Old Jan 29, 2009, 02:34 PM
sebikolo is offline
Find More Posts by sebikolo
Joined Jan 2009
Ch 5 & 6 - ?
sebikolo is offline Find More Posts by sebikolo
Old Jan 30, 2009, 02:47 AM
geotrouvetout is offline
Find More Posts by geotrouvetout
geotrouvetout's Avatar
Rouen (FRANCE)
Joined Nov 2003
Hi,
This is a OTP chip, if the program has not be done to read 6 channel you can't get more from this radio.
To more channel, you have to make your own encoder with a PIC, AVR etc ..., i think it's a PPM from the encoder to the RF.
Gťo .
geotrouvetout is offline Find More Posts by geotrouvetout
Old Jan 30, 2009, 07:03 AM
sebikolo is offline
Joined Jan 2009
Thank Gťo
Old Jan 30, 2009, 11:58 AM
TeamTEOR is offline
Find More Posts by TeamTEOR
Off 2 The Edge of Reality
TeamTEOR's Avatar
Scottsdale, AZ
Joined Sep 2003
As expected, Airtronics was not willing to help in any way at all.
TeamTEOR is offline Find More Posts by TeamTEOR
Old Jan 31, 2009, 11:51 AM
BlueFFF is offline
Find More Posts by BlueFFF
Up in smoke!
BlueFFF's Avatar
Greenville, TX
Joined Jun 2007
waqa,
I really like the screen shots you did for your compaq. I dug mine out and it still works. Being able to change planes in the field and having tons of model memory really makes the 6ch TX worth the $60 bucks. I think I will just buy one of those rather than try to hack a way to use my Polks Tracker III for 2.4G. Would it be possible to build a cable to interface the compaq and the existing USB hookup on the TX rather then adding a special one to the TX? I'm thinking a special cable that could be connected to my existing Compaq cable and then to the USB port on the back of the TX leaving both TX and Compaq items in there original condition. What do you think?
I don't know too much about electronix stuff, but can do my own soldering when the need arrises, but I would need some instruction on how to do this if it is possible.
BlueFFF
BlueFFF is offline Find More Posts by BlueFFF
Old Jan 31, 2009, 02:42 PM
waqa is offline
Find More Posts by waqa
have foam, will fly
waqa's Avatar
San Diego
Joined Dec 2008
Originally Posted by BlueFFF
waqa,
BlueFFF
BlueFFF,
Leaving the TX+cable and Ipaq+cable intact is on my list of things. I hacked into my TX as it was just quicker to do than build a go-between module at the time and I don't have a 4 pin mini din plug like the one on the TX side of the usb cable so I already cut my cable.
To avoid cutting anything, I have put together a simple circuit that uses 3AA batteries. The parts should all be available at radio shack except possibly the 4 pin mini din, I'm going by my radio shack today to find out if they carry it. If not I'll have to order one from mouser.com, they cost about $1.
The parts needed are:
max232n IC (level shifter 5V-12v)
5 1uf capacitors
small perf board
4 Pin Mini Din (S-video male plug)
breakaway header pins or male db9 (to connect to Ipaq or any pocket pc rs-232 serial cable)
a small switch
3AA or 3AAA battery holder
There are plenty of ways to do this but I think this is the least expensive solution. I'll post more detailed schematics and build photos once I'm done making it. You could also use a lipo or single 9v with the addition of a 5v regulator like a 7805. I'm not sure about the current usage but will test it and post my results.
In the attached photo you can see how I use my TX side connector for both the Ipaq and USB by cutting it and soldering in servo connectors. Only 3 wires are used so servo connectors and wire works great for this.
waqa is offline Find More Posts by waqa
Old Jan 31, 2009, 04:04 PM
BlueFFF is offline
Up in smoke!
BlueFFF's Avatar
Greenville, TX
Joined Jun 2007
waqa,
That sound great! Just the type of help I was hoping for I will have to get my TX on order.
