This thread is privately moderated by Dr Kiwi, who may elect to delete unwanted replies.
Old Jan 04, 2009, 09:35 AM
peterangus is offline
Find More Posts by peterangus
peterangus's Avatar
Blackpool, Great Britain (UK)
Joined Dec 2003
I thought it was clear. In post 74 I am refering to MOTOR INPUT POWER which is the same as BATTERY OUTPUT POWER, and which is casually called WATTS in the flybrushless tables.
peterangus is offline Find More Posts by peterangus
Old Jan 04, 2009, 09:55 AM
rgoble is offline
Find More Posts by rgoble
rgoble's Avatar
Dayton Montgomery, Ohio, United States
Joined Sep 2004
The watts in on FlyBrushless are just Volts*Current
rgoble is offline Find More Posts by rgoble
Old Jan 04, 2009, 02:52 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
I can't imagine how a single "average" equation can cope with the variability of motors and props....but...
...if one is trying to determine how much power one needs to put into a system to get a required output (thrust @ a certain pitch speed) I'd rather turn Peter's equation around.
As an example: I want 20oz thrust at 50mph... what do I need to put in?
20 x.14 x 50 = 140W
Not bad: Hacker A20-22L with a 8x6 APC E:
10.9v, 13.55A, 148W, 8670rpm, 49.3mph, 567g, 19.97oz, 3.83g/W
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Jan 04, 2009, 03:21 PM
Tom Smith is offline
Find More Posts by Tom Smith
Rhinebeck CD-99,00,01,02
Tom Smith's Avatar
New Bern, NC
Joined Mar 2001
Just joined this site but am having a problem. The heading comes in on my computer screen loud and clear but the other writing is so tiny I can't read it. I'm no computer whiz, apparently, so can someone help me out here. Tom
Tom Smith is offline Find More Posts by Tom Smith
Old Jan 04, 2009, 09:27 PM
rgoble is offline
rgoble's Avatar
Joined Sep 2004
The front size on the site isn't set small, it should be about the same as the font here on RCG. Are you having problems with just my site or other sites as well? Also can you tell me what OS and web browser your using.
If your running windows you can hold down the Ctrl Key and scroll your mouse wheel up to make the font larger. Keep in mind doing this will make the font larger on every site. To undo it use Ctrl and scroll down.
Robert
Old Jan 04, 2009, 11:56 PM
Tom Smith's Avatar
New Bern, NC
Joined Mar 2001
There arew a few sites where the printing is so small I can not read it. The main Yahoo site is that way. My computer is running with Windows XP. Tom
Old Jan 05, 2009, 12:00 AM
Tom Smith's Avatar
New Bern, NC
Joined Mar 2001
I just tried the control key thingy and it worked. All this time I have been going nuts with these sites and never knew how the heck to fix it. Thanks a million from a computer challenged senior citizen. Tom
Old Jan 05, 2009, 12:40 AM
rgoble is offline
rgoble's Avatar
Joined Sep 2004
Glad that fixed your problem Tom. That is one of those simple things that can leave you scratching your head for a while if you don't know how to undo it, just like the Alt+Ctrl+Down Key. You probably hit it on accident, I know that's how I found out about it.
Robert
Old Jan 05, 2009, 01:47 AM
A Useless Geek is offline
Find More Posts by A Useless Geek
just Some Useless Geek
Chicagoland
Joined Oct 2008
That's power consumption.
20 x.14 x 50 = 140W
I question whether these "rule of thumb" calculations do us a lot of good without knowing the exact efficiency curve for a particular motor/prop/RPM combo. My suspicion is that the efficiency effects are far too complex to put into a rule of thumb nutshell; it is far more likely that the efficiency per combo needs to be graphed like any other complex curve.
A Useless Geek is offline Find More Posts by A Useless Geek
Old Jan 05, 2009, 09:19 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
About every program has an option to change character size under 'view'. <ctrl> + and <ctrl> - usually do the trick.
Vriendelijke groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Jan 05, 2009, 01:12 PM
rgoble is offline
rgoble's Avatar
Joined Sep 2004
I added a graph to the motors that have Rm and Io values to show the efficiency curve at 7.2v and 11.1v. I can add the rpm or other plots if it will be useful, but for now I didn't want to clutter the graph up too much.
I am using the formula's found at http://www.rcgroups.com/forums/showthread.php?t=185271 to find Ipmax and I graph out to that current.
Robert
Old Jan 05, 2009, 01:30 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
That's why I put in this: I can't imagine how a single "average" equation can cope with the variability of motors and props....but...
But it was interesting to find that the one random sample I selected was in the ballpark!
Old Jan 06, 2009, 12:54 PM
peterangus's Avatar
Joined Dec 2003
Geek and Dr K
In my post #74 I list three constraints.These will filter-out some of the main variabilities. I request that you observe these constraints when you select examples to test the equation.
The third constraint is intended to filter-out examples which are over-propped or under-propped. Such states imply low motor efficiency, and would be of no practical interest.
Two scources of possible large error which cannot be filtered are inaccurate Kvs and inaccurate prop pitches [all too prevalent].
No doubt, there will be room for improvement. But it must not get complicated.
Even if the tolerence on the results is + & - 30%, it may still be worth using. It takes only a few seconds.
Old Jan 06, 2009, 10:28 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Originally Posted by ..
[COLOR=Indigo
Welcome to FlyBrushless.com
Cheers, Phil
Phil,
I tried registering with FlyBrushless.com but they never sent me a confirmation email. Any email address to them would be good. The "Contact US" doesn't seem to work either.
Bill
Prof100 is offline Find More Posts by Prof100
Old Jan 06, 2009, 11:12 PM
rgoble is offline
rgoble's Avatar
Joined Sep 2004
Bill,
I activated your account for you so you should be able to login now. I'm not sure what happened but you are the second person that has said they didn't get the email.
Also thanks for pointing out the blank "Contact Us" page, I must of forgotten to go back and fill that one out.
Robert
Discussion combining data for different brands of motors derway Power Systems 3 Oct 29, 2006 12:23 PM
Test pilots wanted for our AON brushless motors on E-flite Mini-Edge 540 3D ARF. Steven Chao 3D Flying 0 Aug 29, 2005 03:10 AM
motor/prop test bench txzagi Power Systems 9 May 08, 2002 05:36 PM
motor/prop test bench txzagi Fuel Plane Talk 1 May 06, 2002 07:48 PM
Where to Get Service for Jeti Phasor Brushless Motors? GoEFlight Vendor Talk 2 Jan 09, 2002 12:34 PM
