Old Dec 11, 2008, 05:38 PM
bambino is offline
Find More Posts by bambino
Mexico
Joined Nov 2005
Hello, Im new into hovercrafts. Any reliable hovercraft to buy?
Hi, I fly small size electric rc helicopters but have been interested in hovercrafts. It is just that I see none in the market. Hovercrafts seem hard to find in any LHS.
May you tell me please what hovercraft is good to buy for a beginner? Any well known brand out there you recommend me?
First of all, I would like to know how is it that single main motor hovercrafts counteact torque reaction. In a single main rotor helicopter you have tail rotor for this. In a coaxial helicopter, both reactions cancel out. How do you work it in a hovercraft for counteract torque reaction?
About 7 years ago I attempted to build one, but it didn't work well
This a diagram of the wannabe hovercraft I build years ago. It was all made of balsa wood, except for the skirt that I made out of that kind of trasparent plastic you use to cover your books.
It lifted, not much, but it lifted a bit. I chose this configuration to avoid setting the motor shaft on a vertical position, then avoiding hovercraft starting to turn.
However, I didn't set correctly the center of gravity so when it lifted, it was not evenly lifted. In addition to that, torque reaction complicated everything.
The arrows show the direction in which I thought air should flow. The screen (that triangle in the middle of the hovercraft) was set at 30 to deflect the airflow coming out from the motor, trying to avoid major loses in power.
I just started it once. As results were disappointing, I did not try it again nor I tried to improve it. I took out the glow 0.049 motor out of it.
Thanks to you all!
bambino is offline Find More Posts by bambino
Old Dec 11, 2008, 07:16 PM
metroidrc is offline
Find More Posts by metroidrc
Micro EDF addict
metroidrc's Avatar
Upstate NY
Joined Jun 2007
If you want something goes on water then you can get the scamper, otherwise the axon racer.
metroidrc is offline Find More Posts by metroidrc
Old Dec 11, 2008, 09:01 PM
bambino is offline
Mexico
Joined Nov 2005
hi metro, thanks
I looked for scamper but it is about 158 british pounds.
http://www.sussex-model-centre.co.uk...d.asp?id=24506
Is there anything cheaper that goes on water also?
thanks!
Old Dec 12, 2008, 04:43 AM
Stef is offline
Find More Posts by Stef
Flying Saucer Mechanic
Stef's Avatar
Middle River MD
Joined Dec 2000
model hovercraft
Good performing model hovercraft made of foam are easy to design and build. Do a search on the internet to see what others have done. If you have an RC set up already a really nice HC could be done for less than $30.
Stef is offline Find More Posts by Stef
Old Dec 12, 2008, 06:24 AM
Micro EDF addict
metroidrc's Avatar
Upstate NY
Joined Jun 2007
wow 158 pounds is alot - considering it takes 8 hours to build!
Yes I'd say try building your own.
Old Dec 12, 2008, 01:54 PM
HoverTim is offline
Find More Posts by HoverTim
HoverTim's Avatar
Joined Mar 2007
intro to rc hovercraft
you could alway try a griffon 600 the are 50.00 for the kit and they are avalible from palaform see link http://www.modelhovercraft.co.uk/index.php?q=65.html thesr craft go well very light made out of depron see link for video
Fran Oakey's Griffin 600 Hovercraft (1 min 22 sec)
hope this helps
HoverTim is offline Find More Posts by HoverTim
Discussion Hello! Im new.... Evo71 Electric Plane Talk 4 Aug 24, 2008 08:59 PM
Discussion Hello Im new and have a question john_auberry Sailboats 0 May 28, 2006 11:42 PM
HELLO,Im new to gas rc flying. tim slocum Dock Talk 2 Nov 05, 2005 08:09 AM
Hello, im new :) LEARSI Micro Helis 16 Aug 26, 2005 01:57 PM
Hello,Im new to this site and ..... tim slocum Scale Boats 7 Jun 23, 2005 12:40 AM
