So, my parts list for the cable is:
1 - Level Shifter: Assembled Shifter Or Unassembled Kit 1 – PS2 keyboard connector with about 12 inches of cable still attached. 1 – RS-232 Male DB9 connector. (You can harvest one from an old serial cable if you have one laying around) I already covered the level shifter so will move on to the PS2 connector. The pin layout of the PS2 is the same as the 4 pin din layout needed for the radio but you’ll need to remove the little plastic key in the connector barrel. To do this take a small screwdriver or other implement and apply a little pressure to the key and it will break away easily. Try not to damage any pins but if you do bend a couple they can be bent back easily. What you’ll be left with is a 6 pin din, where the 2 top pins will now fit in the key of the transmitter. You can remove those pins if you want but I chose to leave mine in to provide some orientation protection. |
Waga,
The Trainer connector shown in this post: http://www.rcgroups.com/forums/showp...&postcount=178 looks to me like an S-Video cable connector. You can buy S-Video cables in the electronics department of just about any *-mart store. If it is indeed an S-Video connector, then no snipping of posts are required, as there would be with a PS-2 connector. |
Joined Sep 2008
[QUOTE=keepitsimple]Hello,
First of all.. congratulations for this great job! I see from your Mixer Screen that you "connect" the Pots to the 5th and 6th channel. By this you lose two Mixes and remains only one mix to use. My question: Is ther any other way to get the 5th and 6th channels operative?. I bought the Tx and Rx from r2hobbies. regards kinkon |
Hannover,Germany
Joined Dec 2006
now the transmitter doesn't work
Hello
I've this Transmitter/receiver since 4 weeks and until yesterday it's works very well. Yesterday I was reprogramming this DR setting and when I have finished, I switched off and reconnected the transmitter and go to my model ( T-38 Trojan from Parkzone ). After switch on the transmitter and the model, the servos from canal 1-3 goes to the endpoint and do nothing, when I move the sticks on the transmitter , only canal 4 works. Again on the computer I can see the same result in the T6config software, all the bares was on the endpoints and no movement ( Image1 ). In the meantime I've tried out a lot of possible configuration, I've reloaded the default values, I've deactivated all mixers, switches, DR without success. When I change the endpoints from 1 and 3 to 1 and 2, the bares becomes smaller and I can see a little changing when I move the sticks. Now in the configuration all endpoints are 100%, all SupTrims are 0, all switches and mixers are off, the mode is 2 and acro is selected. Has anybody an idea, what could bee happen Thank in advance Klaus |
| Thread Tools | |
| New Product X8---new 2.4GHz Radio System | ASSAN | Radios | 5653 | Feb 13, 2013 05:07 PM |
| For Sale NEW - 2.4GHZ 2 channel Pistol R/C system | SRM | Cars - Cars and Parts (FS/W) | 0 | Oct 22, 2008 09:39 AM |
| Yippee! New 2.4GHz DSM radio - New standard? | PrasadL | Indoor and Micro Models | 6 | Oct 24, 2005 05:57 PM |
| FS: 1x Used 1x New 2.4ghz Wireless video cameras with receiver | Nik-rc | Aircraft - Electric - Airplanes (FS/W) | 4 | Nov 30, 2004 06:21 PM |
