This thread is privately moderated by Z06 Tony, who may elect to delete unwanted replies.
Old Dec 11, 2008, 09:47 PM
Z06 Tony is online now
Find More Posts by Z06 Tony
Trader Rating: 162
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
Trader Rating: 162
For Sale
Walkera 59#D1 2.4Ghz RTF helicopter all metal head w/extra head parts
I bought this heli new for $200 plus $40 shipping a few months ago. You can get one from Walkera wholesale for $169 plus $40 for shipping now as they are marked down. I flew it (hovered)4 times and the fourth time I had a blade strike and bent the main shaft broke an arm on the head and stripped 2 servos. I put 3 new servos and are including the 2 stripped servos and one good servo. I put a whole new head w/upgraded arm where it broke(it used to be a pressed fit piece and now they are 2 pieces with a set screw. I am including the damaged head with only 2 pieces damaged and all the rest good. The canopy has a crack on the nose(see pic)That is tape in the pic and has since removed and CA'd. One of the lower metal canopy posts is missing. You really do not need the bottom ones as the bottom plate keeps it secure. There is a small flat spot on the main gear but it flies fine. The blades on it in the pics are new and come with new test flown twice Align 325 pros(see vid). Price is $100 delivered conus.
Please note, you only get 1 extra parts head. The other head in one of the pics is not included.
Specification
1). Overall Length: 650 mm
2). Main Rotor Dia. : 630 mm
3). Tail Rotor Dia. : 136 mm
4). All-up Weight: 510g (Battery included)
5). Battery: 11.1V 1200mAh Li-Po
6). Main Motor Type: 380 PF
7). Transmitter: WK-2601
8). Gyro: Built-in
9). Receiver: RX-2601
10).Servo: weight 8.5g / speed 0.11sec/60o(4.8V)/ torque 0.9kg/cm (4.8V) / dimension 22.5X11.5X24mm
Features
1). CCPM mixing control system and collective pitch control system make perfect 3D maneuvers such as rolls, inverted, and swoop flights.
2). The compact structure characterized by metal main frame and metal tail boom makes the helicopter more stable. Easy-to-be mounted parts like servo are used.
3). The drive power for the 59D and 59#D1 are 380PF motor.
4). The flight time on the saturated Li-Po battery will be up to 6-8 minutes.
5). 4-in-1 receiver mixes together the circuits of receiver, speed controller, gyro and mixer. It is of compacted size, high sensitivity, and strong anti-interference.
6). The usage of 2.4G technology is prompter in reaction, more sensitive in operation, and stronger in anti-interference.
Z06 Tony is online now Find More Posts by Z06 Tony
Site Sponsor
Discussion WALKERA 4#3B 2.4Ghz Metal Upgraded Edition Helicopter buacc Micro Helis 132 Jan 30, 2009 06:28 PM
For Sale **NEW** Walkera 5G6 metal 2.4Ghz helicopter $100 delivered Z06 Tony Aircraft - Electric - Helis (FS/W) 1 Nov 30, 2008 07:24 PM
Sold NEW Walkera 4#3B 2.4Ghz FP micro helicopter full metal Z06 Tony Aircraft - Electric - Helis (FS/W) 7 Nov 19, 2008 08:45 PM
Sold NEW Walkera 5#10 2.4Ghz FULL metal upgrade Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Oct 25, 2008 12:20 AM