BlueFFF
Old Feb 02, 2009, 08:13 PM
abbydawn is offline
Find More Posts by abbydawn
Joined Sep 2008
Originally Posted by waqa
Yes, any Ipaq running OS version 3 or later will work.
So far I've got 9 screens.
I'm trying to exploit the touch screen as much as possible to make it a nice tool, any and all ideas are welcome. This is all open source so any and all good ideas go into the design. I need to clean up the screens, get all the fonts right, and barring any major issues should have it all done this weekend.
For anyone interested, the source code as it evolves will be here. I make no warranty etc. on the software, use it at your own risk.
A PC novice here so the question may be absurd. Is there a handheld out there that could be used in the same manner as my home PC to program the TX? I suppose the OS might not be compatible with the software driver provided. Have to be cheaper than a portable PC.
abbydawn is offline Find More Posts by abbydawn
Old Feb 03, 2009, 09:48 AM
waqa is offline
have foam, will fly
waqa's Avatar
San Diego
Joined Dec 2008
I'm using my Pocket PC Handheld. It is an older model that has a regular serial cable rather than only USB. Any newer Pocket PC's having only USB may need to use a Bluetooth version, if they have bluetooth. I'm also working on a Palm Pilot version though the software for it will take longer.
Old Feb 03, 2009, 10:05 AM
waqa is offline
have foam, will fly
waqa's Avatar
San Diego
Joined Dec 2008
I tried the MAX232 circuit with no luck. I wasn't 100% it would work as the 115kpbs baud rate needed is near the upper limit for these chips. There are plenty of other level shifter IC's out there, mouser.com carries around 100 of them. Most operate up to the mhz ranges and most are in SMD (tiny) packages.
So, since my first version works, I'll stick with it. The level shifter I'll use is this one LINK , it works and has nifty TX and RX LED's so you know everything is hooked up right and working. They cost $10. Building the same circuit from scratch wouldn't save much.
You'll need to power the level shifter. The TX uses 5V TTL logic so I'm going to try out this DC-DC converter
4.5V might be sufficient so I'll try a 3AA setup as well.
I've got a few 4 Pin DIN plugs coming from mouser in a couple days and will report back then. Radioshack had none of these.
Old Feb 03, 2009, 12:03 PM
MoFl is offline
Find More Posts by MoFl
MoFl's Avatar
EspaŮa, AL, Sevilla
Joined Apr 2007
What about IR port?
Hi to all, although I registered a long time ago, this is my first post in this forum.
I'd like to introduce another possibility to communicate Pocket PC's with this RC system (BTW, I have the 6 Ch Turborix) which could be to use the IR port, that is quite common. I've had 3 pocket PC phones, and all of them had IR serial port.
Obviously, a serial to IR interface would be needed on the transmitter's side. I've found these two schematics but, for sure, there are lots of them, and also ready made, because (old?) PC motherboards used to have a header to plug them in:
http://electronica.ugr.es/~amroldan/...ccion_IrDA.doc
http://www.rentron.com/IR_TRANSCEIVER.htm
What do you think?
MoFl is offline Find More Posts by MoFl
Old Feb 03, 2009, 04:03 PM
BatLaw is offline
Find More Posts by BatLaw
BatLaw's Avatar
United Kingdom, Wales, Dinas Powys
Joined Jan 2005
A very simple question from a simpleton. Will this Tx bind with/to the Parkzone Rx found in the Vapor and Ember 2?
BatLaw is offline Find More Posts by BatLaw
Old Feb 03, 2009, 04:27 PM
MoFl is offline
MoFl's Avatar
EspaŮa, AL, Sevilla
Joined Apr 2007
You could try to find the PPM signal following a similar procedure as described here:
http://users.belgacom.net/TX2TX/tx2t...to-oscillo.htm
http://users.belgacom.net/TX2TX/tx2t...h/tx2txgb1.htm
It's a page dedicated to explain how to make trainer cords to join different brands of radios. The same problems (finding PPM signal, changing polarity, ...) are found in this task.
