl
Hello, Hans.
I agree with you. No problem to run with 8xNiMh. The regulators would work OK down to 7 V (input).
Ok, using a Turborix 6ch Tx, I fitted the Tx with a new Esky Lama 2s 7.4v 900mha flight lipo, fully charged, to approx 8v, and within minutes of working with T6config (the configuration utility), The config screen glitched and I lost all my Tx settings! The Tx power light was glowing red from the start of course. Right now, that same battery is showing 8 volts on my multimeter.
Ok, maybe 7V it's a bit near limits, but at 8V you shouldn't have problems. Did you measure the voltage under load, or after disconnecting it or switching off the TX?
Although the TX only drains 180 mA, deppending on the battery, there might be a significant difference between no load and under load voltages.
Anyway, I wouldn't use a 2S LiPo on this TX (too close to 7 V), but I think 8 NiMh is perfectly OK.
Old Feb 23, 2009, 04:20 PM
Joined Dec 2008
No geo no pic of my meter New sd card is ordered and on the way lol. Anyway yes it has a green section with a circular horseshoe type symbol, this is what I have been using also to check the continuity tests, on xk setting, it has one other setting which is x10 so which would I use for this particular test? Thanks.
Old Feb 23, 2009, 05:23 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Meter
86waterpumper -
Please, please go buy one (or two) of these . It will make your troubleshooting a lot easier, I promise.
AJ
P.S. It even comes with batteries (well, mine did). I have 3 of them because I keep misplacing them.
Old Feb 23, 2009, 05:28 PM
Lead Wings is offline
Find More Posts by Lead Wings
I enjoy the voices
Lead Wings's Avatar
Perth, Australia
Joined Apr 2007
Interesting that they say Rx's will be $25 if the 6 channel ones can work and are only $13
Lead Wings is offline Find More Posts by Lead Wings
Old Feb 23, 2009, 05:31 PM
Rouen (FRANCE)
Joined Nov 2003
86waterpumper ,
can you describe the scale (the omega one , like a circular horseshoes), Xk is Thousand times and X10 is 10 times what you are reading on the scale, for the continity you have to use the lower one X10 in your case or less if you have one like X1.
the scale (logarithmic) should be like one of these 2 on the picture
Géo
Old Feb 23, 2009, 06:38 PM
BlueFFF is offline
Up in smoke!
BlueFFF's Avatar
Greenville, TX
Joined Jun 2007
If the new 9ch TX is the same as the imax then it's possible they may be planning to offer FSSS and FHSS modules and not the GFSK system there $30 TX uses. I hope this will not be the case. I also hope other brands of modules will fit into the new TX. It would really make this a popular 9ch system and put pressure on the other brands to lower there prices.
Old Feb 23, 2009, 08:01 PM
congo is offline
Find More Posts by congo
Joined Feb 2009
I ran the test again, measured the static voltage of the lipo as 8v, and there was no noticeable vdrop under Tx load, measured on the Tx case battery terminals which are still connected. (my multimeter is a good old analog one, so I don't have digital accuracy)
When I started the T6config and switched on the Tx, I had lost my settings. but was able to reload them after two attempts.
I began the test again from scratch, this time it was reliable and showed my correct settings at bootup. Repeated twice, same reliable result.
Ended test after nearly two hours, load voltage was then 7.5v, no further problems.
I am a tad confused about the initial glitch at power up for this test sequence. I could not reproduce it. Remember, my Tx has a damaged Rf choke in the trainer module, so, I'm paranoid.
congo is offline Find More Posts by congo
Old Feb 24, 2009, 02:55 AM
com210 is offline
Find More Posts by com210
Bouvard Western Australia
Joined Feb 2009
Congo, did you get to try the transmitter when you lost the settings? I mean did it default back to something or was it completely dead? Sounds scaringly similar to what happened to my tranny.
com210 is offline Find More Posts by com210
Old Feb 24, 2009, 02:58 AM
tommywatson is offline
Find More Posts by tommywatson
Sydney Australia
Joined Sep 2003
Binding
I just received two new 6 channel receivers from R2hobbies. Both bound OK first time. I have a 3S lipo in my TX,
Regards
Tom Watson
Sydney Australia
tommywatson is offline Find More Posts by tommywatson
New Product X8---new 2.4GHz Radio System ASSAN Radios 5743 Sep 01, 2016 11:51 AM
Yippee! New 2.4GHz DSM radio - New standard? PrasadL Scratchbuilt Indoor and Micro Models 12 Jun 03, 2013 07:03 AM
For Sale NEW - 2.4GHZ 2 channel Pistol R/C system SRM Cars - Cars and Parts (FS/W) 0 Oct 22, 2008 09:39 AM
FS: 1x Used 1x New 2.4ghz Wireless video cameras with receiver Nik-rc Aircraft - Electric - Airplanes (FS/W) 4 Nov 30, 2004 06:21 PM
