This thread is privately moderated by Dr Kiwi, who may elect to delete unwanted replies.
Old Sep 28, 2012, 02:09 PM
THOMASJONES is offline
Find More Posts by THOMASJONES
Closed Account
Joined May 2011
Originally Posted by Dr Kiwi View Post
Thank you Dr.Kiwi.
Can I please trouble you for the link to the prop that you used, the GWS HD 8x4 for the Suppo 2217K/6T. My APC prop, like you had mentioned, is no where near efficient and I want to make sure I don't get the wrong prop again.
Thanks mate
THOMASJONES is offline Find More Posts by THOMASJONES
Old Sep 28, 2012, 02:34 PM
yomgui is offline
Find More Posts by yomgui
Joined Feb 2011
Hi,
I've just "solved" DrKiwi's suppo from is data + the value of no load current from suppo (1.6A at 10V).
Made some calc with this motor:
@10.7V with GWS 8x4DD : 17.97A - 13583rpm (DrKiwi had 19.3A - 13380rpm)
@11.2V with APC 8x6E : 33.32A - 11851rpm (DrKiwi had 36.7A - 11220rpm)
The difference between calcs and true results can be explain by the fact that I extrapolate from prop data in the 7000rpm range, and by other unknown various small factors.
@11.74V with APC 8x4E : 24.68A - 13917 rpm
so your results are just fine I guess.
BTW, that would produce around 1050 g of thrust, probably a bit more.
yomgui is offline Find More Posts by yomgui
Reply With Quote  (Disabled)
Old Sep 28, 2012, 02:36 PM
yomgui is offline
Joined Feb 2011
Originally Posted by THOMASJONES View Post
Thank you Dr.Kiwi.
Thanks mate
The APC needs more amps for the same thrust than the GWS, IN STATIC, that doesn't mean it's a bad prop IN FLIGHT, it's just two different props as DrKiwi explained.
PS: I believe that with this motor, the GWS 8x4 is better for WOT around 60 km/h and below, the APC one is better for WOT around 80 km/h and above, still the APC always leads to a more powerful setup.
Old Sep 29, 2012, 01:36 PM
Closed Account
Joined May 2011
Wow... thank you so much for sharing your results. It gives me some closure in knowing that I wasn't completely wrong but simply using a different prop.
Do you have the link to the GWS HD 8x4 prop that Dr.Kiwi was using by any chance?
Old Sep 29, 2012, 05:07 PM
yomgui is offline
Joined Feb 2011
This are very common propellers, you should find them at many places.
Old Sep 29, 2012, 10:31 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
http://www.bphobbies.com/view.asp?id...pid=EP8040Gray
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Oct 14, 2012, 03:48 AM
Andy Meysner is offline
Find More Posts by Andy Meysner
Andy Meysner's Avatar
Mississauga ON Canada
Joined Feb 2007
Is there a problem with flybrushless.com account activation? I registered several weeks ago but have never received a confirmation email to activate the account.
Andy Meysner is offline Find More Posts by Andy Meysner
Old Oct 14, 2012, 08:00 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
It is a wonderful page and the gentleman that keeps it up and does all the work is a class act. He is user rgoble here you can PM him or use the Contact Us link on the page that will get you can answer.
There are not limits for using the info there as a guest but being a registered user will let you upload data too.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Oct 15, 2012, 05:39 AM
Joined Feb 2007
Thanks Jack, I'll contact Robert
Old Oct 15, 2012, 07:44 AM
rgoble is offline
Find More Posts by rgoble
rgoble's Avatar
Dayton Montgomery, Ohio, United States
Joined Sep 2004
Andy I sent you a PM about your account. Jack thanks for telling him how to get in touch with me.
Robert
rgoble is offline Find More Posts by rgoble
Old Oct 15, 2012, 07:56 AM
Jack
USA, ME, Ellsworth
Joined May 2008
You're more than welcome. And thank you for your work and devotion to a most wonderful site!
Jack
Old Oct 15, 2012, 08:14 AM
Joined Feb 2007
Thanks guys
Old Nov 27, 2012, 09:09 AM
taboRC is offline
Find More Posts by taboRC
Monterrey
Joined Dec 2008
Question regarding Motor - ESC - Battery
Hi Guys, Im getting ready for the Winter in Mexico, thats mean, no longer 45C during the day..
I cool brother just got me a Midget Mustang (http://ecsvr.com/twm/shopexd.asp?id=3724) from The World Models, they suggest I use the following equipment..
Outrunner Motor KM0203800
Propeller Adaptor HW2340101, 7" x 4" propeller
25A brushless ESC
2 cells 7.4V 2100 Li-Po
What if I use instead the Rimfire 300 and 11.1V battery?
I really want some speed on this baby.
taboRC is offline Find More Posts by taboRC
Old Dec 09, 2012, 10:55 AM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Rimfire 300 is only 1380Kv... if you want real speed you need a higher Kv motor, and slightly smaller, high pitched prop... a MicroDAN 2505 (~1885Kv) on 3s with a 6x5.5 APC E gets you 512g @ 76mph from 14.2A/152W... or if you went to 4s you'd get 700g @ 104mph from 19.60A/267W.
With a 5.1x4.9 Zagi on 4s it gets you 572g @ 90mph from just 14.30A/200W.
This question should be over in Power Systems, not here.
Old Jan 05, 2013, 11:50 AM
tengarang is offline
Find More Posts by tengarang
Fly Straight Fly High
tengarang's Avatar
United States, CA, San Jose
Joined Aug 2010
Ive run in to a situation where im seeing some weird unexplained data.
Im running a certain setup with a 1550KV 3128 bell motor using an FMS 35amp esc.
using the known good reference 3s 850mah 25C-50C turnigy nano tech, im able to draw 30amps at 240 watts on the watt meter. I only have one of these packs
I have four more of 3s 850mah 45C-90C fully charged and balanced using the same setup platform...all four packs somehow level down to 10 amps and only 90 to 100 watts....
Here is the kicker...
Ill put a 4s 850mah with 45C and I only get 14 amp draw at 148 watts....
I know this is not the ESC...because with that one special 25C to 50C 3s pack im getting the full capability of the motor....
on my other platforms I dont see this problem with the packs in question...just this particular setup...
i was referred to this thread from this thread....you will see my frustrations there as well
http://www.rcgroups.com/forums/showt...1665167&page=7
tengarang is offline Find More Posts by tengarang
Discussion combining data for different brands of motors derway Power Systems 3 Oct 29, 2006 11:23 AM
Test pilots wanted for our AON brushless motors on E-flite Mini-Edge 540 3D ARF. Steven Chao 3D Flying 0 Aug 29, 2005 02:10 AM
motor/prop test bench txzagi Power Systems 9 May 08, 2002 04:36 PM
motor/prop test bench txzagi Fuel Plane Talk 1 May 06, 2002 06:48 PM
Where to Get Service for Jeti Phasor Brushless Motors? GoEFlight Vendor Talk 2 Jan 09, 2002 11:34 AM