Old Feb 03, 2009, 06:30 PM
MoFl is offline
MoFl's Avatar
EspaŮa, AL, Sevilla
Joined Apr 2007
Photos of Turborix 6 ch
I'd like to share some photos of the Turborix 6 ch system.
Also, some remarks:
The receivers and RF section are exactly the same than in the 4 ch system.
On the TX, the battery +12V is routed to two 5 volt regulators: a smd one, on the tracks side, which feeds the microcontroller, and a TO-220, comp side, which feeds the RF module. The +12V track also feeds a resistor divider going to the microcontroller (probably, just for voltage sensing). So, it isnít a problem to feed the TX with NiMHs, LiPos or anything that provides enough voltage for the regulators to work (typically 7.5V). From the photos in other posts, looks like the same applies to the 4 ch system.
The mainboard (not the same as 4 ch version) is prepared for another versions of the TX: Has room for reverse switches and a HF section (you can see the place for the XTAL (under the TO-220) regulator, and for the RF coils (marked IFT1ÖIFT5). The reverse switches are routed to microcontroller pins, maybe the program is prepared to react, maybe itís not (depends if itís the same micro/program than for the other versions with the same mainboard).
The PPM output of the microcontroller is routed to the trainer connector via 1k2 resistor. This signal is not used by the programming cable, but is useful for a PC simulator (Iíve used FMS with a standard USB simulator cable). The same microcontroller signal is routed to the PPM_IN of the RF module via a resistive divider.
The trainer/programming connector has all the pins wired (pinout in a previous post from keepitsimple). In the 4 ch system there is one wire missing.
The main IC on RF TX module and both RX modules is an A7122 (http://www.amiccom.com.tw/upload/200...6243578035.pdf). The main and aux RX have the same RF board. There is a 16 pin SOIC labeled FS8004, in the TX module, both receivers RF boards and also in main RX motherboard. I havenít been able to find information on this one (same as somebody said in a previous post). Coud be some type of microcontroller.
I have a Futaba FP7UAP, and maybe I'll experiment feeding it's ppm signal into the Turborix's RF module (after adapting signal level), and see what happens. As the same USB simulator cord works with both radios, protocols should be quite compatible.
Hope this information is useful for somebody!
Old Feb 03, 2009, 08:07 PM
abbydawn is offline
Joined Sep 2008
Also, some remarks:
The main IC on RF TX module and both RX modules is an A7122 (http://www.amiccom.com.tw/upload/200...243578035.pdf). The main and aux RX have the same RF board. There is a 16 pin SOIC labeled FS8004, in the TX module, both receivers RF boards and also in main RX motherboard. I havenít been able to find information on this one (same as somebody said in a previous post). Coud be some type of microcontroller.
NoFi, interesting info, thx. Some of us are having rather unbelievable range test results which makes us wonder if the button is actually doing the job it supposed to. Also I've found that if I hold the button down before turning the TX on there is no transmission until I release the button. Does that make sense? Maybe you could shed some light on how the dang thing technically performs a range test? One flyer flew to his visual limits, pressed the range button and still maintained control!
New Product X8---new 2.4GHz Radio System ASSAN Radios 5743 Sep 01, 2016 11:51 AM
Yippee! New 2.4GHz DSM radio - New standard? PrasadL Scratchbuilt Indoor and Micro Models 12 Jun 03, 2013 07:03 AM
For Sale NEW - 2.4GHZ 2 channel Pistol R/C system SRM Cars - Cars and Parts (FS/W) 0 Oct 22, 2008 09:39 AM
FS: 1x Used 1x New 2.4ghz Wireless video cameras with receiver Nik-rc Aircraft - Electric - Airplanes (FS/W) 4 Nov 30, 2004 06:21 PM
